1st Gen Custom Rear Airbags
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacosConQueso, Mar 5, 2022.
  1. Mar 5, 2022 at 3:21 PM
    TacosConQueso
    TacosConQueso [OP] Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    So Ive been running this setup for about 4yrs now and it has been great so I figured it was about time to share it incase it can give someone else some inspiration/ideas.
    How it began:
    This truck is a '99 and the OEM leaf springs went flat long ago. About 3 years prior to adding airbags, I replaced the OEM springs with General Spring HD springs. They too went flat after about 2 years. Not wanting to constantly be replacing springs, or spend a fortune on specialty ones, I began looking at airbags. My main concern with airbag kits available, is...well...they just look weak and poorly designed for the loads that can be going through them, so I decided to make my own.
    The Design:
    The frame brackets are all 1/4in flat bar that has been bent to follow the contour of the frame and only attaches with 2 bolts, 1 in the bumpstop, and 1 in the lower flange of the frame just aft. This aft bolt also attaches a welded angle that is inside the frame just to prevent that flange from ever getting rolled under high load.
    The axle mount also uses 1/4in flat with some welded 1/2in flat bars so the cradle will clear the u-bolts. I also used a daystar cradle here which simplified the attachment (one center bolt tapped into one of the 1/2in flats).
    With the bags mounted in this location, I was able to align them pretty well with the axle, the bump stops (my thinking was this is a reinforced area of the frame already designed for loading), and pretty close to the center of the frame web (to minimize any torque applied to the frame).
    Enough text, now some pictures (please excuse the dirt):
    Here you can see the aft bolt and the angle reinforcement inside the frame (also didn't know about it rubbing a hole in my airline...need to fix that...):
    Passenger side also got a simple heat shield for the exhaust:
    Couple last notes:
    All bends were made with a homemade finger press brake and a Harbor Freight 20T press
    Usually run the bags at 12psi to get a good ride height and ensure they can't get pinched
    Inflated with Schrader valves mounted in the lower license plate holes
    Well hopefully somebody enjoyed all this and maybe it'll inspire someone to do something else cool. Let me know if there are any questions and Ill try to answer what I can (although Im not on here too much).
    billyballer, btu44, oldgreg and 6 others like this.
  2. Mar 5, 2022 at 4:15 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Just what pray tell are you carrying in the bed that wears your HD springs out in 2 years?
  3. Mar 5, 2022 at 5:33 PM
    TacosConQueso
    Brian
    Im hoping I got a defective set because it sure didn't take much. Never got to tow with the springs but I think the trip that did them in was when I drove across the country for a summer internship. I had a duffle of clothes, a cooler, 5gal water jug, box of cooking stuff, box of personal stuff, and my camping/climbing gear. I picked up the camper shell that summer too so in total maybe 500-600lbs in the bed? I was consistently hitting the bump stops the entire drive home and decided I needed a fix.
  4. Mar 7, 2022 at 8:17 AM
    jbrandt
    Justin
    Yeah, with the HD springs that should be no problem at all. I never really hit the bumpstops with 2 motorcycles in the bed of my doublecab.
    How old are your 5100's? Looks like at least one of them leaks. That'll have a significant impact on the ride, too.
  5. Mar 18, 2022 at 1:34 PM
    TacosConQueso
    Brian
    Yeah I thought they may be just the thing, if only they had kept their arch. After going both routes, for the price, I think I will always just do airbags in the future. Too easy to adjust the ride height depending on the load and a replacement bag doesn't cost nearly as much as new springs if it ever comes to that.
    The shocks were replaced about the same time as the springs. I think they may have bottomed out a few times when the springs went flat which certainly didn't do them any favors. (I don't think 5100s will bottom out but I foolishly went with 5125s thinking the HD springs would ride a little higher). They are still damping well though and by looking at the dirt on the piston, they haven't bottomed out in a long time.
  6. Mar 18, 2022 at 4:19 PM
    jbrandt
    Justin
    Your bumpstops should prevent bottoming out no matter how flat your springs are. With the bags effectively replacing the bumpstop, you want to be sure it still can't bottom out the shocks to prevent that from happening in the future.
    I definitely like bags. I put some on my 4Runner to take out a bit of the squat when I'm towing my travel trailer.
  7. Mar 29, 2022 at 6:35 PM
    TacosConQueso
    Brian
    For sure, air bags are nice. Ive been keeping an eye on the shock travel but it really doesn't take much air in the bags for them to function as bump stops.
  8. Jun 18, 2022 at 9:23 PM
    Bobo4x4
    Bobo4x4 Member
    First gen Tacoma
    Did you have to drill holes for any of the mounts?
  9. Jun 19, 2022 at 9:15 PM
    TacosConQueso
    Brian
    2x holes per side: 1/2in through the front side of the bump stop and then a 5/16 (I think it was) through the bottom flange of the frame ~6in further back.
  10. Mar 7, 2024 at 5:20 PM
    cfpfour
    cfpfour Member
    Collin
    2002 Tacoma TRD Ext. Cab 3.4L 4x4 MT
    Stock
    This is a really sweet set up. Its uncanny how similar my experience has been to yours lol. My General Spring HD's are also sagging after only 2 years (its nearly on the dot). I also have about 500ish lbs in the back almost all the time including the topper. I did however tow a 6x12 trailer twice this past summer that was fairly loaded quite a ways heading out to my internship and back as well. I think I'll be doing something similar with air bags, because I don't really want to buy new leafs again. Did you replace the sagging leafs after adding the airbags?
  11. Mar 30, 2024 at 8:20 PM
    TacosConQueso
    Brian
    Sorry, been away for awhile.
    Still rocking the "HD" leaf springs. Bushings were shot on the old ones so I kept the "HD" ones installed.
    cfpfour[QUOTED] likes this.
  12. Apr 1, 2024 at 5:56 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I added those to my 98. I have OME Dakars with the extra leaf. The leaf springs are made for off-roading and not necessarily carrying a heavy load. The bags are great for carry ing stuff. Cement, dirt etc. I also haul a motorcycle on a hitch carrier and with 7 psi in the bags it rides perfect.
    cfpfour likes this.
  13. Apr 1, 2024 at 10:10 AM
    cfpfour
    cfpfour Member
    Collin
    Stock
    I ended up buying new leafs and shocks since they were both gone. Airbags are now on as well and it definitely works well.
    Good to hear about the motorcycle carrier. I've got one too and hadnt tried it yet, looking forward to it.
    Xbeaus[QUOTED] likes this.
  14. Feb 6, 2025 at 8:30 PM
    jmsdc
    jmsdc New Member
    Jonathan
    '02 Tacoma
    great write up. I've been thinking of doing something like this and I appreciate you posting. Do you remember what brand of airbags and/or a part number?
    thanks again. I know this is an older thread but I hope you see it.
  15. Feb 21, 2025 at 1:42 PM
    TacosConQueso
    Brian
    Sorry for the late reply but I went back through my old receipts and confirmed I used Firestone 6781 airbags. These are the same bags that they include in their 2304 Kit made for 1st gens
  16. Apr 10, 2025 at 10:07 AM
    billyballer
    billyballer Member
    Bill
    2004 White Tacoma 4x4, Ext Cab, 2.7, 5 speed
    What brand are the air bags? and do you have an onboard compressor?
  17. Apr 10, 2025 at 4:34 PM
    that_one_1999_tacoma
    that_one_1999_tacoma Well-Known Member
    1999 Toyota Tacoma pre runner xtracab
    bbs wheels, 2001-04 guage cluster, coolant system refresh, new headlights, full 9,000 dollar repaint, grille lights, smoked bumper blinkers, valve cover gasket replacement, and new oem rear bumper
  18. Apr 20, 2025 at 11:03 AM
    TacosConQueso
    Brian
    I do have a compressor but not permanently wired or plumbed, just mounted. Most of the time I top them off with shop air. For how infrequent they need it, its often not worth using the onboard compressor.
    Ive heard of people just carrying a bike/hand pump and as long as it has a good valve that you can release without loosing pressure in the bag thats really all you need.
  19. Apr 20, 2025 at 5:29 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Nice work, looks really good and solid.
