2.4 electric fan conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tresguey, May 11, 2022.
  1. May 11, 2022 at 9:55 AM
    Tresguey
    Tresguey [OP] Member
    2004 Tacoma
    I did a search of increasing MPG's with a 1 gen Tacoma 2.4l, didn't come up with much, I did see a very amusing thread about removing the fan shroud.
    I drive 140 miles a day round trip to and from work in SoCal. I plan on doing an experiment with an electric fan conversion. I will upgrade my alternator first. I plan to run both a brushed then a brushless fan during the experiment. I also plan on running the experiment with regular unleaded and super unleaded fuel.
    Unless someone has already done this, I think it would be good information to play with.
  2. May 11, 2022 at 12:11 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    A waste of time and money!!
    You would need very precise measurements to calculate if any mileage increase
    For less cooling then the stock set up.
    About the only time a electric fan is useful is with a swap where the factory fan will just not fit in the engine compartment
    How do you plan to control the fan??
    When it quits and leaves you sit ?
    I have removed so many electric fans and returned to stock in the last 20 years. Most had failed and cooked the engine or caused a head gasket failure
    Good luck in any case.
    MadNachos, treyus30 and Key-Rei like this.
  3. May 11, 2022 at 1:54 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Salvage yards are full of two kinds of vehicles, wrecks and cooling system failures........
    Key-Rei likes this.
  4. May 11, 2022 at 2:01 PM
    Tresguey
    2004 Tacoma
    I have access to OE brushless fans and after market high performance electric fans. The OE brushless fan has a built in sensor and PWM control. the performance aftermarket fan will be controlled by an after market PWM fan control. The cost will be nothing out of pocket, just my time.
    Less cooling...hmmn, you make a good point, I can also test the stock fans CFM at the static pressure the stock radiator creates and compare that to both electric fans.
    I am a gauge watcher, and have AAA. I am not worried about a failure.
    I have a good friend that has a dyno, I can also do a few dyno runs to see if there is a noticeable difference pulling the fan clutch and fan.
  5. May 11, 2022 at 2:06 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Supposedly the belt driven fan is more efficient as air flowing through the radiator at highway speeds will turn the fan reducing drag on the accessories belt, upgrading the alternator will increase drag on the belt.
    Bivouac and treyus30 like this.
  6. May 11, 2022 at 2:07 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Electric fans suck.
    MadNachos and Bivouac like this.
  7. Aug 31, 2022 at 11:49 AM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Any update on this experiment? Curious if OP went through with any of it.
    Any idea what kind of CFM the OEM clutch fan puts out?
  8. Aug 31, 2022 at 12:01 PM
    Bivouac
    I am sure if I looked I could find the equations so you could do your own math .
    To much like work for me.
    The stock set up works the best.
  9. Aug 31, 2022 at 12:05 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I did an electric fan conversion on my old 20R Truck back in the 90's and it worked great. I did it because it was less expensive than buying a new fan clutch. I kept the stock shroud on too and it provided adequate cooling.
    hfjeff likes this.
  10. Aug 31, 2022 at 12:05 PM
    betterbuckleup
    Ian
    Concord, CA
    I'm sure I could too, just lazy and wanted to see if anyone had already figured it out :D
    Bivouac[QUOTED] likes this.
  11. Sep 3, 2022 at 3:18 PM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    For 280,000 miles of my tacos 313,000life was with a single 16” electric fan with a flex a lite digital fan controller. Towed cross country many times, sat in traffic in northern New Jersey 100’s of times. Never had an issue still have to fan in there to this day tho I will be parting the truck once I get enough posts to sell things here. I wired In a led to know when the fan was on and have never had an issue or an overheat. Toyotas cooling systems are way over engineered and take it from me not one issue other then the controller firing once due to age. I was consistently getting 20-23 mpg and no loud fan on startup.
    gusto11071 and betterbuckleup like this.
  12. Sep 3, 2022 at 3:18 PM
    Duke_962
    Nwnj
    Also mine is a v6 5 speed 4x4 that still found the woods with no issues
  13. Sep 3, 2022 at 6:31 PM
    betterbuckleup
    Ian
    Concord, CA
    Good to hear. Did you make your own shroud for it? Or run without one?
  14. Sep 3, 2022 at 8:18 PM
    Duke_962
    Nwnj
    Ran a flex a lite fan and shroud unit with a flex a lite vsc controller. Originally had a dual fan setup on an angle but found the single worked fine when one of the two fans died and couldn’t replace the single fan. I forget the actual size of the fan but want to say it was 16-18” and never had an issue. My truck was also super charged for 120,000 miles. So I put it through its paces and never overheated. The vsc controllers are nice. They turn on low and ramp up the hotter the rad gets. Nice because it take the shock load off the charging system. No dimming lights and had an input for a/c if you still have it.
  15. Sep 3, 2022 at 8:46 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Which VsC? I have a ling controller but didn’t have an A/C input and debating on tossing a different controller in when I get around to it.
  16. Sep 3, 2022 at 8:55 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Don't most new vehicles have electric fans? Why do you suppose that is?
  17. Sep 3, 2022 at 9:00 PM
    nudavinci64
    Robert
    moar new vehicles def have less space in engine bays. Which is at least one likely reason.
  18. Sep 4, 2022 at 5:07 AM
    gusto11071
    gusto11071 Well-Known Member
    Juan E.
    Brewster, NY
    2003 Tacoma Ext Cab DLX 2.7L 4X4
    Rear FJ Cruiser Disc Brakes, Front Tundra Brakes, Heated 4Runner Mirrors, 2018 Tacoma OEM 18" Wheels
    My 2 cents: I personally know that a electric fan puts less drain on the motor, I would for sure UPGRADE the alternator as well. Just have to make sure that it can cool the engine when the AC is on and under towing conditions as well. It does save you on gas in the long run. Now, on the horse power scale, I think any less load on the motor is a PLUS on the HP, now how much more you will have to figure that one out, Good Luck !
  19. Sep 4, 2022 at 5:27 AM
    Duke_962
    Nwnj
    123195 From flex a lite. Surf around for the best price. You don’t have to upgrade the alternator. My factory one made it 280k before it gave up. Most new trucks come with electric back up fans but when you get into 1500 and up trucks belt fans are still needed when heavy towing. I towed with this little fan and never had an issue. My new tundra uses a belt fan with electronic coupler which is best of both worlds. When not need it completely free wheels and then the ecm can command it on to the level it needs.
  20. Sep 4, 2022 at 5:51 AM
    gusto11071
    Juan E.
    Brewster, NY
    This is the one I am installing on my 2.7L
    It’s about 19” round
    beez likes this.
