1st generation Tacoma door will not unlock- *SOLVED*
Discussion in '1st Gen. Tacomas (1995-2004)' started by Markcal, Jan 9, 2017.
  1. Jan 9, 2017 at 2:05 PM
    Markcal
    Markcal [OP] Well-Known Member
    Kirt Adams, GweboC, 5280 and 21 others like this.
  2. Jan 9, 2017 at 2:13 PM
    Markcal
    @tcBob- I offered this video to someone having a door that wouldn't unlock, thought it was a great find and should be stickied, so I made a thread and will leave it to your discretion.
    jvswaim and tcBob like this.
  3. Jan 10, 2017 at 4:27 PM
    Slickster
    Slickster greentaco
    2002 pre
    great vid @Markcal
    been having the same issue with my taco now i can fix it!
    thanks.
  4. Jan 10, 2017 at 11:13 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    A sticky :bananadance::thumbsup:
    Great video.
  5. Mar 9, 2017 at 6:39 AM
    Taco_4x4_Guy_
    Taco_4x4_Guy_ Member
    USA
    2017 Toyota Tacoma DC TRD Off Road Premium
    3" Toytech Lift, Toyota Billstein Shocks, TRD Pro Grill, 18" Fuel Rims with 285 65 R18 Cooper Discovery SST Tires.
    Mine is starting to stick. I don't think its the spring I think the actual locking mechanism. I have to spray a little WD-40 in there once every few months to get it to unlock.
  6. Mar 16, 2017 at 9:32 PM
    butsack
    butsack Well-Known Member
    SW WA
    1997 Reg cab 3rz auto
    aftermarket cassette player
    i have to hold the key open in the lock and pull the handle at the same time.
    the 20 year old ignition is my concern :fingerscrossed:
    Lukass likes this.
  7. Mar 17, 2017 at 12:46 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I think the door lock spring broke as mentioned in video will cause, what you're experiencing.
    Keep your key rings a light as possible. Saves on wearing of key tumbler
  8. Mar 17, 2017 at 11:11 PM
    OldBoysToys
    OldBoysToys Active Member
    Jim
    1997 Black extracab tacoma - 2002 Imperila jade extracab TRD Tacoma
    Bilstien shocks toy tec lift Brush guard / Helwig 1250 Helpers
    try some thing with a light lube WD 40 will wash away any lube ,maybe a gun oil spray or dry lube ~~OBT~~
  9. Mar 18, 2017 at 12:23 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Graphite lock spray works good to.
    1kdrye, SilverBulletII and Dalandser like this.
  10. Mar 18, 2017 at 1:07 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I like that stuff too, except on of my door locks is "squishy" going in the lock direction. Luckily unlocking it is trouble free and that's the important one, but it seems that it's more sticky after using the spray. Real solution as usual is probably take it apart and see what's going on - may likely have nothing to do with the spray. I'll continue to keep using it since it really has made locks easier to turn in every other application I've used it in so far.
  11. Mar 24, 2017 at 6:56 AM
    glenn27
    glenn27 Well-Known Member
    Central Virginia
    2002 Toyota Tacoma SR5 TRD package/Xtend cab
    I just watched the video twice--and other than seeing the broken spring--I pretty much understand.--and Thanks to the O/Poster!
    Mine won't 'release' for want of a better word=--when I pull up on the outside handle, unless I really 'jerk' the door. Looks like the whole latch/lock is all one assembly is one piece.
    Guess I'll have to pull my door panel apart--just didn't want to take a chance on breaking those little plastic push clips and I know that's going to happen.:fingerscrossed::fingerscrossed:
    Like to find one in a junk yard first and pull it apart--so I could see inside.
    just my ramblin'
    glenn
  12. Mar 25, 2017 at 6:18 AM
    glenn27
    Central Virginia
    Following up on my success--or lack of..I pulled mine apart yesterday afternoon. ('02 Tacoma) Mine is a little different than the video, but same overall operation. I have no return spring--mine has power door locks/windows--so the little electric motor is built into the latch assembly (duh-:annoyed::annoyed::annoyed:)mine--the little 'slide linkages' are just flat worn out--it seems. There are eblongated slide channels that this pin rides in--I can see they is much 'travel' before it activates or pulls the little latch up. The slide is worn more than normal and sloppy. Ok--went by the Toyota dealer yesterday, got them to print me off a diagram/breakdown of the inner door workings, so I knew what was what.
    Asked about price/availability--"Oh, about $325 or so"--I almost fell out. Tried several junkyards in the area--no Tacoma's anywhere--but I still see a lot of the on the street--so folks much still be buzzing around in them....Right now--I just stuck the inner panel back in place, until I can decide what to do about it...
    **.Just spent $400 on motor work--the truck is 15 years old, but in otherwise, VGC--I have a feeling it is just going to start nickel/diming me to death...Luckily--I'm retired and have other vehicles, but this is my main hauler....
    ***Anyone have one of these door-latch assemblies (drivers side) stuck away they'd want to sell?++
    Thanks for listening to my tale of woe....
    glenn
  13. Mar 25, 2017 at 6:25 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Crickits...........................
  14. Mar 25, 2017 at 8:35 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can probably look for a complete door assembly at a junkyard or on Craigslist and sell the parts you don't use to keep the cost low. Can the tumbler be separated from the electronic actuator so you can use your original key?
  15. Mar 25, 2017 at 9:09 AM
    glenn27
    Central Virginia
    Just tried to post a WTB thingie in the classifieds--realized I couldn't unless 50-post count...
    Oh, well....
    glenn
  16. Mar 25, 2017 at 9:11 AM
    glenn27
    Central Virginia
    It is a separate part already--part of the outside door handle....No luck on local junk yards--I checked yesterday. C/L dead end also-
  17. Mar 25, 2017 at 2:49 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bummer. CL's always got a couple doors around here. I was at a dismantled today that quoted me $200-$350 for whole doors.
  18. Mar 26, 2017 at 5:13 AM
    glenn27
    Central Virginia
    I'm still searching, but no luck so far--right now I just temporarily 'hung' the inner door panel back up w/ some tape so I could drive it....
    Had another thought yesterday morn--I work P/T for a national auto parts store--called my boss and he started researching it--seems like an aftermarket company (Dorman) makes a lot of accessory parts like this--see what he can find out...
    He'll let me know something Monday--
    Feel like I'm on this--:turtleride::turtleride:
    glenn
  19. Mar 29, 2017 at 4:28 AM
    glenn27
    Central Virginia
    Did A lot of research, and was finally able to decipher that Dorman does makes the left -hand side door latch/electric activator. one-direct OEM replacement, but not without some hassle-(websites won't reference each other, or just dies out)-but that's ok...
    .Ordered one yesterday thru my little P/T job (Federated Auto Parts)-and will see how it looks/works out.
    At 1/2 price from Toyota, I can deal with that a lOOOOOOOOOOOOOOOOOOt better.......
    glenn
    lucky13don likes this.
  20. Apr 1, 2017 at 7:47 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    If it doesn't work out, there's recyclers in rancho Cordova cali.they go by make and have parts that local places dont.might be worth some Google time.but the shipping might suck.
