1st gen TRD Supercharger - 100% rebuilt
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by anothernord, Nov 12, 2015.
  1. Nov 12, 2015 at 10:51 AM
    anothernord
    anothernord [OP] Well-Known Member
    Northern Colorado
    Various Toyotas
    DCLB Manual
    SOLD
    Comes with everything needed for install except a few gaskets and a check valve - see below
    The rebuild parts have only a handful of miles on them - I just installed the blower on my truck to make sure everything was good. I took care to make sure everything was done right using the right tools.
    - New Jon Bond Performance PTFE lip seals - properly installed
    - New made in Japan Nachi rotor bearings
    - New made in Japan Nachi snout bearings, low mileage (2k) coupler
    - New rear needle bearings
    - New SKF shaft seal
    - Super-handy 1/4" NPT filler hole tapped into the housing (you don't have to pull the charger to change the oil
    - Refinished with Rustoleum hammered (looks nice under the hood)
    - Low mileage idler pulley ~3k
    - Low mileage belt ~3k
    - Nearly-new actuator (installed ~2k ago)
    - Tensioner plate/bolts
    - Throttle body bolts*
    - TB cable bracket/screws
    - Correct-length PCV hose/clamp
    - Fresh oil, drained to double check for any issues after rebuild and refilled with 120ml of brand new AcDelco oil.
    You'll need the following parts to finish the install:
    -TRD throttle body gasket $15 (I can throw in a used one if you want)
    -Intake manifold gasket (or reuse your stock ones)
    -Check valve (I stole one from a brake booster hose I had laying around)
    *One of the throttle body bolts stripped on me so before I ship, I'll install a helicoil it'll be as good as new
    Price: $2100 shipped in the lower 48. I'd be keen to sell locally so PayPal doesn't eat everyone's money.
    TylerTron and Dcsleeper408 like this.
  2. Nov 13, 2015 at 6:44 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    What is your location?
  3. Nov 13, 2015 at 9:06 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Heh, just saw this on CL... 5 miles from me!. Sadly I'm not in the market for a second s/c. GLWS!
  4. Nov 13, 2015 at 2:50 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
  5. Nov 15, 2015 at 7:26 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
  6. Nov 16, 2015 at 8:05 AM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Northern Colorado, Fort Collins area
  7. Nov 20, 2015 at 8:36 AM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
  8. Nov 24, 2015 at 11:23 AM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    $2200 shipped in the lower 48.
  9. Nov 26, 2015 at 8:44 AM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    Turkeybump - with added picture of all the extra parts needed to install.
  10. Dec 2, 2015 at 11:11 AM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
    $2100 shipped!
  11. Dec 11, 2015 at 12:32 PM
    anothernord
    Northern Colorado
    Various Toyotas
    DCLB Manual
