2.4L I4 to 3.4 v6 engine swap out question
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Dec 8, 2014.
  1. Dec 8, 2014 at 8:55 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    what all is involved if I wanted to swap my 2.4 4 banger for a v6 but wanted to keep my auto tranny?
    is it a simple pull out and drop in swap or would I need new motor mounts and a lot of other stuff too and if so what?
    I already realize I need all new exhaust system (I assume nothing can match up there)
    ps - nothing is wrong with the engine I have now, I just think a v6 would be better suited for towing
  2. Dec 9, 2014 at 2:26 PM
    keakar
    karl
    louisiana
    bump -- anyone ?????
    I have read two opposing views on this question,
    some say the wiring harness, exhaust, computer, and CC ecm is different so you need to buy a donor truck to swap everything
    then I have heard the truck doesn't know or care what engine it has and the v6 will just plug right in and you don't need a donor truck
    can anyone who knows about this say what is and isn't "reasonable" to do.
    would I be better served to buy a v6 truck and sell mine or do an engine swap with mine from a 4 to a v6?
  3. Dec 9, 2014 at 2:43 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I've never performed this swap but i'm positive the ecm, wiring harness, mounts and exhaust will need to be changed. A v6 radiator may be larger also. A donor truck would be your best bet if you decide to do the swap. I'm sure somebody here that has had expeirence with this swap will chime in.
  4. Dec 9, 2014 at 3:33 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    The transmissions might be different but like 68 said, a donor truck would be your best bet and you can just swap all the parts over. I'd think it would just be easier to find a V6 truck myself but that's just me. Good luck!
  5. Dec 9, 2014 at 7:19 PM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    I did this same swap on my 99. The easiest way to complete the swap is with a doner truck. Swap the entire wire harness, motor, transmission, ecu. The frame mounts for the motor are further back about 3/4". Radiator and shroud are different. Also the tach is different between the 4cyl & 6cyl. With all that a donor truck is the easiest route.
  6. Dec 9, 2014 at 7:36 PM
    keakar
    karl
    louisiana
    ok thanks guys, thats what I needed to know.
    this is more about research for "what if" because im thinking sometime in the next 5-10 years i was to make the truck "new" again and would need a new hood and tailgate (dents) for that as well as thinking of a bigger motor then my 2.4 and new paint job so i was wondering just how much donor stuff to look into for a project like that but it sounds as though its best to stick with whats in the truck and if i want a v6 its better to buy a v6 truck.
    trouble is its getting hard to find 2wd v6 first gens around here lol
  7. Dec 9, 2014 at 7:57 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Hey Mark, how big a pain in the ass was swapping the wiring harness?
  8. Dec 10, 2014 at 9:02 AM
    markmb45
    Mark
    Utah
    It's not too difficult. Be ready to remove the dash and steering column and glove box and knee panel. Remove instrument cluster, there are a couple of nuts behind it. Remove the screws around the heater controls. Then pull the dash out. There are about 5 clips on the dash that will like to stay in the body below the windshield, pull those out and reinsert them in the dash. Now the wiring harness can be pulled. I leave most of the relays and electrical boxes (ie 4wd computer, antenna relay etc.) connected just remove the mounting bolts. Pull fuse box with the harness. Several sub harnesses can be disconnected from the fuse box/ intergration relay. The main PITA is some of the harnesses runs into the engine compartment, just disconnect and feed into the cab. Then lay out the new harness and reinstall in reverse. One thing to note, some electrical connectors change between years of the same model truck.
  9. May 31, 2017 at 5:08 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Sorry to bring up this old thread, but there are very few threads with real info on this subject.
    If you can remember, would you mind telling me what you did in regards to the motor mounts being a little too far back? 3/4" doesn'tseem like much.
    Any info would be greatly appreciated!
  10. Jun 2, 2017 at 1:40 PM
    markmb45
    Mark
    Utah
    I used the 4Runner mounts and welded them in place. Your right about 3/4" back. I placed the motor and trans in place then tacked the mounts.
  11. Jun 2, 2017 at 2:35 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    @COMAtized99,
    @jacobrippey did this swap on his truck, it does involve removing and re-welding the motor mounts a bit father back. Here's his build thread.
    Having a donor truck will make your swap 100x easier. You can buy one on DashHub shipped to your door for around $3,000.
    jacobrippey and COMAtized99 like this.
  12. Jun 2, 2017 at 3:43 PM
    COMAtized99
    North Carolina
    99 DCLB v8
    I found his build thread, and have already talked to him.
    I don't have a specific donor vehicle, but I've got so many spare parts laying around that I've basically got a donor.
    This will be my 4th motor swap. Other than the motor mounts, it should be pretty simple.
  13. Jun 2, 2017 at 4:48 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    Eventually, I will build a comprehensive thread on how to 3.4 swap tacos. Good luck with your swap brother!
    COMAtized99 likes this.
