2” Lift - Please steer a guy right
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chicken_Taco, Oct 7, 2023.
  1. Oct 7, 2023 at 9:06 PM
    Chicken_Taco
    Chicken_Taco [OP] Well-Known Member
    Comfortably numb on the Darkside of the moon
    2019 Midnight Black Tacoma TRD Sport
    Working on it ...
    I’m hoping you all who have way, way more knowledge in this area than I do can sort of help me along here. I’ve been wanting to do a lift on my 2019 TRD Sport for sometime. Now that I have just rolled 64,000 miles on the truck I have some change saved up and need tires, thought this would be a good time to do a wheel/tire/Lift on the truck. This is my fourth Toyota truck but the only one I’ve actually seriously thought about doing a lift on.
    So thing is, I know nothing about this. I need you all talk to me like I was a five-year-old. I would like to put 285/70/17 tires on the truck. Would a 2 inch lift be enough? If yes, how would I get there?
    To start I was thinking about swapping out, shocks and putting Bilsten 5100s in the rear and 6112 upfront. What else should I be looking at in order to get these tires under my truck?
    Thank you in advance for all of you who take the time out to help out and get me on the right path.
  2. Oct 7, 2023 at 9:26 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    If I were to do it all over again I would do a much more minimal front lift 1-1.5" up front with a matching rear lift to maintain some rake.
    Then just properly clearence the front fender well with a cab mount chop and pinchweld fold.
    Doing it this way you maintain better cv angles saving your boots lowering the odds of phantom vibrations throughout the drive train.
    I ran 285's with a 2-2.5" front lift depending on how much weight was on the roof at the time. No chop on +1 wheels for a year with no issues but alignment is key if you have any intention on wheeling the truck at all.
    A 5100 or 6112 are great options just remember to include a leaf pack or add a leaf to bring up the rear aswell. A block is a fair option for a truck that is mainly street use.
    Plan on a front diff clamshell bushing somewhere down the line as that needle bearing does not like the strain from a lift.
    Wheel offset, staying around a +15-0 will make fitting the wider tires much easier any further into a negetive and you will start to find more rub points.
    Expect your economy to tank I would suggest a tune around the same time or shortly after I wish i did mine far earlier.
  3. Oct 8, 2023 at 5:38 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm more than content with my 2" 5100 lift, and 1" rear block. No regrats...
    But I will never, never go 285. Matter of fact, I'm going from my upsized 265s to an even taller 33" 255 soon.
    71tattooguy and RushT like this.
  4. Oct 8, 2023 at 6:26 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Steering you right would be new front coilovers, rear shocks and leafpack.
    Adjustable UCA's if you can swing it and swap the needle bearing with the ECGS clamshell bushing, while you're already in there.
    On a 2019 you might want to start hitting those camber bolts with PB Blaster now. ;)
    TacoManOne likes this.
  5. Oct 8, 2023 at 8:22 AM
    Veet-88
    I always forget to mention the damn cam bolts mine had to cut out and new LCA's and bolts installed.
  6. Oct 8, 2023 at 9:55 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Stick with 0 to +4 offset for your new wheels & go with 'pizza cutters' (255/80/17 - tall and skinny, vs fat) will let you put them on the truck with the least amount of effort.
    If you stick with 285/70/17, they will be fatter and will more than likely rub. You can do some trimming and possible CMC (cab mount chop) to clear that up.
    Bilstein 5100s all around or 6112s like you said are great. If you stay at 2", you can probably get away with stock UCAs, but aftermarket ones never hurt. For the rear, an AAL will suffice unless you want to drop money on a leaf pack.
    Here's my 'budget' parts list suggestion:
    JBA UCAs
    5100s with OME 887 coils or equivalent 6112 setup
    HeadStrong AAL in the rear with 5100s or 5160s
    0 to +4 offset wheels
    255/80 (or75)/17 tires
  7. Oct 8, 2023 at 10:11 AM
    USPfan
    USPfan Well-Known Member
    North of 60th paralell
    2018 Tacoma TRD OR DCSB
  8. Oct 8, 2023 at 10:46 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  9. Oct 8, 2023 at 11:45 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This is what I did ,no vibes or problems and zip ended up with 3 inches of lift with the tall tires.
    Tocamo[QUOTED] likes this.
  10. Oct 8, 2023 at 2:05 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why do you need a lift?
  11. Oct 8, 2023 at 7:30 PM
    Chicken_Taco
    Working on it ...
    That is a great question. I was thinking lift in order to get some bigger tires on it. The wheel that I’m going with is the 4Runner TRD pro
    17-in. x 7-in. cast aluminum wheel
    ·11-mm. with 4-mm. wheel offset widens the overall vehicle track width by 0.9-in. (22 mm.)
    MonkeyChief likes this.
  12. Oct 8, 2023 at 7:31 PM
    Veet-88
    That wheel is a great candidate for skinnies
  13. Oct 8, 2023 at 7:37 PM
    RIX TUX
    why bigger tires?
  14. Oct 8, 2023 at 7:42 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Lift doesn’t clear bigger tires unless you won’t be using your suspension afterwards.
  15. Oct 9, 2023 at 9:37 AM
    Acwood
    Acwood Well-Known Member
    Alex
    Atlanta, GA
    2023 TRD Sport 4x4
    Bilstein 5100 2/1 level, diode dynamics SS3 sport fogs, form taillights, interior chrome delete and LED interior
    I’ve read from a member here that with a 2” lift on the Tacoma and those 17x7 +4 offset wheels with 275/70R17’s with NO RUBBING. I’ve got the bilstein 5100’s set on the top notch (2” in front and a 1” block in back.) I’m going to get the 17x7 +4 SEMA wheels, just can’t decide to go bronze or black.
  16. Oct 9, 2023 at 10:00 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Put some 255/80/17s on those wheels and run that for a while to see if the look fits what you want. The truck will sit about 1.5” higher off the ground with the larger tires alone.
    Blaze Creek likes this.
  17. Oct 9, 2023 at 10:06 AM
    Blaze Creek
    Blaze Creek Well-Known Member
    2012 Tacoma trd sport
    Great suggestion. This works well for those looking for a lift without adding blocks or leaf springs.
  18. Oct 9, 2023 at 2:49 PM
    Chicken_Taco
    Working on it ...
    So, if I went with these tires:
    Falken Wildpeak A/T3W - LT255/80R17 E 118S
    I would be able to get them on these wheels (4Runner Pro wheel) with NO (I.E. stock) lift?:
    If that is indeed the case, then dang, I’m in. I think I’ll be OK driving on pavement (truck is my daily driver too) sacrificing the .4 of an inch in width.
  19. Oct 9, 2023 at 2:54 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    That is correct. You’ll need an alignment and might need to trim some plastics but that’s it.
  20. Oct 9, 2023 at 2:56 PM
    pastoreater
    pastoreater doesn't know
    M
    5g 4runner
    :spy:
    255/80r17 allegedly will not clear metal parts on a stock 4runner . . . can anyone confirm that? I would like to be able to bottom out and not womp my fender.
