2.4L 2RZ injector installation a tip and question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ControlCar, Nov 29, 2023.
  1. Nov 29, 2023 at 6:37 PM
    ControlCar
    ControlCar [OP] My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    YO
    Half way point!
    Tip:
    I didn’t have to remove TB
    If u disconnect all harness pigtails, you can set back harness
    Question:
    Confused about the lower o-ring that seats into head.
    Mine are definitely different and as brittle as glass
    Also the ports into the head are
    Freakin full of sand
    The brittle ones look more like a grommet
    The one on the injectors more of a thick o-ring
    here some pix
  2. Nov 29, 2023 at 6:39 PM
    ControlCar
    Steven
    Sugar Land TX
  3. Nov 29, 2023 at 6:40 PM
    ControlCar
    Steven
    Sugar Land TX
  4. Nov 29, 2023 at 6:43 PM
    ControlCar
    Steven
    Sugar Land TX
    Lmk what you guys/gals think
    chisel out those brittle head grommets, clean install new injectors?
    Or
    Do I need different lwr o-ring/head grommet part(s)
    Cheers
  5. Nov 29, 2023 at 6:53 PM
    ControlCar
    Steven
    Sugar Land TX
    looks like these are what I got with injectors
    But do not see that old lwr head mounted ‘insulator’ anywhere
    Only that large brittle grommet
  6. Nov 29, 2023 at 7:03 PM
    ControlCar
    Steven
    Sugar Land TX
  7. Nov 29, 2023 at 7:12 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    When I replaced my injectors I didn't take the plastic seal that goes into the head out. But looks like those gotta be replaced now. Chisel out, install new plastic cups then put injectors in as they are. That extra rubber on the bottom is fine, my new ones came just like that and they work great. Make sure to put a little lube on the rubber pieces.
  8. Nov 29, 2023 at 7:42 PM
    ControlCar
    Steven
    Sugar Land TX
    A firm^^^
    I took a shop vac to the I ports
    I can see the injector insulators and removed them
    those head inserts
    I didn’t ‘Hulk It’ on them but did crack the lip
    Unknown if there is part# or even available
    Will check in am
    After I clean up/put away tools
    MadNachos likes this.
  9. Nov 29, 2023 at 9:35 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Murd3rd likes this.
  10. Nov 29, 2023 at 9:41 PM
    O'Silver_Taco
    MD
    ...The brown ones on the right are oem from motorwest for pre 2000....
    and are not densos....that was before denso was used in the factory
    the pinkys are denso .....2000 they switched to denso made ones ...at the factory...
    The blue one in the middle is a generic one from someone in Washington state...trying to match the original oem matsushita brown ones..
  11. Nov 29, 2023 at 9:57 PM
    O'Silver_Taco
    MD
    This is the japan oem supplier that made the oem injector before they switched to denso's ...pre 2000
    matushita ?matsushita
    TheWildMan likes this.
  12. Nov 29, 2023 at 10:18 PM
    O'Silver_Taco
    MD
    TheWildMan, THatt and ControlCar[OP] like this.
  13. Nov 29, 2023 at 10:26 PM
    O'Silver_Taco
    MD
    IN that thread or some other......someone had a vac leak they could not find...
    turns out it was a cracked cup....engine run like sheet...go figure...
  14. Nov 29, 2023 at 10:29 PM
    O'Silver_Taco
    MD
    Wish I was half as smart as some of these monkeys....
  15. Nov 29, 2023 at 11:02 PM
    O'Silver_Taco
    MD
    This diagram is wacked....5vz's DONT USE CUPS....
    only 2rz and 3rz.........I was also corrected about this in the recent past...
    in that diagram.....they call those cups....'insulators'....
    I assume...so they dont want em to ground out to the head....
    the ground must be provided by the a ground on the harness...
    ......or the ecm switches the injector on/off by switching on/off the ground path...
    just like the starter circuit...dont know.....
    that makes sense.....that might avoid DC arcing over millions of cycles...
    ON RC stuff that use HV 12s lipo packs .....that;s how to avoid arcing...
    by switching on the back side of the load....the load(injector) acts as a capacitor ...
    so you dont fry the logic switch transistor inside the ecm...
    so does that mean the injectors....are always hot.....waiting for an ecm ground....
    In an electrical circuit....the electrons actually travel in a reverse path...then what you think...
    what a mind F##k....
  16. Nov 29, 2023 at 11:24 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Toyota started using the pink tops in the 2RZ when they switched to Coil-On-Plug with the mid-year change over in 2000. Which I believe were the Cali-Spec versions.
    Bigd83 likes this.
  17. Nov 29, 2023 at 11:31 PM
    O'Silver_Taco
    MD
  18. Nov 30, 2023 at 12:46 PM
    ControlCar
    Steven
    Sugar Land TX
    Thanks OS for info/links!
    I think cups are ok
    But
    That vacuum leak potential, isn’t something I want to diagnose/track down/raise my blood pressure…..in the future….taking y’all’s advice and buying cups
    Bc shipping same for both(freaking $16)
    I splurged, got cups AND that $70 FP gauge you posted (in another thread) last week.
    Guess will be my Xmas gift to myself….meh
    modifying a 3/4 bolt with dremmel as we speak to remove….if stops raining today.
    (Doubtful)
  19. Nov 30, 2023 at 12:51 PM
    ControlCar
    Steven
    Sugar Land TX
    IMG_3705.jpg IMG_3704.jpg As far as injectors
    They are AM
    They are exactly the same…..down to small #’s stamped in a raised platform on the injector
  20. Nov 30, 2023 at 1:11 PM
    ControlCar
    Steven
    Sugar Land TX
    Now, I’m going to go out on a limb here re: AM vs. OE
    I’m not stating that I’m (AM) is right or OE guy is wrong
    I’m just stating my case/decision making
    firstly, I would not being stating this if this part was from a late model vehicle (let’s say 2019 thru 2023)
    -we got a 27yr old part design here
    Undoubtedly, perfected by AM companies over the years
    -an OE injector on Toyota website(looks same as above pix^^^) is $172
    Adding tax, lets say $800 for four
    This AM set was $60
    I could buy 52 injectors as opposed to 4
    Will cheapies last as long?
    Probably not. But that’s my labor/time.
    Pretty easy decision IMO
    kinda like buying a water pump for an old Chevy 350…..GM doesn’t make those pumps anymore, they have a AM vendor produce, then stamp it with logo and mark the part up.
    Again, newer vehicles my reasoning wouldn’t apply
    ouch……I can feel the OE hate coming!
