2.7L oil capacity
Discussion in '4 Cylinder' started by 05RedTaco, Dec 21, 2010.
  1. Dec 21, 2010 at 6:48 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I got to changing my oil in my little 2.7L 2TR engine. First thing I noticed when i checked the oil before draining is that the oil level was one quart ABOVE the full mark on the dipstick. So I was driving around for 4900miles with the engine over filled with oil :rolleyes: Thanks Toyota dealership!
    I have put over sized filter on my 2.7L, part number; 90915-YZZD3 and filled the engine with 5 quarts of Castrol Syntec 5w20. I started the engine, made sure I have oil pressure and shut it off. I checked the dipstick and the oil was on the full mark on the dipstick after only FIVE quarts! Keep in mind that the owners manual calls for 6.1 quarts with filter change :eek: I have checked the oil again this morning after the truck has been sitting the whole night and the oil is hair above the full mark, right where it should be.
    Now there are two options; Either the owners manual or the dipstick are off by a quart...
    Black97v6MT likes this.
  2. Dec 21, 2010 at 6:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Follow the manual.
  3. Dec 21, 2010 at 6:59 AM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    i thought the 4 bangers ran on sunshine and love ?
  4. Dec 21, 2010 at 6:59 AM
    05RedTaco
    Tony
    Scottsdale
    So you are saying that the dipstick is wrong and useless?
  5. Dec 21, 2010 at 7:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Seems to be the concensus....
  6. Dec 21, 2010 at 7:03 AM
    05RedTaco
    Tony
    Scottsdale
    How do you know that the dipstick is wrong, not the owners manual?
    Is there any proof pointing to the dipstick to be wrong?
    If the dipstick is wrong, did Toyota ever corrected the problem? I would like to have dipstick which reads correctly...
    I am not trying to be a dick, just trying to get more info about the problem.
    Black97v6MT, elioregon and Toyko Joe like this.
  7. Dec 21, 2010 at 7:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the 2.7's in teh Tacoma take more oil than the V6 brothers. They all hold about 6 quarts. I havent checked yet, But I belive Toyota uses the same dip stick for the V6, as they do the 2.7. This could lead to the disparity. NO engine in a Tacoma was designed to run only 5 quarts. If you choose to follow the dipstick, as opposed to the manual, and only put in 5 quarts, you'd be running the risk of damaging the engine due to oil starvation. Your call.
  8. Dec 21, 2010 at 7:17 AM
    05RedTaco
    Tony
    Scottsdale
    I know enough about cars to know about the dangers of running low on oil. However over filling the engine is not good either, because it puts more stress on all the engine seals. To starve the engine of oil, the oil level would have to be quite low, since the oil pickup is way down in the bottom of the oil pan.
    Just a guess... The 6.1quarts could be for a dry engine. I know that the 2TR has double balance shafts. From what I know about balance shafts they hold quite a lot of oil and when you change the oil you can't completely drain the oil from the balance shafts.
    On my 2.5L Nissan engine, it had single balance shafts, when i removed the balance shafts, I first drained the oil, then removed the oil pan, then took the balance shafts out. Even after the oil was fully drained and the oil pan was off, I still drained about 0.5quarts out of the balance shafts. Before I even took the oil pan off, I drained the oil for good 20minutes...
  9. Dec 21, 2010 at 7:38 AM
    Ted Nugent
    Ted Nugent Well-Known Member
    Tim
    NEPA
    2010 Reg cab 4x4
    I put 6 quarts in and don't touch the dip stick i just trust the manual.
  10. Dec 21, 2010 at 11:16 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    :) been using 5 quarts for 6 years. No issues.
    Hofmann’s Tacos likes this.
  11. Dec 21, 2010 at 11:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'm puttin half qt in the Toyota filter and puttin it on then dumpin 5 quarts in the motor. I figure 1/2 qt low or 1/2 qt over is not gonna matter that much either way so I just split the difference and go on with life with the dipstick saying F. It's stupid for the 2 motors having same dipstick and stupid for the manual to be 1 qt off from dipstick and stupid to waste time worrying about it. If oil is on F then it's on Toyota for having misleading info in manual and/or misleading readings from the dipstick they chose to put in the motor regardless of how many quarts it took to get it on F.
    Black97v6MT and Toyko Joe like this.
  12. Dec 21, 2010 at 11:33 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    My money's on that, and the engine holds a bit of oil - in balance shafts or elsewhere - even after filter's been removed and oil's drained from the drainplug.
  13. Dec 21, 2010 at 1:15 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    This subject has been beat to death on the forum. IMHO the 6.1 qt figure is for a dry filll, when there is no oil in the heads or the balance shafts. A DOHC engine will hold quite a bit of oil in the head, as this is sort of a big flat tray where the cams are mounted.
    To make the dipstick on my truck show full, requires 5 1/8 qts. 5 quarts fills to just below the full mark. The one time I put in 6 quarts, it showed about a inch above full on the dipstick. Too much oil can, not always, cause foaming of the oil by the crankshaft sloshing it, and air does not lubricate. I trust the dipstick, as Toyota has been using it for at least 6 years now without changing the design, and I dont see any Taco's on the side of the road dead.
    Toyko Joe likes this.
  14. May 28, 2012 at 1:58 PM
    My4x4Tacoma
    My4x4Tacoma Member
    2012 Reg Cab, 4x4, I4
    Did the first oil change today, at about 2200 miles. It still had the factory fill in it, and the dipstick read right at full before I changed it.
    I drained the engine, and the oil out of the filter. About 5 quarts total.
    I put 5 quarts in, ran the engine a few minutes, and the dipstick now reads just below full. So my conclusion is that 5 quarts with the filter is about right.
  15. May 29, 2012 at 11:32 AM
    OldDog
    OldDog Well-Known Member
    w.mass
    2010 reg cab 4X4
    I just changed my oil. I put 6 qts in. Dip stick tells me its over filled( you can't even get a level line of oil on the dip stick....It sucks ). Which I don't believe .manual says to use 6.1 qts.
  16. May 29, 2012 at 12:17 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I think I would be verifying I have the correct dipstick at the dealer.
  17. May 29, 2012 at 2:35 PM
    91r100gs
    Dan
    Kansas City area
    OldDog,
    Let it sit level overnight, then when you pull the stick look on the back side for the reading. I just use 5.5 and call it a day.
    Happy Motoring
  18. May 29, 2012 at 2:41 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    ^^x2, my manual says 5.5 qts. so thats what goes in and dipstick is dead on everytime! Stop being so paranoid!
  19. May 31, 2012 at 5:54 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    This is funny because I just had my oil changed and the guy tells me I had to add an extra quart it took 6! I look back at the previous oil changes all from the same place and they say 5. Now Im thinking....... wtf right? I check the dipstick and it does not read abnormal.
    So I may or may not be driving around overfilled. I am more concerned with all the 5 quart changes in the past.
  20. Jun 1, 2012 at 6:21 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
