1st Gen sway bar question... any ideas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Loia, Aug 28, 2020.
  1. Aug 28, 2020 at 10:31 AM
    Loia
    Loia [OP] Member
    2004 Tacoma extended cab
    Hey fellas,
    So I recently changed my rack and pinion, tie rods and sway bar end links. I bought new OEM bushings for the sway bar (rubber ones not polyurethane)... applied some grease, cleaned it all up and fastened it on. I could immediately feel the difference , however, a week later the bushings were chewed up. I’ve attached some pictures , if anyone has any idea why this may have occurred, pls let me know your thoughts.
    the only thing I can think of is that the sway bar itself needs to go and be swapped because the surfaces of the spots where it meets the bushings are worn out, a bit rusty. I did clean them up before I did the work... but it’s the only thing I can think of now... maybe the end links could be playing a part...
    Thanks for any pro tips.
    PS - Before I do the re work, I will definitely source some polyurethane bushings so if anyone has a link for a spot to buy those for my taco pls do pass it along.
  2. Aug 28, 2020 at 10:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll let someone chime in on possibly what happened but I will say, grease is only needed for poly, not rubber.
    Poly will spin/turn hence why they need grease, and over time, begin to squeak and squeal until re-lubed again.
    Rubber twists in place.
    ElTaquitoJr likes this.
  3. Aug 28, 2020 at 10:36 AM
    Loia
    Loia [OP] Member
    Boom. Pro tip out the gate. So maybe the grease combined with rubber and rough surface was the culprit...
    thanks for quick response.
  4. Aug 28, 2020 at 11:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Did you get the correct size I think there are 3 different sizes .
    Kwikvette likes this.
  5. Aug 28, 2020 at 11:46 AM
    Loia
    Loia [OP] Member
    Hey man. Yeah, they came from Toyota with my VIN # as reference, and they fit in snug.
  6. Aug 28, 2020 at 11:47 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Own the Truck from New then??
  7. Aug 28, 2020 at 11:49 AM
    Loia
    Loia [OP] Member
    Sorry, don’t follow what you mean. I’m not the first owner, but I suspect those bushings that I took off were from the factory and have been on the truck since it was new.
  8. Aug 28, 2020 at 11:56 AM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    Don't you have to tighten things down with the weight of the truck on it? If the suspension was hanging and you lowered it it would put a pre-twist on the bushings... I could be wrong..wouldn't be the first time, just ask my wife.
    goldentaco03 likes this.
  9. Aug 28, 2020 at 12:50 PM
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    I had similar rust on the sway bar when i took it out to replace the brackets and bushings. New brackets from the dealer and the poly bushings from rockauto, sort of sanded and painted the sway bar and no problems since. Maybe just toss the polys on there and be done with it.
  10. Aug 28, 2020 at 1:37 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    Are you sure you didn't swap them left/right?
  11. Aug 28, 2020 at 2:03 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Petroleum products (grease) are generally bad for rubber unless it says that they're rubber safe or vice versa...but that being said I can't imagine it ruined them that fast...
  12. Aug 28, 2020 at 3:39 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Maybe it's just the pics, but it doesn't really look like the swaybar is sitting flat in the bushings.
    Looks like it's shifted to the driver side.
    Wyoming09 likes this.
  13. Aug 28, 2020 at 6:47 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    @Loia did you take the swaybar out completely and change the bushings or take one side off at a time?
    The sway bar is essentially a giant spring. If you take it out completely and don't reinstall it at the same degree, you can "load up" the spring and it'll wear out bushings way faster.
    You may need to remove the swaybar end links, then loosen the the mounts and rotate the sway bar down towards the ground
  14. Aug 29, 2020 at 12:01 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I was going for the fact at sometime the sway bar may have been changed I have run across this a few times the parts ordered by the VIN are not the correct ones.
    Nothing worse then the Vehicle owner swearing the part is correct when it is way to big to fit.
    Best of Luck!!
  15. Aug 29, 2020 at 8:43 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    The diameter of a sway bar on a TRD model is 28 mm. On other models it is only 27 mm. At least I think so. I do know that the TRD model sway bar is the larger of the two sizes. You might wanna check.
  16. Sep 2, 2020 at 11:12 PM
    Loia
    Loia [OP] Member
    Thanks for the all the feedback guys.
    I took the sway bar off completely, changed the end links, and used new bushings.
    I’ve ordered some poly ones, and am considering a brand new bar just to not deal with the rust on the current one.
    the diameter I’m not quite sure, bought the bushing from Toyota , with the VIN, they gave me these bushings.
