2.7 liter towing capacity
Discussion in '4 Cylinder' started by dgjones, Mar 13, 2010.
  1. Mar 25, 2010 at 10:47 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    no to be an asshole or anything...they stole that dyno from doug thorley because iv had that dyno saved on my desktop for the past forever....thats the stock dyno for a 2.7 with nothing to do with lce engineering. i highly doubt that lce got the exact same number as lce. i know dynos stock are dynos stocks, but its not aways the case.
    yes manuals will have more power than auto because the manual transmission is less "complex" with fewer lower losing parts.
    yes this is the baseline for the 2.7 (2tr) motor
  2. Mar 26, 2010 at 12:24 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    true sorry i was just trying to demonstrate the difference between flywheel hp and wheel hp. thats all :D yah dynos differ and all but idk, they could have the same dyno type. u never know. lol or your right and theyre just lazy and copied :D
  3. Mar 26, 2010 at 6:40 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Engine size isn't what gives you the towing capacity.
    Chassis & axle strength are also a HUGE reason for towing capacity (amoung other things)
  4. Mar 26, 2010 at 7:40 AM
    08pretaco
    az
    no worries man. had a few drinks last night and felt like arguing hahah :D but yes that dyno is out our 2tr with an auto tranny. the manual will give you slightly larger output numbers.
    and as they might have the same dyno and blah blah i highly doubt all the high and low points would match up exactly perfect
  5. Mar 26, 2010 at 2:12 PM
    Barnone
    Barnone Guest
    Of course the other issue is stopping the load.
  6. Mar 28, 2010 at 2:51 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The 60 series Detroit refers to the size of the individual cykinder in cubic inches. In comes in various configuration. Most of the ones in a semi-tractor are V8s.
    The Porche 911 has a six cylinder engine. The 4 cylinder counterpart was the 912 which hasn't been around for about 30 years.
  7. Mar 29, 2010 at 6:24 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Everything matters in some way to tow capacity, concerning the mechanics. It's going to be limited by the weakest aspect, and i dont think the truck is week either.
    Simply , it would tow more if it had the v-6, but then the wheelbase and weight transer limit its capacity. I dont know for sure , but i'm assuming the brakes and axle are as strong as the v-6s ,x-fer case too.
    I think the 4 cyl engine is some sort of marvel , i dont expect it to get up a certain hill in 5th gear ,but it does. So far I'm getting my money's worth.:)
  8. Mar 29, 2010 at 8:06 PM
    4Barrel
    4Barrel Well-Known Member
    Buffalo, NY
    2004 SR5 TRD
    does the 2.4 have similar towing performance as the 2.7? i have a 2WD 2.4 and want to tow about 2,500#...
  9. Mar 30, 2010 at 6:04 AM
    Tacoyota
    08 4wd
    My guess is your 2.4L is around 2500 lb capacity, check the owners manual and other owners though.
  10. Mar 30, 2010 at 6:06 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    i can expect these same towing results with my 2001 2.7 correct?
  11. Mar 30, 2010 at 12:46 PM
    Barnone
    Barnone Guest
    My 2.4l is rated at 3500lbs according to the manual.
  12. Apr 10, 2010 at 1:32 PM
    95TacoSX
    95TacoSX Member
    Illinois
    1995 Tacoma SX Stock
    Is the 3,500lbs towing capacity the numbers for 4x4 or is it less?
  13. Feb 9, 2011 at 5:30 PM
    frog13
    frog13 Well-Known Member
    People always forget about how a machine is geared...alot of it has to do with the gearing!.
  14. Feb 9, 2011 at 5:58 PM
    Turp
    Turp Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless, 2022 4Runner Wheels
    3500lbs is about 1500lbs more than I need.
    Ouch......Greetings from the north (Danville). My Tacoma came from Rices
  15. Feb 9, 2011 at 8:23 PM
    #35
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Mine too...you work at station 1?
  16. Feb 10, 2011 at 4:44 AM
    #36
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    OEM tow rating capacity is all about the vehicle size, weight, and spring capacity, not so much the engine size.
    BTW: I can highly recommend U-haul for a hitch for the Taco. Had one on my '09, and it was very high quality. Looked like a relabeled Valley hitch. Installation was simple and clean. IIRC, it was $135.
  17. Feb 10, 2011 at 6:40 PM
    #37
    HomeGrown
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    Dhk! Great post, I fully agree. I'm driving a '93 S10 while waiting for my Taco to come in next month. I pulled a fully loaded U-haul 6x12 trailer about 250 miles. My s-dime has a V6 automatic, my previous '09 Taco was a 4 cyl. Although the S10 has more power than the Taco did, pulling the same trailer (fully loaded) the Tacoma felt much more capable and safe with the trailer than the S10 did.
  18. Feb 11, 2011 at 6:07 AM
    #38
    Turp
    Virginia
    02 PreRunner SR5
    They seem to be a decent dealer.
    No, Station 5. Though I did work at Sta 1 most of my career.
    I visit Greensboro quite a bit.
  19. Feb 11, 2011 at 6:23 AM
    #39
    Tasthree
    Tasthree Member
    Also keep in mind that a longer wheel base will make towing more stable. When I was figuring out which truck to buy to tow our fifth wheel years ago the RV industry had a standard for vehicle wheel base to trailer length and weight ratio. A 4x4 will reduce the towed weight capacity a little also. I went to rent a u-haul car hauler one time. I entered our truck as 4x4 with the towed vehicle and they wouldn't rent it to me. Entered our truck as 2x4 and was good to go. Don't know why. Weight of T-case,front end and xtra friction???
  20. Feb 11, 2011 at 8:45 AM
    #40
    Turp
    Virginia
    02 PreRunner SR5
    The connection point and vehicle weight distribution of Tractors and 5th wheels are very different than standard automobiles.
    Wheel base is a factor and 5th wheels and tractors place the "tongue" load forward of the rear axle which distributes the weight on the frame and axles better. The sportscar with a rearward positioned hitch didn't click with me and I agree with your point that a longer trailer handles well even though the car has a short wheelbase. My point is that load weights, load position, and contact points (wheelbase) are significant factors in towing and have a relationship with one another in the towing package. Been there and got some stupid stories I hope I don't repeat. Thankfully little or no damage occurred.
    Just my 2cents of trailer experience.
