1st gen lower control arms compatibility
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgen808, Nov 25, 2023.
  1. Nov 25, 2023 at 5:02 PM
    1stgen808
    1stgen808 [OP] Member
    Just wondering if anybody knew 2004 Tacoma four-wheel-drive lower control arm is the same as a 3rd gen 4Runner 4x4? Thanks guys
  2. Nov 25, 2023 at 5:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep.
    1stgen808[QUOTED][OP] likes this.
  3. Nov 25, 2023 at 8:54 PM
    1stgen808
    Thank you
  4. Nov 25, 2023 at 8:59 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    One difference is the sway bar mounts are in a different spot. Other than that they are the same.
    turbodb likes this.
  5. Nov 25, 2023 at 9:25 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I thought the steering stop is slightly different as well.
    Tour991 likes this.
  6. Nov 25, 2023 at 9:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The stock lower ball joints and tie rod ends attribute to the slightly shorter turning radius, but can be exchanged for the other variants meaning, you can use Tacoma LBJs on a 4Runner if you use Tacoma TREs as well.
  7. Nov 25, 2023 at 9:58 PM
    1stgen808
    I was going to keep my lower ball joints and tie rods would that work? Also is there a way to get around the way the tab is facing for the sway bar end link to match up to the Tacoma setup? Thanks
  8. Nov 25, 2023 at 10:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You did read my post right? Yes, you can use them.
    I'd ditch the sway bar.
  9. Nov 25, 2023 at 10:48 PM
    1stgen808
    @Kwikvette sorry I did read it. Gonna keep the sway bar attached right now to get me through safety checks here in Hawaii. That’s the only reason I need to hook it up. So was looking at an alternative option to allow the stock tacoma sway bar to be used with the 2000 4Runner lca since the tabs where the sway bar gets mounted to between the Tacoma and 4Runner are in different orientations
  10. Nov 25, 2023 at 10:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The hell...so you need to run a sway bar yet the remaining 99% of ridiculous Tacoma's with stupid lifts (many of them half-assed and unsafe) are ok to roam?
  11. Nov 25, 2023 at 11:55 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Keep the sway bar, it's safer if you speed.
  12. Nov 26, 2023 at 7:24 AM
    02hilux
    Planet: EARTH
    Look almost like mine :cool:
  13. Nov 26, 2023 at 11:08 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I've always heard if you delete the sway bar then it has a tendency to oversteer...
    Replacing the sway bar link bushings has a big impact if the old ones were wore out...
    At least on mine....the old rubber ones were shot...
  14. Nov 26, 2023 at 11:35 AM
    Nano909
    Xcab 3.4 4wd 5MT
    Yeah delete the sway bar if you want massive body roll.
