2.7 oil pump installation
Discussion in '1st Gen. Tacomas (1995-2004)' started by LittleT, Oct 30, 2017.
  1. Oct 30, 2017 at 8:35 PM
    LittleT
    LittleT [OP] New Member
    1999 Tacoma Prerunner
    does anybody know if the marks on the oil pump gears need to be aligned...
  2. Oct 30, 2017 at 8:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Oct 30, 2017 at 9:19 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I believe the inner gear has one less "tooth" than the outer gear, so it won't stay aligned anyway as it spins, so my guess that it doesn't need to be aligned. The 1996 repair manual doesn't mention needing to align the gears. The marks may indicate that they should both be facing outward.
    LittleT[OP] and Dalandser like this.
  4. Oct 31, 2017 at 12:26 AM
    Glamisman
    Glamisman Well-Known Member
    this is what I have...
  5. Oct 31, 2017 at 11:57 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    I didn't align mine. PACK it FULL of petroleum jelly to help it prime. picture below is what happened when it didn't prime fast enough and wasn't packed with enough petroleum jelly (i cleaned a lot to get this picture).
    LittleT[OP] and 98tacoma27 like this.
  6. Oct 31, 2017 at 5:49 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    no prime needed
    LittleT[OP] likes this.
  7. Jul 11, 2019 at 12:04 PM
    2000Tacomauser
    2000Tacomauser New Member
    2000 Tacoma
    Info response is two years too late...but the smaller gear mark aligns with the crankshaft key and the larger gear mark aligns opposite of the other. This is so the crankshaft pulley will slide back on and engage with the pump gear without a hassle.
  8. Nov 4, 2024 at 11:56 AM
    Langing
    Langing Well-Known Member
    Bill
    Durham, NC
    2000 Blue Tacoma Regular Cab 2.4L 2RZ-FE 2WD MT
    Camper on back
    Interesting comment you made here @2000Tacomauser. Where did you get that information?
    I'm having a problem getting oil pressure after doing a ton of work on my 2000 2RZ-FE. The engine was dry of all oil when I began the first start. Had a pressure gauge, never showed any pressure at all.
