1st gen Taco/3rd gen 4runner parts interchangability
Discussion in '1st Gen. Tacomas (1995-2004)' started by yodataco, Mar 21, 2022.
  1. Mar 21, 2022 at 2:22 PM
    yodataco
    yodataco [OP] Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    Looking to buy a 3rd gen 4runner and have some 1st gen taco parts sitting around. I wanted to confirm how interchangeable are the parts between them, Namely engine, trans, transfer case, and rear drive shaft.
  2. Mar 21, 2022 at 2:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    03-04 Tacomas are drive-by-wire, as are 01-02 4Runners.
    All 3rd Gen 4Runners had ABS; some Tacoma's had it and some didn't.
    All 4x4 3rd Gen 4Runners were ADD; some Tacoma's were and some were manual hub.
    Auto 3rd Gen 4Runners had a different stall speed than Tacoma's.
    A multimode transfer case was optional on 99-00 3rd Gen 4Runners; this transfer case was never made available for Tacoma's.
    2001-02 3rd Gen 4Runners had a center-locking differential and did away with the optional rear locker.
    A few different gear ratios were offered for the 3rd Gen 4Runner than were offered for Tacoma's, but there were indeed 4.10 between both and a few other (don't remember).
    Front suspension on both is nearly identical, with the exception of the sway bar, lower ball joints, and tie rod ends.
    Rear suspension is completely different between the two.
    Rear axle housings are also different, with slight variations in the 3rd member as well.
    Just get your 3rd Gen 4Runner and decide what extra parts are worth keeping and which ones aren't.
    Easy.
  3. Mar 21, 2022 at 2:45 PM
    yodataco
    Alex
    Orange County, CA
    2000 4Runner
    Thanks,Just checking before I make the plunge. I have most of what i need up front to convert the runner to 4wd, Sold the push button transfer case and transmission knowing its for drive by wire. Still have the drive shaft out of my Taco but im certain the runners have a shorter one. Looking at 98-00 4runners to avoid that drive by wire stuff.
  4. Mar 21, 2022 at 3:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Same as a Tacoma.
    Either, modify the current spindles by dismantling them and installing the appropriate wheel hubs (whether you go ADD or manual hub).
    New wheel bearing (the same regardless if 2wd or 4wd, regardless if ADD or manual hub).
    Front diff, and necessary components depending on the route you go IE ADD or manual hub.
    Transfer case of your choosing.
    Transmission, if auto, can have the output shaft swapped out. If replacing the auto, make sure it's of the same engine due to the input gear differences.
    Can't recall driveshaft lengths between both models, etc.
  5. Mar 21, 2022 at 3:31 PM
    yodataco
    Alex
    Orange County, CA
    2000 4Runner
    Already have my 4wd spindles off my Taco new bearings/seals and gusseted so it should be a straight swap.
  6. Mar 21, 2022 at 3:47 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    From what I've gathered on the forums and rummaging through junkyards...
    3rd gen 4Runner wheelbase is about 1" longer than a standard cab 1st gen Tacoma. You might be able to use a rear 4Runner drive shaft in a standard cab Tacoma, not in an extended or double cab. I think different years (or maybe trims?) of 4Runners also got different drive shafts.
    Over the weekend I overheard some guys talking about how some 4Runners had slip yokes and other didn't. They weren't sure why.
  7. Mar 21, 2022 at 6:07 PM
    yodataco
    Alex
    Orange County, CA
    2000 4Runner
    Thought so. Ill go find out while shopping
  8. Apr 1, 2023 at 7:06 PM
    illbeda
    illbeda Well-Known Member
    Can anyone verify if first gen (2000) Tacoma PreRunner front struts will plug and play with a 3rd gen 4 runner ?
  9. Apr 1, 2023 at 7:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Coilovers will; neither use struts.
    But they may have different spring rates if you're talking stock.
    treyus30 likes this.
  10. Oct 13, 2024 at 8:11 PM
    oregon.tacomajulian
    oregon.tacomajulian New Member
    Julian
    Will 3rd gen runner rear shocks work on a Tacoma 1st gen?
  11. Oct 13, 2024 at 8:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4Runner rears have stems on top, not eyelets so no.
  12. Oct 13, 2024 at 8:32 PM
    NikkoCharger
    NikkoCharger Active Member
    Dontae
    rusty '01 Double Cab
    -I learned the hard way that 3rd gen 4Runner's have shorter front doors then our Taco's. The door panels, front windows, the door its self and a few other parts do not fit.
    -The hood latch from a 3rd gen 4Runner will bolt right up, but the secondary hood release latch will be hard to get reach.
    -Yakima q clips for the 3rd gen 4Runner will fit our Taco's
    -The manual hvac controls will swap over.
