1st Gen Sound Ordnance B-8PTD Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fuzzy Dustmite, Jan 25, 2014.
  1. Jan 25, 2014 at 3:50 PM
    Fuzzy Dustmite
    Fuzzy Dustmite [OP] Active Member
    Greg
    Mesa, AZ
    02 DLX Lunar Mist / Grey
    Got a Sound Ordnance B-8PTD powered subwoofer off ebay a few days back. Installed it today. Took some pics to serve as a walkthrough of sorts. I don't claim I'm an expert by any means, just watched a few videos on YouTube. Probably other, better ways to do it, but it's working :)
    Comments appreciated!
    Disconnect negative battery terminal:
    Removed the fuse while I hooked everything up
    Found this unused firewall opening with grommet:
    Pulled the grommet and cut an X in it with a box cutter:
    Fed the power cable through that into the cab:
    This is where it comes through in the cab, just above the gas pedal:
    Routed it behind the pedal to prevent any problems:
    Started disassembling the interior to feed the wires cleanly:
    Remove this pin:
    Pin removed:
    Remove the 6 screws on either side of the center console:
    2 here:
    One here
    Two inside the storage area:
    IMG_20140125_090532_28b3ff15fafd191d45ee1641bbc10adda978f598.jpg\
    Center console removed:
    Remove the shifter knob:
    Shifter cover removed:
    Pull the knobs off the air controls:
    Pop the cover:
    Remove the two screws holding the stereo surround:
    Grab the cover and pull straight out:
    After it came out, I disconnected the connections to the airbag and the cigarette lighter. Couldn't get the ashtray light cable disconnected, so I just let it hang by that.
    Removing the lower cover:
    Remove the screw behind the lower cover:
    Lower cover removed, aux powers disconnected:
    Interior disassembled, now running the power to the passenger seat:
    Removing the receiver to get at the sub connections in the back (there are 4 screws here):
    Removing the interior panels to route the sub audio cables:
    Routing the audio cables:
    Connecting the audio cables to the receiver's sub ports:
    Running the remote power from the head to the passenger seat, using the same path as the power:
    Remote power connected:
    Decided to use the center console mounting bracket for the ground as it is unpainted:
    Connections made on the sub:
    Hooking up positive power:
    Fuse back in:
    Hooked up negative power and reassembled.
    Not too bad, took a couple of hours. I had recently replaced the stock stereo with the Pioneer, so I was familiar with the radio removal.
  2. Jan 25, 2014 at 7:18 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Nice write-up! Congrats on the new sub. I've had one for some time, and remain very happy with it. (FWIW, my install looked a lot like yours. :cheers:)
  3. Jan 27, 2014 at 11:21 AM
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    Great write up OP! I was wanting to install one of those Sound Ordnance subs, how does it sound?
  4. Jan 27, 2014 at 3:28 PM
    Fuzzy Dustmite
    Greg
    Mesa, AZ
    I like it. It gives the sound a nice punch. I don't do hip hop or any other heavy bass stuff, mostly rock/alternative/punk, so it does well for that. Still not sure i have all the settings dialed in, as I don't really know what I'm doing, but I like the sound I'm getting.
    Next on the list is a stock speaker upgrade.
  5. Jan 27, 2014 at 5:43 PM
    mkatts
    mkatts Well-Known Member
    Joe
    Columbus, OH
    95 Reg cab 4x4 2.7L
    of you like how it sounds then its dialed in right for you! :)
    thats all that matters.
    good job!
  6. Jan 27, 2014 at 8:31 PM
    Norton
    Like Fuzzy, I'm very happy with mine too.
    After installing my new stereo and replacing the four main speakers, I was disappointed with the lack of bass. Adding the B-8PT made a HUGE difference. IMO, it's one of the easiest and best bang for the buck audio upgrades you can do for our trucks. Highly recommended.
  7. Jan 27, 2014 at 9:34 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Just put in and tuned a JL 10w7 and man did I miss my bass
  8. Jan 28, 2014 at 10:05 AM
    blake9220
    blake9220 Well-Known Member
    Blake
    Orange County, CA
    01 TRD PreRunner DblCab
    I've got one of these in my truck and like the guys said above, definitely good bang for the buck, however i still miss having a true sub. :(
  9. Jan 28, 2014 at 10:35 AM
    yoterdude
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Thanks Fuzzy, I don't listen to any rap really just rock and some dubstep. I would like something that wouldn't be in the way like a huge box in the back seat so I think the Sound Ordnance would fit me perfect!
  10. Jan 29, 2014 at 7:34 AM
    Fuzzy Dustmite
    Greg
    Mesa, AZ
    Fits nicely under the seat. I think I might have to fashion some sort of guard for the back of it so that on the occasions I have passengers in the extended cab, they don't accidentally step on/kick the plugs.
  11. Mar 13, 2015 at 9:48 AM
    Ericyoung111
    Ericyoung111 New Member
    07 sr5 6 speed
    Has anyone tried installing this unit in a second generation tacoma under the passenger seat? Does this work?
  12. Jun 8, 2016 at 1:21 PM
    cheddardonkey
    cheddardonkey Member
    I know this thread is a little old but does anyone know if this (or any other self contained powered slim sub) will fit behind the rear seat in the 1st gen double cab?
  13. Jun 8, 2016 at 2:06 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    This ones under 3" thick. Check the deminsions and see if it will fit.
    Look at this on eBay http://www.ebay.com/itm/301469569773
    cheddardonkey[QUOTED] likes this.
  14. Jun 8, 2016 at 2:17 PM
    Aw9d
    Aw9d That one guy
    Great write up OP! Here is a site that can help you with how to tun your sub. It won't be 100% accurate for your setup but will give you the knowledge you need to get it going.
    http://www.crutchfield.com/S-QTnUJ8934j4/learn/car/subwoofers/tuning.html
    Sure if you like replacing your sub/amps due to damage..
    Just because you like the way it sounds doesn't mean it's dialed in right. Gain could be too high causing clipping/distortion which is damaging your sub and odds are unless you know what to listen for you can't hear it.
    I can't tell you how many times I've meet people who said "My subs sounds great" and they are so distorted I'm shocked they haven't fried yet. I show them on an O-Scope how much it's clipping their setup is and I'll adjust it. Night and day difference with the sound output.
    I've seen some really good setups tuned horrible and the owner had no clue how bad it was until I fixed it. I'd say 90% of the installs that were brought to me were had too much gain set on the amps.
  15. Jun 8, 2016 at 2:23 PM
    devinzz1
    devin
    2023 aclb trd or mt
    soooooooo many people think that gain= volume knob. i know of a shop that charges for installs that just crank that fucker up.
  16. Jun 8, 2016 at 2:25 PM
    Aw9d
    Aw9d That one guy
    You are 100% right about Gain being a volume knob. Drives me up the wall when I see shops, *cough audio express cough* run the gain at 90% or higher.
    I just recently started doing tuning for people with an Oscilloscope so they can see the clipping that's going on. Best tool I have for car audio installs.
  17. Jun 8, 2016 at 2:33 PM
    devinzz1
    devin
    2023 aclb trd or mt
    if i did it more often id get a smd dd-1. can find em on ebay pretty cheap.
  18. Jun 8, 2016 at 2:36 PM
    Aw9d
    Aw9d That one guy
  19. Jun 8, 2016 at 10:39 PM
    cheddardonkey
    man its close. But what a deal, and reviews seem to be favorable. almost can't pass this up and if it doesn't fit I'll consider under the pass seat again. thanks for the tip!
