2.7L Computer Performance Chips...
Discussion in '4 Cylinder' started by Navelfunk, Sep 5, 2011.
  1. Sep 5, 2011 at 5:11 PM
    Navelfunk
    Navelfunk [OP] Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
    Is anyone using them? How are they?
  2. Sep 5, 2011 at 5:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    Nope. junk. waste of money. You'd get more performance buying a bag of doritos and farting in the gas tank.
  3. Oct 18, 2011 at 4:22 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, 300mm Broadway rear view mirror, LED brake lights, side markers, rear turn signals, plate lights, and interior lights. Flowmaster cat back exhaust, a cracked tail light that I fixed with some tape, all black grille, 15” Raceline 401B wheels, Goodyear 235/75/15 All Terrain Tires
    Just do a supercharger. It'll work:D
  4. Oct 19, 2011 at 12:23 PM
    Navelfunk
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    I'm over it. I saw one for $4300, but that's a waste of money for the end result. I'd probably have to put that much, if not more money into the suspension, rims & tires, and the exhaust. Plus, the bulk of the computer/chip set is not very compact. I'm trying to roll low-key. Sleeper style...
  5. Oct 19, 2011 at 12:27 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    when i pay this thing off i'm sending mine to diesel toyz in texas and getting the turbo diesel engine and hd manual trans swap then it's sas or a complete overhaul of the ifs i'm undecided on the last one.
  6. Oct 19, 2011 at 5:01 PM
    compmoto
    compmoto Member
    Kevin
    femocrat MD
    09 Tacoma Access cab 2WD
    those were some great, insightful answers to his question, which happens to likely be the same as others on the site. I didn't buy my jap taco for that purpose. I was hoping to use it to get better MPG, and still move the "smaller" items in my world. I would like to know a way to extract some more power, and MPG outa this baby-boy truck ...without turbo/super fuel infected, diesel afterburner BS investment...I already spent $20K on this POS! I shoulda done more research! Mazda/Ranger supposedly gets better MPG,and has a little more power/payload ...plus they are known for similar reliabilty... just sayin
  7. Oct 19, 2011 at 5:33 PM
    compmoto
    compmoto Member
    Kevin
    femocrat MD
    2009 Ford Ranger Performance & Efficiency Standard Features
    2,260 cc 2.3 liters in-line 4 front engine with 87.4 mm bore, 94.0 mm stroke, 9.7 compression ratio, double overhead cam and four valves per cylinder 99D
    Unleaded fuel 87
    Fuel consumption: EPA 08 city (mpg): 21, highway (mpg): 26, combined (mpg): 23, 629 and 391
    Multi-point injection fuel system
    17.0 gallon main unleaded fuel tank 14.2
    Power: 107 kW , 143 HP SAE @ 5,250 rpm; 154 ft lb , 209 Nm @ 3,750 rpm
    Read more: http://www.truckinweb.com/ford/99/ranger/2009/performance.html#ixzz1bH
    ENGINE 2.7L-4CYL 4.0L-V6 Type, Materials 2.7-liter inline 4-cylinder, DOHC 16-valve cast iron block with aluminum alloy head with VVT-i 4.0-liter DOHC EFI V6, 24-valve aluminum block with aluminum alloy head with VVT-i Displacement 2,694 cc 3,956 cc Bore x Stroke 3.74 x 3.74 in. 3.70 x 3.74 in. Compression Ratio 9.6:1 10.0:1 Horsepower 159 hp @ 5,200 rpm 236 hp @ 5,200 rpm Torque 180 lb-ft @ 3,800 rpm
    Read more: http://www.trucktrend.com/features/...ccess_cab_tech_specs/index.html#ixzz1bHFte8vi
    I guess , technically you are correct , but 2.3L vs 2.7L , come on now...
    I bought a Toyota , and expect more than resale value for my money. I can't haul my junk with "resale value" Thanx for your insight...
  8. Oct 19, 2011 at 7:51 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    He wants the mythical combination of more horsepower and better fuel economy. :facepalm:
    Sounds like someone wants to bitch about their baby-boy POS truck.... just sayin'
    Those performance chips kick ass, minimum 15hp and at least 4mpg, check my sig, I went from 21 to 30 mpg with one.
  9. Oct 19, 2011 at 7:57 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    08tacoma4x4 5spd 4cyl
    afe cold air intake,tornado fuel miser,body armor front bumper,dual magna flow exhaust,blacked out factory rims and fender flares,baja lights,cooper ATR tires,Gforce,hood scoop,peel n seal bed cover,chrome nerf bars
    iv got the gforce chip on my 2.7l i can tell a big difference in sound and power getn 27 to 29mpg
  10. Oct 20, 2011 at 12:41 PM
    Navelfunk
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    That actually was helpful. If I had my '68 GTO still, I wouldn't be having this discussion, it would've already been done. But, my taco is 1yr. old and has 3k mi. on it, and cost me $18k with everything but bluetooth. Looks like intake & exhaust are the winners, along with some wider tires. Now all I need is a job to pay for 'em...
    Plus, if I'd really wanted a race truck I would've bought a V8 Tundra or a V10 Ram...
    DGXR likes this.
  11. Oct 20, 2011 at 12:48 PM
    rdp5008
    rdp5008 Well-Known Member
    Russell
    Missouri
    2001 Tundra
    ARE Camper Shell
    Where can I buy dorito fart in a can to add to my gas tank? Do doritos help with the farting performance gains or do non-dorito farts work too?
    Finally a cheap power mod that works!
  12. Oct 21, 2011 at 4:17 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    why dont i just put u on my hood so u can blow all that hot air ur wasteing down my intake . or just try this dont down a product till you try it mine was free so no money wasted there:)
  13. Oct 21, 2011 at 5:10 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    Like i said dont down it till u try it im running lower rmps since i put it on and im happy with it so go chocke on ur methane bro:brianr:
  14. Oct 21, 2011 at 5:30 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    so ur telling me every mod u ever done to ur truck is useless because it didnt come factory i guess ur rite its all a waste of money:eek: hey i forgot 2 tell you dnt put gas in it it didnt come from the factory:D
  15. Oct 21, 2011 at 6:33 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    mine must be different then cause its rite on the intake just b4 the throttle body nah ur right i forgot u know it all your mr know it all
  16. Oct 21, 2011 at 6:37 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    i guess next ur going to tell me a turbo wont work either and that porting and posishing the head is no good either ?:p
  17. Oct 21, 2011 at 6:54 PM
    mytoyo2
    mytoyo2 Mytoyo2
    Frank
    va
    im not wasting good money or letin some dumb ass rag my truck out on a dyno .with that being said no 1 knows a truck as well as its owner if u wana put 1 on ur truck and run it on a dyno have at it
  18. Oct 21, 2011 at 6:57 PM
    worthywads
    Dude, get a grip, you obviously don't realize your throttle body restricts the flow by around 75% or better while you are cruising down the road even at 80mph. Some fixed piece of metal prior to that throttle body CAN'T improve the flow that lasts through a flat plate choking the motor.
    And how the fuck can you run at lower rpms with a manual transmission at the same speed? Since you must be driving slower it makes total sense you are using less fuel, because that the only way you can be running lower rpms.
    A turbo on the other hand can make more power, since it increases pressure along with fuel on BOTH sides of the throttle body.
    Your ingnorance is glaringly obvious. :crazy:
  19. Oct 21, 2011 at 7:01 PM
    worthywads
    Many have done dyno test only to repeatedly find NOTHING.
  20. Oct 21, 2011 at 7:21 PM
    worthywads
    Just said it, turbo works, tornado doesn't, can't run lower rpm with manual unless you drive slower.
    What don't you get?
