1st generation (2003 ) hub/spindle assembly ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by awkdeere, Dec 20, 2020.
  1. Dec 20, 2020 at 2:25 AM
    awkdeere
    awkdeere [OP] Member
    Tony
    2003 Tacoma Prerunner
    None
    It took me awhile to figure this out, but now I fully understand. On the 2nd and 3rd generation Tacomas, you can replace front wheel bearing assemblies via unbolting & replacing hub/spindle because there are many makers of these units on-line. Bit for the 1st generation Tacoma, ... there are none out there. I wonder why, because they too can be unbolted and removed ?
  2. Dec 20, 2020 at 2:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The first Generation bearings need to be pressed out of the steering knuckle some do this on the truck others remove the knuckle and have the bearings replaced by someone with a press.
    If you have no clue what your doing quite easy to mess things all up
    Taco critter and Black DOG Lila like this.
  3. Dec 20, 2020 at 11:40 AM
    bowhunter13
    bowhunter13 Well-Known Member
    2002 silver Tacoma
    2002- Toytec Lift/Suspension, Total Chaos UCA
    I did mine after I broke one of my steering knuckles figured if I had 1 side torn apart and new I might was well do the other side. Well me being a genius I am I tried to Press out the bearings which worked but I forgot about the snap ring in there so I also broke the 1 good steering knuckle I had (an extra $450.00 screw up). Its defiantly not hard to do just don't get in a hurry and look it over good.
