1st Gen Tacoma Clock Fix (Re-solder)
Discussion in '1st Gen. Tacomas (1995-2004)' started by rackomint, Mar 12, 2020.
  1. Mar 12, 2020 at 8:24 PM
    rackomint
    rackomint [OP] Well-Known Member
    Anna TX
    2001 5-spd SR5 3.7L V6 4WD
    The dash clock was out (didn't even know I had one in the first place) and upon searching the interwebs I found a solution that worked for me.
    I am posting this in order to make it easy for someone else to find with a Google search.
    I've been reading up on the subject and it looks like Toyota might have used Lead Free solder on some of the components and they tend to crack over time with vibration, etc.
    I'd say it's worth a try even if you are not able to notice any cracks with naked eye or under magnifying glass. In my case, it was pretty noticeable. It only takes a couple of minutes. Took me less than 20 from start to finish.
    I found this video on how to do it and it was very helpful:
    https://youtu.be/J-Z75rvHSSA
    Here are pics from my clock.
    You can see the crack. Once I resoldered all resistors, it plugged in and works like a charm.
    t3hWIT, JakesTacoTRD and cruiserguy like this.
  2. Mar 12, 2020 at 8:40 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Your ebrake is a little greasy. Wonder what your steering wheel looks like. :bananadead:
  3. Mar 12, 2020 at 8:49 PM
    rackomint
    Anna TX
    Oh man.... I just bought this truck and oh boy.. The amount of gunk I took out of it is unreal. Finishing cleaning tomorrow. E-brake handle is the last. And yup, the steering wheel and shifter were almost black.
    Here's a pic of what the AC fan looked like before and mid clean, I didn't take an after pic
