2.4 to 3.4 swap integration relay wiring help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Str8 front toy, Apr 17, 2019.
  1. Apr 17, 2019 at 7:02 PM
    Str8 front toy
    Str8 front toy [OP] Member
    Justin
    Hawaii Hilo
    2017 TACOMA Trd Sport
    Pro Comp 6 in lift King Suspension Dirtking UCA
    Ive searched google, forums, fsm, but i cant seem to get a good picture of the wiring behind the integration relay. While pulling the harness from the donor vehicle thing got cut bad and im trying to put it back together but cant figure the route of the wires. I for cant read wiring diagrams because its confusing as hell. This is what im trying to put together:
  2. Apr 17, 2019 at 7:03 PM
    Str8 front toy
    Justin
    Hawaii Hilo
    Any help would be appreciated, ive been searching for the past weeks before asking for help
  3. Apr 18, 2019 at 12:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Sorry if you can`t read schematics your kinda up the creek.
    You might wait a very long time till some one is doing the very same thing as you .
    Meaning everything needs to be the same.
    Not sure why your changing all that every thing can be merged at the ECM.
    Now if everything is out of the same year truck it is not as bad
  4. Apr 18, 2019 at 1:24 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Why are you changing all that part of the harness?
    Wyoming09 and BartMaster1234 like this.
  5. Apr 18, 2019 at 8:20 AM
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    Oh man wiring everyones worst nightmare. lol
    Im confused why are you changing the wiring because I've done 2.7 swaps to 3.4 truck and vice versa and I never had to take or modify the harness under the dash dash or foot boards. as long as the engine has its engine harness and ECU and the some what the same year its just plug and play
  6. Apr 18, 2019 at 1:03 PM
    Glamisman
    Glamisman Well-Known Member
    I have reserached this in the past... the inetrnal pathways inside the integration relay are all differernt as well as where the wires on the various connectors are pinned.
  7. Apr 20, 2019 at 11:56 PM
    Str8 front toy
    Justin
    Hawaii Hilo
    Im more than up the creek, i live on a rock in the middle of the pacific. Im not changing anything. Im trying to put it back together because while pulling the motor the dash harness got accidentally cut with a reciprocating saw. So i was hoping someone could snap a pick under there dash behind the integration relay so i have a rough idea of which wires goes up into to cowl wires. Toyotahunter I dont think i can use my 2.7 dash harness with 3.4 computer, plus i was shooting for ac, criuse control, e locker
  8. Apr 21, 2019 at 12:01 AM
    Str8 front toy
    Justin
    Hawaii Hilo
    Im using this from the fsm but it doesnt have anything about the plugs and where they go from behind the integration relay
  9. Apr 21, 2019 at 12:11 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    How the heck do you cut the DASH harness when pulling the motor???
    Edit: I see what you mean. It’s a body harness btw, and you don’t need it for the swap. You need the motor, the engine main room harness and ECU. You still need to learn to read the diagrams though because the connectors from the body that plug into the ECU will most likely need to be re-pinned some even though they may plug in
  10. Jun 17, 2019 at 12:23 AM
    Str8 front toy
    Justin
    Hawaii Hilo
    Thank you, i had to figure out the diagrams. Finally got it. Just one more question about the ac...
