1st Gen Halogen Headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by JKO1998, Dec 9, 2015.
  1. Dec 9, 2015 at 7:34 AM
    JKO1998
    JKO1998 [OP] Well-Known Member
    Utah
    Been tryin to find stuff, I was told to do D2S lights or something? Does anyone know if there's a lot with instructions or something?
  2. Dec 9, 2015 at 1:35 PM
    Toyomonkey59
    Toyomonkey59 Well-Known Member
    James
    Hedgesville Wv
    2012 toyota tacoma Trd 4.0 4x4 Doublecab
  3. Dec 9, 2015 at 1:50 PM
    Toyomonkey59
    James
    Hedgesville Wv
    Or osram night breakers
  4. Dec 9, 2015 at 1:52 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    I have zxe bulbs. They are ridiculously bright.
  5. Dec 9, 2015 at 2:16 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I did a H4 conversion on my truck with factory sealed beams and run Hella 100w halogen bulbs without any complaints, did have to add in a relay harness to get the full benefit though.
  6. Dec 9, 2015 at 3:10 PM
    JKO1998
    Utah
    Pictures anyone?
  7. Dec 9, 2015 at 3:11 PM
    GreeGunc
    Jacob
    North GA
    My camera sucks to much to see it
  8. Dec 9, 2015 at 8:08 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    halogen is the gas used in most of the stock headlights that have ever been produced. ever. and i mean as far back as the 1800s. probably further, I don't know. Every standard automotive light has halogen in it. even your stock turn signal, map, backup light, and stop light bulbs. D2S is a type of HID light bulb. only made to fit certain vehicles like mercedes, bmw, and the like. It uses xenon as it's filler gas instead of halogen. when you go to a parts store and buy their "better than OE" light bulbs, or long life light bulbs, you're buying the same OE headlight design with xenon in it instead of halogen. it allows the filament to burn brighter since it can handle more. but it doesn't burn as bright as HID.
    you can go on ebay and buy HID conversions for our 9003 (a universal part number) light bulbs. essentially, it is a HID bulb built on a 9003 bulb mount that comes with an extra wire lead and power converter to power the HID bulb. Take these for example. they have the same mounting as your stock 9003 bulb. but they're HID light kits that come with the ballast to power them. you just stick the light bulb in the lamp assembly, hook one end of the ballast to your stock wiring, stick it on the firewall close by, connect the other ballast wiring to the light bulb and vuala, HID lights on your stock truck.
    that's probably what you're looking for.
  9. Dec 9, 2015 at 8:11 PM
    CodeSeven
    Serge.
    Coachella Valley
    also, these HID bulbs that i linked on EBAY come with a "color warmth" rating. the following picture displays the color warmth options you can get for any light bulb ever be it automotive, home, or utility. your average house light bulb runs around 3500k. a slight yellow. you don't get to pure white until about 6500k. blue colored lights are higher than 6500k. you can see in the pic. so if you want pure white lights or even those blue lights. look for 6500k-12000k HID bulbs. the ebay link i gave i think gives you color warmth options. [​IMG]
  10. Dec 9, 2015 at 8:15 PM
    JKO1998
    Utah
    All that went over my head... I need help or to skip that part of my wanna be build...
  11. Dec 9, 2015 at 8:16 PM
    CodeSeven
    Serge.
    Coachella Valley
    you really do need to take the time to read what I said. cant help you otherwise because when it comes down to it, it's your choice on what you want. this is just info to help you decide what you want.
  12. Dec 9, 2015 at 8:19 PM
    JKO1998
    Utah
    I did read it, I just don't under stand it, I read some where that people put the D2Ss in stock housings, maybe those are retrofits? My lights work fine I just wanna makem look nice.
  13. Dec 9, 2015 at 8:25 PM
    CodeSeven
    Serge.
    Coachella Valley
    ok. looks like you're attending this forum pretty well. so I guess we can have a conversation about it.
  14. Dec 9, 2015 at 8:28 PM
    JKO1998
    Utah
  15. Dec 9, 2015 at 8:32 PM
    CodeSeven
    Serge.
    Coachella Valley
    ohhhh I see. those lights are complete lamp assembly replacements. everything you asked about has been in just changing the bulbs alone. this is something else.
  16. Dec 9, 2015 at 8:34 PM
    JKO1998
    Utah
    Yeah sorry, guess I didn't know the words to use. So this would be new housings, new bulbs, new wiring, projectors and I'm sure other stuff
  17. Dec 9, 2015 at 8:34 PM
    CodeSeven
    Serge.
    Coachella Valley
    those are called projector headlamps. they're complete replacements for your current headlamp assembly.
  18. Dec 9, 2015 at 8:34 PM
    CodeSeven
    Serge.
    Coachella Valley
    im not sure about the new wiring. they may come with connectors to fit your stock wiring setup.
  19. Dec 9, 2015 at 8:35 PM
    CodeSeven
    Serge.
    Coachella Valley
  20. Dec 9, 2015 at 8:36 PM
    JKO1998
    Utah
    Yeah see, I was told those were junk and I don't like the 2 bulls thing, if I could find out how to make them like the picture I posted itd be amazing. I'd like to do this after lifting, it'll be awhile... Highschool saving is slow..
