2.7 Oil pan leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MidnightJambalaya, Apr 5, 2022.
  1. Apr 5, 2022 at 1:47 PM
    MidnightJambalaya
    MidnightJambalaya [OP] New Member
    1996 tacoma sx
    I’ll start off by saying I’m not much of a mechanic at all. I don’t even change my own oil not gonna lie. I’ve noticed since I’ve had this truck that it leaks loads of oil mostly while driving long distances though. I had the head gasket replaced a few months ago but the leak has still been there. When I crawl down under there I notice a lot of oil on the skid plate and it’s leaking from lower down in the engine. I’ve attached a picture. Seems like oil pan or filter?? Need help thanks, currently my truck is also my house so would like to figure it out.
  2. Apr 5, 2022 at 2:19 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Yeah, it's an oil leak.
  3. Apr 5, 2022 at 2:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In my opinion it’s not just the oil pan.
    I can see oil dripping from the filter.
    Oil doesn’t usually leak UP. It leaks down.
    You need to degrease the engine and see where it starts. Oil dye will help.
    oneikr and Deathbysnusnu like this.
  4. Apr 5, 2022 at 2:24 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Could be leftover from the valve cover leak, it's pretty high on the block to just be oil pan.
    Get a couple of cans of brake cleaner and spray that crap off, get it clean. Then you'll be able to see what if anything is leaking.
    Plus working on an oil coated engine just sucks.
    oneikr and TnShooter like this.
  5. Apr 5, 2022 at 7:09 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Definitely need to clean off all the gunk so you can tell where it's coming from.
    The gaskets on the oil filter mount are easy to replace, so start there.
    It could also be a timing chain cover seal, front crank seal, or something higher.
    I had a leak at the spot where a distributor would go, right behind where the coil packs mount. You couldn't see it unless you removed the coil packs.
  6. Apr 6, 2022 at 3:45 AM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Mine looks the same. It's a leak at the filter mount. I have not tried to fix it, but have read about it on these sites. Common problem.
    crazytacoman likes this.
  7. Apr 6, 2022 at 5:45 AM
    TreyG870
    TreyG870 New Member
    Trey
    2001 Tacoma
    Mine looks like that, but I'm almost certain it's coming from around the oil pump. I've ordered a kit from LC Engineering to hopefully remedy that situation.
  8. Apr 6, 2022 at 6:04 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Clean it up as mentioned. Looks like oil filter seals. I believe you can buy both for about 12$.
  9. Apr 6, 2022 at 6:05 AM
    Toyotadilly
    Dillynn
    Sarasota,fl
    If it's that same area then mostly likely that's what you need. Over the years of hot oil make them super brittle
    oneikr likes this.
  10. Apr 6, 2022 at 8:29 AM
    heavymetallecturemonster
    heavymetallecturemonster Member
    Billy
    Triangle area, North Carolina
    1997 Tacoma
    Mine also looks that way, I just replaced the valve cover gasket which was definitely leaking but I'm now trying to figure out if there are other leaks. Not sure if the valve cover leak, which was a trickle, could all drip all the way down to soak the lower area of mine to look the way yours does
  11. Apr 6, 2022 at 11:21 AM
    Toyotadilly
    Dillynn
    Sarasota,fl
    Oil travels down and wind velocity will spread it all over. Keep the area clean and just look for anything new. As mentioned also,uv dye can be added to the oil and a black light can assist in identifying the oil leak
  12. Apr 6, 2022 at 4:46 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Truff right there...... I did mine a while back, easy.
  13. Apr 6, 2022 at 8:00 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I just did mines a couple of months ago. Really helped with reducing the oil left on the pavement after parking for a while. I still get a small drop, but only after parking on an incline for a while.
