1st gen tacoma 4x4 rear shock recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crazyjj26, Feb 25, 2021.
  1. Feb 25, 2021 at 1:47 PM
    Crazyjj26
    Crazyjj26 [OP] Member
    97 tacoma 3.4 v6
    putting on rear shocks on the taco. was told bilstein 5100's won't work on a stock frame and was advised to go with 4600's. is this accurate? any other rear shock recommendations? looking to keep under $200
    will plan on doing the front in a few months. any advice for those?
    not planning on doing any crazy off-roading, just logging/mountain roads out here in Colorado
    1997tacomav6 likes this.
  2. Feb 25, 2021 at 2:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Whoever said anything about a stock frame is a moron.
    Bilstein 4600s are valved just right for a vehicle that normally lives on road but drives off the beaten path maybe once in awhile.
    Bilstein 5100s are valved a bit firmer, according to many, for better off road manners. What differentiates the 5100s offered for 1st Gen Tacoma's versus the 4600s is that they come in a longer length.
    That's because they're normally used in a lifted application, so longer shocks won't over-extend and kill themselves during off road articulation.
  3. Feb 25, 2021 at 2:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    By the way, a simple scrolling through the 1st gen section will yield a ton of answers for you.
    Suspension questions are asked on a daily, and you may read and find out more for questions you never thought you had.
  4. Feb 25, 2021 at 2:22 PM
    Crazyjj26
    97 tacoma 3.4 v6
    @Kwikvette
    i bought the rear set. says for 1-1.5" lift. will they be fine on the stock frame?
    Bilstein 33-247717
    Bilstein 33-247724
    i know bilsteinlifts.com isn't associated with bilstein but they list the below for the 1-1.5" lift, not sure if this is true or not about being good on the stock frame:
    DESCRIPTION
    Bilstein 5100 1-1.5″ Rear Lift Shocks for 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004 Toyota Tacoma 4WD
    Part: 33-247724_33-247717
    Rear Shocks are advertised for 1-1.5″ of lift, but we noticed that they will still work fine with 0″ or stock height
    https://www.bilsteinlifts.com/shop/...-lift-shocks-for-1995-2004-toyota-tacoma-4wd/
  5. Feb 25, 2021 at 2:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ok...let's drop the phrase "stock frame"
    Someone used it one time, and now it's stuck to you like glue. It's not even a thing people talk about when talking suspension or the sort unless you went fully custom.
    Going back to your question about the shocks though; you can get away with using those shocks but could run into potential issues depending on usage.
    Your leaf pack; how old is it and what is the condition of it?
    Should take pics, preferably a side shot with the wheel removed.
    If your off road driving is really that limited, you could get away without damaging the new shocks. Otherwise, having the stock leaf pack, especially if it's worn, could result in your shocks collapsing when your suspension articulates, causing premature failure. Extended bump stops alleviate this; may not be necessary in your case though.
    TWJLee likes this.
  6. Feb 25, 2021 at 2:29 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Wtf would an "aftermarket" frame even be? That'd be the worst mod of all time - just buy a different truck
  7. Feb 25, 2021 at 2:30 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Wait. Were you the guy from yesterday?
    Bro, if you're that concerned, just get a front lift too. Like an extra 200 bucks
    https://www.bilsteinlifts.com/shop/...ble-front-shocks-for-1995-2004-toyota-tacoma/
  8. Feb 25, 2021 at 2:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You remind me of me :laughing:
    Had a guy on another forum ask about suspension; went full blown into details with part numbers as to what he'd need.
    Got asked some off the wall questions too.
    Days later, he posts a new thread asking similarly what he asked in his first thread. I'm like, really? :facepalm:
  9. Feb 25, 2021 at 2:33 PM
    Taco2021LB
    Taco2021LB Well-Known Member
    Don
    WA
    2004 DblCab 4x4
    OME 882 Dakars Falken 235/85R16s
    That's it.
    Make the topic even more mind boggling for the OP.
  10. Feb 25, 2021 at 2:34 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Think I saw that lmao
  11. Feb 25, 2021 at 2:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lol I forget you're on the 4R forum too; it was that brainchew guy wanting a 1" lift on his 4R.
    Gave him all the info, part numbers for the '99 Highlander model even, and gave him alternatives and what it would net him.
    After all that, he went out and asked the same shit elsewhere :rofl:
  12. Feb 25, 2021 at 2:35 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    The goal is to beat the absurdity out of him. It's like softcore bullying - it works on 99% of people, the rest just game end themselves
  13. Feb 25, 2021 at 2:37 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    aftermarket frame = rust mod
    Taco2021LB likes this.
  14. Feb 25, 2021 at 2:37 PM
    Crazyjj26
    97 tacoma 3.4 v6
    I can tell you the leaf pack is the original and not in the best condition. the bushings on the rear are trashed, one of the many reasons for the swap. i will upload pics later when i get the wheel off. the pic below is of the lower, rear shock right to give you a brief look at what im dealing with.
    in terms of use - it won't be anything crazy. pretty much for camping, skiing, etc. not rock crawling or anything like that. would the 4600's be good for that or maybe some more research needed?
  15. Feb 25, 2021 at 2:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thank you for that picture.
    With a stock leaf pack, you are many years long overdue for a new one.
    If you wish to retain factory height, I would suggest you get a leaf pack from general springs. Don't forget to include new u bolts as well.
    As for the shocks, just buy a pair of Bilstein 4600's; they're affordable as hell.
    I'd also recommend buying new Bilstein 4600's up front as well; look for a place that sells the top hat and other parts necessary. I bet you have stock suspension up front which too, is many years past due.
    Disposable shocks don't normally last for more than 50-70k miles, even less if they're the cheap kind, and even less than that if they're used outside the norm.
    jbrandt likes this.
  16. Feb 25, 2021 at 2:40 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I mean you're not wrong... "after"-market lol
  17. Feb 25, 2021 at 2:40 PM
    jbrandt
    Justin
    best thing is it's FREE too!
  18. Feb 25, 2021 at 2:41 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Guess that means its not covered by Toyota's warranty though
  19. Feb 25, 2021 at 2:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Get out of my thread :burp:
    treyus30 likes this.
  20. Feb 25, 2021 at 2:44 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I would associate a stock frame with one that hasn't had the shock mounts relocated.
    New leaf pack, springs, struts and shocks are in your future OP, if you want anyway.
    Will still ride like a truck though.
