1st Gen Twin Stick Options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ZomBaja, Nov 25, 2015.
  1. Nov 25, 2015 at 1:23 PM
    ZomBaja
    ZomBaja [OP] Well-Known Member
    Dustin
    Central MS
    2002 Doublecab TRD Prerunner
    So, getting ready to convert my truck to 4wd.
    2002, V6, auto, 2wd.
    Also, I will be building the 4x4 system using manual parts from earlier tacomas. Not the ADD that came in this year truck.
    But, while I have everything ripped apart, and while I'm collecting all the parts, I'd like to go ahead and do a twin stick set up IF possible.
    I haven't been able to find much, if any, info regarding this.
    Typical concerns are, will the twin stick work with auto, or will I need to 5 speed swap?
    Can I use the stock T-case?
    And so on.
    If anyone has any information, it would be greatly appreciated!
  2. Nov 25, 2015 at 2:44 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Member @ToyRyd04 did a 4x4 conversion with twin sticks. Aand then did a sick ass SAS!! Check it out
  3. Nov 25, 2015 at 2:52 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    For what it's worth I suggest using Add parts. Add have stronger hubs than CVs manual hubs break before the CV. One of my idiot friends tried 37s on his with manual hubs interestingly enough he blew the hub , cv, and his spider gears in one shot.
  4. Nov 25, 2015 at 4:26 PM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    @TIPICOTACO , thanks for the bump.
    As for twin stick OP, you can twin stick a tacoma chain case. FrontRangeOffroad fab makes a twin stick setup, all you have todo is split the case and do a little grinding on the shift forks.
  5. Nov 25, 2015 at 4:52 PM
    ZomBaja
    Dustin
    Central MS
    @ToyRyd04 I couldn't find your build.
    And thanks for the info guys. I've seen some twin sticks out there but they say "won't work with stock v6 chain driven t case"
    Gonna check low rang again!
  6. Nov 25, 2015 at 4:58 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
  7. Nov 25, 2015 at 5:10 PM
    ZomBaja
    Dustin
    Central MS
    Wow, didn't even catch that lol.
    Thanks guys. Hopefully I'll be able to get it all sorted out now
