1st gen Tacoma 2wd to 4wd conversion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phillium, Jan 27, 2018.
  1. Jan 27, 2018 at 12:03 AM
    Phillium
    Phillium [OP] Member
    99 Tacoma SR5 V6
    Hello everyone, I really need some help with this one. I have a 99 Tacoma SR5 manual with the 3.4 and I’m looking to make my little truck into a 4wd machine. I know it’s a lot of custom work but I already have the whole front end cut off a pre-runner to swap in. I wanted to see if anyone had done this swap before and could help me figure out what I’ll need to make it possible! I know I’ll also need the 4wd driveline but I’m not sure what else. Any advice you have would be awesome. Thanks!
  2. Jan 27, 2018 at 12:14 AM
    01 Runner
    01 Runner Well-Known Member
    San Marcos,Texas
    (Old Man Tan) 2001 Pre-Runner
    2001 Tacoma Build (Started 03/17) Mods done- Wheels- -method nv's 16x8 4.5bs 0 o/s -Bfg a/t 285/75r16 Suspension- -king coilovers 2.5 (non resi) -total chaos uca -bilstein 5100 rear shocks -ome dakkar leaf springs Tech/Lights/Cool Mods- -HELLA lights mounted on bumper -Righid D2s mounted inside bumper -CB radio with rear tailgate mount -deck plate mod (actually worth it) Armor- -Relentless Fab “Predator” bumper Winch- WARN m8000 (steel cable) ————————————————————————— Mods to come- -rear bumper (relentless fab) -arb air rear locker -4x4 conversion (way down the road) -new exterior window trim -fender flare delete & 35’s -new tint -new headlights -full size spare tire -tire carrier/hi-lift/jerry-can mount
    Welcome to TacomaWorld man. I would deff use the search bar on this topic. Plenty of people already have threads and there’s tons of post on it. Don’t be surprised if people tell you exactly what I did, it’s just how they are here.... :anonymous:
  3. Jan 27, 2018 at 12:18 AM
    Phillium
    99 Tacoma SR5 V6
    I tried a little bit but I was mostly just finding pre-runner to 4wd conversions and that’s not what I need
    Michael05 likes this.
  4. Jan 27, 2018 at 12:23 AM
    01 Runner
    San Marcos,Texas
    It’s has to be 6-lug to convert to 4wheel drive. The reason so many pre-runners are converted is the fact that they’re built on the same base as the 4x4....without being 4x4. It makes it really easy to just swap everything over and go.
    CatInTheRoom likes this.
  5. Jan 27, 2018 at 12:34 AM
    Phillium
    99 Tacoma SR5 V6
    Yeah I know. I already have the whole front end (suspension, axles, steering) from a pre-runner and somebody who can weld it for me
    01 Runner likes this.
  6. Jan 27, 2018 at 6:27 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Ok I just went through the entire four wheel drive conversion process. Are you trying to convert a non-PreRunner 5-lug to 4WD?
  7. Jan 27, 2018 at 6:29 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you have a 5-lug it will not work even if you have the front clip of a PreRunner. The frames are completely different you would have to cut and weld several cross members and do a lot of custom fabrication to the frame. It would be easier if you just swapped frames.
    I would not even attempt to do it to a 5-lug. It's not worth it at all. At that point I would just SAS it since you're doing so much custom work just to make it a PreRunner.
    What I'm saying is that a complete cab and drivetrain swap to a full PreRunner/4x4 frame will be easier than welding and modifying a 5-lug frame. You'll be paying more in parts than it's worth. You still need lots of 4WD components remember that.
    @Tour991 dropped his 5-lug body and engine (I think?) onto a 6-lug frame and suspension? Maybe he can chime in
    sfchris, Hamer95USA, Tour991 and 2 others like this.
  8. Jan 27, 2018 at 6:34 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Welcome to TW-You'll find all the answers here, some you won't like. lol.
    sfchris and 01 Runner like this.
  9. Jan 27, 2018 at 6:35 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Such as mine. Lol.
  10. Jan 27, 2018 at 6:37 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Honestly at the point of converting a 5-lug frame to a PreRunner frame I would just cut my losses and sell the truck for a 4WD. Unless you're really patient, good with fabrication, and have a lot of time and money it is not worth it. There's a reason why people don't convert 5-lugs to stock IFS 4WD. 5-Lug to SAS 4WD is much more common - I see that all the time. If you were adamant on keeping your truck that's the route I'd take.
  11. Jan 27, 2018 at 7:21 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    If you haven't yet, look in the 'Solid Axle' section here. There are many builds/ conversions there for you to collect ideas.
    Good luck.
  12. Jan 27, 2018 at 11:11 AM
    Phillium
    99 Tacoma SR5 V6
    you guys are just gonna think I’m stupid an stubborn by the end of this but let me explain my situation. I have a 5 lug non pre-runner Tacoma that has more sentimental value to me than I can put a number on. It’s recently been in a crash and now the front end would need some work to make it driveable again. My friend has already cut the whole front end off a pre-runner for his own project and is willing to sell it to me for a few hundred. As for all the custom work and fabrication, I’m going to work with that same friend who is a diesel mechanic with his own shop and a Toyota expert. Him and his boss have the resources and skills to make the front end swap happen,(including fabrication and modifying the cross-members) now I need the rest of the 4wd components to make it all come together. I know it’s not easy, and I know it’s not cheap, but I do know that it’s possible. Thanks for all your feedback
  13. Jan 27, 2018 at 12:16 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'm just like you. I'm sentimentally attached to my truck which is why I didn't just sell it.
    Honestly you would have an easier time buying a 4x4 frame instead of modding your 5-lug one. If you are set on modding your 5-lug I would just do an SAS.
    Phillium[QUOTED][OP] likes this.
  14. Jan 27, 2018 at 4:15 PM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Interesting thread....what is SAS?
    Thank you
  15. Jan 27, 2018 at 4:52 PM
    Phillium
    99 Tacoma SR5 V6
    Straight axle swap
  16. Jan 27, 2018 at 7:40 PM
    Ritchie
    Solid axle swap
  17. Jan 29, 2018 at 10:16 AM
    Actionjackson
    Jack
    MA
    2004 Tacoma
    Thanks Folks. WOW I would love to have a solid front axle in my 04. Is that even possible? Don't have to answer really but that is what I would like to do one day....
  18. Jan 29, 2018 at 11:35 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes tons of people do solid axle swaps. It's just a ton of welding and fabrication.
  19. Aug 3, 2020 at 8:56 AM
    ToyotaTod98
    ToyotaTod98 Well-Known Member
    Tod
    98 limited 4x4 excab white
    Lift ,wheels,micky tires, 4.56 front and rear locker.
    Hey guys. I see it's been awhile since someone has posted about this but I'll ask anyway. I'm fixing to help my buddy convert a2 wheel drive 4runner that has an automatic trans. To a 4 wheel drive with a five speed. Now he bought a 98 runner that has a bad auto trans , but a perfect body and everything else. And he bought a wrecked 98 ex.cab tacoma 4 wheel drive. For parts. The tacoma just has a totaled body but everything else is good. So from what I have read, everything should be able to just swap over and bolt up? I know we'll have to take the front diff , CV axles, knuckles, 5 sp. trans and transfer case with both drive shafts and center brace. I read I'll have to swap out the ecu from the 5sp. To put in because the runner was an auto. The tacoma has the J shifter with auto hubs so I might have to either put on manual hubs or work with the vac.lines. But is there anything that y'all know about that I'm missing please let me know. Cause they both have good 3.4 motors and he is going to give me the one out of the tacoma for helping him. And I definitely would like to have a spare motor for my 98 tacoma, since it's my only ride and life line to everything. Thanks in advance guys.
  20. Aug 3, 2020 at 9:05 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    You’ll have to swap a ton of wiring to do the 5-speed swap too. Additionally you’ll need to cut and weld and move the existing transmission perch, or fabricate a new crossmember.
