2.7 liter towing capacity
Discussion in '4 Cylinder' started by dgjones, Mar 13, 2010.
  1. Mar 13, 2010 at 9:11 AM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Why can these small trucks tow so much? Is it because of the "straight" four cylinder engine design? I have a standard reg cab taco with the 2.7 and I pull a pretty large boat with it (3000 pounds) and it handles it pretty well, i was suprised.
  2. Mar 13, 2010 at 2:34 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I guess that the 180lbs of torque and the fact that you can hammer this engine without any concerm may help.
  3. Mar 13, 2010 at 4:55 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I believe they are rated at 3500 lbs.
    98_3RZ_NIC likes this.
  4. Mar 13, 2010 at 5:42 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    3500lbs is the max, 350lb tongue weight. Folks underestimate the towing compacity of these trucks all the time. You won't be speeding along the interstate at 75mph but it'll comfortably run 55-65mph all day long.
    A WWII deuce and half had a straight six that produced roughly 110hp and 200-250 lb-ft of torque. It blows me away how large the towing capacities and trucks have grown. For some reason we need bigger and better with no apparent end in sight.
    akkyle likes this.
  5. Mar 13, 2010 at 6:05 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    3500 lbs is the same as the Rav-4 w/towing pkg capacity....doesn't sound so great anymore does it.
    NCAmother and LocoLocal like this.
  6. Mar 13, 2010 at 7:09 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    isnt that the v6 tho?
    Taconmadres43 likes this.
  7. Mar 13, 2010 at 11:30 PM
    finnigan
    finnigan Member
    Calgary, Alberta, Canada
    2010 2.7L Access Cab 4x4 SR5 Manual
    yes. my 2008 v6 rav4 had 3500 lb towing. 4 banger rav4 is probably 1500 or something like that.
    Hp rating and tourque rating are the net rating nowadays which means power at the rear wheels. It used to be rated at the flywheel. So even though it has 159 hp and 180ft-lb tourque both numbers would be close-to or over 200 rated the old way. Also that power ratio (hp to tourque) is somewhat similar to a diesel engine which we all know is very good for towing. The tourque peaks nice and low too in the low 3000s of rpm
  8. Mar 13, 2010 at 11:34 PM
    john32
    john32 Well-Known Member
    Seaside, Ca
    4x4 Reg cab 2.7L SR5 Manual
    diff breather
    3500 is alot for a 4 banger. I have the 2.7 but dont do any towing at all. its good to know i can if i want to
  9. Mar 13, 2010 at 11:48 PM
    finnigan
    finnigan Member
    Maybe this will help too to put in perspective too. :) A detroit 60 series diesel is a 4 cylinder engine, you find these in a tractor trailer. And the porsche 911. You can do a lot of messing around with an engine even if it is 4 cylinder. Especially nowadays with computers. They get better all the time.
  10. Mar 14, 2010 at 6:58 AM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I drove fullsize V8 trucks for over ten years before buying the Tacoma. Yes, I miss the fullsize truck, but my 4 cylinder does the same job those V8's did at almost half the operating expense.
    I was concerned the 4 wouldn't be up to towing my boats, but it does just fine. Little slower getting up to speed, but will still run down the highway at 70 - 75mph pulling the boat.
  11. Mar 14, 2010 at 9:19 AM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    It is, but the mere fact that you can see a Rav-4 pulling the same as our trucks would be bad enough.
    The 4-cyl highlander has a 3500 rating also.
  12. Mar 14, 2010 at 9:42 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    How much does your biggest rig weigh? I'm pulling a pretty hefty boat, about 3000 pounds and I was suprised at how well the truck performed for a 4 cylinder!!
  13. Mar 14, 2010 at 6:56 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    umm no
    we only put around 120 hp down to the wheels 159 is flywheel hp...look at some dyno charts. (i think this is for the auto tho, the standard should have a bit more power at the wheels)
    Contact our Tech Support Line for further information at 928-855-6341.
    Check out www.LCEngineering.com for New Products, Tech Articles,
    Specials & Monthly Newsletters!
    Note: Images are for illustration purposes only. Images MAY NOT represent the product listed. Please contact Customer Service with any questions or concerns: 928-505-2501.
    PURCHASED BY OTHERS
    Exhaust System - 2.7(4cyl) & 4.0(V6) Tacoma(05-08)
    Exhaust Gasket - 2TR(2.7L 4cyl)(05-10) Tacoma
    Pro Flow Exhaust System - 2TR Tacoma (05-10)
    LCE Full Color Catalog
    K&N 77 Series/FIPK - Tacoma (05-10) 2.7L
    so my truck can pull just as much as a v6 rav4? thats fine with me.
    and besides towing capacity has alot to do with chassis, suspension and weight of the vehicle as well. 3500 lbs is quite a bit for a 3400 lbs truck.
  14. Mar 25, 2010 at 1:20 PM
    81shark
    81shark Well-Known Member
    interesting dyno....
  15. Mar 25, 2010 at 1:27 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    dont flame on me for not knowing :confused: but whats tounge weight?
  16. Mar 25, 2010 at 1:33 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    a detroit diesel 60 series engine is not a 4 cylinder engine... but yes, these engines do haul quite nicely :)
  17. Mar 25, 2010 at 2:55 PM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    A detroit series 60 is not a four cylinder engine. It is an inline six. The four cylinder version was called the series 50, and it was the series 60 minus two cylinders.
  18. Mar 25, 2010 at 3:00 PM
    Wolfman
    Paradise, TX
    2010 PreRunner SR5
    Tongue weight is the weight at the hitch. If it is too heavy, the added weight can cause trailer sway, poor handling, sagging at the rear, and in bad enough cases failure of components. Tongue weight should always be 10% of trailer total weight.
  19. Mar 25, 2010 at 3:08 PM
    Taco Guapo
    Taco Guapo Lurker
    Carefree AZ
    09 AC 4X4 2.7L
    Bone stock
    Inline engines typically have relatively high torque at low RPM. This is what makes them well suited for off-road use as well as towing. Peak HP at or near redline is useless for both applications.
  20. Mar 25, 2010 at 10:42 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    i thought it was the 40 series? or was it 50 too?:confused: i stay forget already, brah lol
