1st gen interior swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phessor, Jan 14, 2024.
  1. Jan 14, 2024 at 1:42 PM
    Phessor
    Phessor [OP] Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Has anyone ever attempted to swap out the interior of a 2001 Tacoma and put it into a 1998 Tacoma?
    I did not realize they were that different until I put in a 2001 headliner. Now I have to either go back to a my raggedy headliner or swap in a 2001 side panels and a pillar.
    It appears that the 2001 headliner has plastic ribbed supports all around the top of the cab.
    This is turning into quite the project. Any help would be greatly appreciated, thank you.
  2. Jan 14, 2024 at 1:47 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    You’d most likely need to swap out the a-pillar plastic and the rear panels around the b and c pillars. I don’t think you’d need to do anything else except maybe the trim pieces above the doors and rear window.
  3. Jan 14, 2024 at 2:21 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Why are you swapping the interior? If the fabric is torn up you can get some new fabric and spray glue and repair the current headliner as long as the backings still ok.
  4. Jan 14, 2024 at 7:31 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    So my headliner has gone through a few iterations of change. I recently removed the Overland roof console and needed to replace the headliner. I purchased a headliner from a 2001, not realizing they were so different. My bad for not doing the research.
    So option A: keep the 2001 headliner and replace the A pillar trim, both 1/4 panel pieces and the white ribbed support pieces on the ceiling. And all associated components needed for the swap. (can you say expensive?)
    Option B: locate a good used 1997-1998 headliner and sell the 2001 headliner I just purchased.
  5. Jan 14, 2024 at 8:42 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I would find a good shell and have a local shop cover it however you want. Probably cheapest.
  6. Jan 14, 2024 at 8:44 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    I will need a good shell, mine is so rotten from being baked in the Arizona sun for a lot of years.
    MadNachos[QUOTED] likes this.
  7. Jan 14, 2024 at 8:51 PM
    MadNachos
    Oh yeah, AZ, I feel ya. Is it complete enough to layer it with fiberglass to hold it together? Might be worth trying if you want to line it yourself. Just tossing ideas out...
    Phessor[QUOTED][OP] likes this.
  8. Jan 14, 2024 at 8:54 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    It is still in one piece, but is flimsy and separating badly.
  9. Jan 15, 2024 at 10:55 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I swapped complete interiors between my 2001 and 2003 Tacomas when I got the newer one six years ago. Instrument panel and all.
    It was surprising to find a number of differences and some incompatibilities within the Gen 1.5 trucks. I’ll bet you’re running into LOTS of things, @Phessor, between a Gen 1 and a Gen 1.5.
    My switch was to change color from oak to charcoal and to upgrade condition. In the end I had to find some 2003 interior trim in charcoal that wouldn’t switch from the oak 2001. Back then, much of it was still available from Toyota so I got brand-new. That’s not the case now — it’s more of a scavenger hunt.
    MadNachos likes this.
