1st. gen tacoma tank size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaforlife, Feb 6, 2012.
  1. Feb 6, 2012 at 6:23 PM
    tacomaforlife
    tacomaforlife [OP] Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    just double checking but what is the actual fuel tank size for the 1st. gen tacoma's i have heard 16 to 18 gallons anybody know what the exact number is?
  2. Feb 6, 2012 at 6:31 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I've put over 19.5 gallons in mine somehow.
  3. Feb 6, 2012 at 6:38 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    the gas tanks varied by year and model (reg. cab, xtra cab, trd, non-trd...)
    yours is most likely 18.5 gallons. go to kbb.com and put in the specs of your truck and look under the 'tech specs' tab
  4. Feb 6, 2012 at 6:48 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    70 Litres.
  5. Feb 6, 2012 at 7:33 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    15 for 2wds 18 for 4wds. it says it in the manual
  6. Feb 6, 2012 at 9:11 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    ? Really?
  7. Feb 6, 2012 at 9:12 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    See page 2 of the attached specifications...
    4x2 capacity = 15.8 gallons
    4x4 and PreRunner capacity = 18.5 gallons
    I don't think we have an actual "reserve tank", as much as the gauge registers empty when we still have ~1.5 gallons remaining.
  8. Feb 6, 2012 at 9:17 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Thats what I figured. Never heard of actually have 2 tanks in a normal "single tank" system. I know my old man had an f150 that had two tanks, but they were two big, seperate, tanks.
  9. Feb 6, 2012 at 9:35 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    correct.
    I have gone up to 40 miles after hitting "E" so about 1.5-2 gallons after you get to the "oh shit I need gas" line.
  10. Feb 6, 2012 at 9:37 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I went 30 miles after the light came on this summer and that was enough! haha
  11. Feb 6, 2012 at 9:38 PM
    TacoMX
    Jonathan
    Deltona, Florida
    haha...I wish I had a gas light :eek:
  12. Feb 6, 2012 at 11:30 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    99 V6 4x4 and my tank is only 15 gallons
    1997tacomav6 likes this.
  13. Feb 7, 2012 at 4:51 AM
    RattleTractor
    Harry
    VT
    Remember...Toyota is Japanese. That means all the bolts are metric and the gas tanks are measured in litres initially. That's the reason for the random numbers like 15.8.
    It's 70 litres for 4x4 and 60 for 4x2.
  14. Feb 7, 2012 at 7:58 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I went 65 miles with mine on before I got nervous and decided to stop. Why I did it, I don't know.
  15. Feb 7, 2012 at 10:24 AM
    sixsixsix
    sixsixsix Well-Known Member
    Was this the time you filled up with over 19.5 gallons somehow? :D
  16. Feb 7, 2012 at 10:39 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Yeah I also went over 420 miles that tank.
  17. Feb 7, 2012 at 2:57 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    :eek: The closest ive ever gotten to that is 320...and according to the info above i have the 18.5 tank which is probably right since ive put in 17.8 or so
  18. Feb 7, 2012 at 5:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea i have a 96 4x4 5spd v6 and mine is only like 15 gal.
