1st gen taco- lift for 33's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TritonBass, Jan 6, 2011.
  1. Jan 6, 2011 at 4:29 PM
    TritonBass
    TritonBass [OP] Member
    Taylor
    Chattanooga, TN
    2011 Tacoma SR5 TRD 4X4 (Metallic Gray)
    I have a 2004 Tacoma SR5 TRD 4X4 5 speed. The truck is totally stock. I bought the truck 3 weeks ago with only 67,000 miles. I was offered a free set of tires. A buddy of mine has only had them for a week and is getting rid of them for a larger tire. They are Pro Comp Xtreme M/T 285/75/r16. I am trying to figure out my options for a lift. I don't do a lot of major offroading but it will be used for a hunting truck. I want a lift that will clear the tires without rubbing and have a little room for offroading capabilities. However, I also want it to fit well in the fenders and provide an overall good look. I do not know much about lifts so any help is much appretiated. Also, I talked to a local dealership that said they wouldn't suggest anything over a 3 inch lift because of wear and tear purposes. The lift I am thinking about is a 4 inch Pro Comp full suspension lift. I don't really see how an extra inch in lift is gonna cause a lot of problems. Let me know what you guys think.
  2. Jan 6, 2011 at 4:30 PM
    TritonBass
    Taylor
    Chattanooga, TN
    also if you guys have any pictures of your set ups with 33's i would love to see them.
  3. Jan 6, 2011 at 6:46 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    The general consensus is that 3" is the limit without some major upgrades... You will most likely need UCAs to get the truck back into alignment spec. Your CV angles will probably be pretty extreme too.
  4. Jan 6, 2011 at 7:00 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    just to give you some comparisons, here is the evolution of my last truck
    2" spacers/AAL and a 3" body lift ( I wouldnt do a body lift again, it was on the truck when I bought it). Those are 33 12x50s on a 15x10 wheel and they rubbed the frame rail at full lock
    7" lift ( 4" pro comp and 3" body lift) with the same tires. no rubbing on the frame
    9" lift ( 4" pro comp, 3" body lift, OME 881s/N91s ). and still 33s, they were too small at this point
    9" lift and the 35s, and they didnt rub the frame rail at all.
    i miss that truck sometimes :rolleyes:
    Justin
  5. Jan 6, 2011 at 7:08 PM
    MowTaco
    Kansas
    I needed to be more specific. If you use a body lift or spindles (if you're 2wd) you can go more than 3". But 3" is the unofficial "limit" on the front coils.
  6. Jan 6, 2011 at 7:24 PM
    TritonBass
    Taylor
    Chattanooga, TN
  7. Jan 6, 2011 at 7:47 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i just got they 3" eibach coil spring lift from toytec.com along with the bilstien 5100 shocks it gave me just a tiny hair over 3 " but it rides beutifully (for a mild lifted truck) take a look at them though. i love them. and i am pretty sure with your procomp wheels you wont rub. i put a buddies stock tunda rim with the same size tire as yours and it only rubbed my frame at full lock to the left barely.
  8. Jan 6, 2011 at 7:49 PM
    sir1123
    Charleston
  9. Jan 6, 2011 at 7:55 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    DUDE! 9" LIFT!!! That truck is fvcking AWESOME:eek:
  10. Jan 6, 2011 at 8:05 PM
    TritonBass
    Taylor
    Chattanooga, TN
    thanks for the info on toytec. this lift looks pretty pricey but it seems like a good idea for what i am trying to accomplish. it says it can be set at 3.5".
  11. Jan 6, 2011 at 8:09 PM
    TritonBass
    Taylor
    Chattanooga, TN
    is 3.5" going to give me enough room? I was really hoping to take advantage of this oppertunity on tires but i dont want to run into any problems
  12. Jan 6, 2011 at 8:11 PM
    ninety8taco
    ninety8taco Well-Known Member
    Ian
    Mesa, Arizona
    98 tacoma 2.7L
    33" Bf Goodrich a/t tires, 15" Mikey Thompson rims, K&N cai, Jardine cat-back exhaust, OME 3" coilovers, 2" shackles, two 10" Kenwood subs, Sony amp, JVC deck, smoked tails, led lights, ect..
    double0taco likes this.
  13. Jan 6, 2011 at 8:12 PM
    sir1123
    Charleston
    that should be the eibach coils but if not go to front lift kit the find them on the site..they ar the silver one
  14. Jan 6, 2011 at 8:14 PM
    sir1123
    Charleston
    no 3" of lift with aftermarket wheels should have you covered
  15. Jan 6, 2011 at 8:15 PM
    TritonBass
    Taylor
    Chattanooga, TN
    you sent the right link. i appretiate it. i was lookin at all the options on there. i have heard good things about the bilstein shocks and this lift could adjust to 3.5" which is nice
  16. Jan 6, 2011 at 8:18 PM
    sir1123
    Charleston
    ya but if u set it to 3.5 ur looking at ur truck riding like your tires are bricks
  17. Jan 6, 2011 at 9:10 PM
    TritonBass
    Taylor
    Chattanooga, TN
    good looking truck ninety8taco. how do you think the truck would ride at 3" with this setup? this is why i started this thread. im really clueless on lifts but im trying to learn more before i make the decision
  18. Jan 6, 2011 at 9:11 PM
    TritonBass
    Taylor
    Chattanooga, TN
    what size wheels are those ninety8taco?
  19. Jan 6, 2011 at 9:26 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
  20. Jan 6, 2011 at 9:42 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I got 3 1/4 from the 5100s and Eibachs and I love the ride check out my build.
