1st gen brakes DIY?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bhh2000, May 13, 2011.
  1. May 13, 2011 at 1:55 PM
    bhh2000
    bhh2000 [OP] Well-Known Member
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    My truck really! needs new front brakes and I would really! Like to not pay the 250-ish that I was quoted. I have never changed my own brakes before but am fairly capable.
    Has anyone done their own? If so how long did it take you? How much work was it and where did you order the new pads and how much were they?
    I'm fairly confident I can do it but the brake line bleeding and making sure everything is working properly makes me a little apprehensive.
    I would love any advise as well. Thanks in advance guys!
  2. May 13, 2011 at 1:59 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Doing the front brakes on the 1st generation Tacoma is easy. I did mine myself, in two and half hours with no problem. There are a few videos on Youtube.
  3. May 13, 2011 at 5:52 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If all you need is rotors and pads, you do not bleed the brakes. That only happens when you replace a caliper.
    Make room for the new pads by prying the old pads apart BEFORE you remove the caliper. Pry between the rotor and the pad. DO NOT pry against the piston.
    Make sure you clean all areas where the pads touch, then lube the same areas with 3m caliper lube. Do not use wheel bearing grease or regular antiseize, it will gum up fail.
    Clean new rotors with brake cleaner before install, they have a protective grease on them.
    Work and finish one side at a time. Then you'll have an idea when you forget how it goes back together.
    Do not breathe brake dust. It may not be asbestos, but it is bad for you. Clean everything with brake cleaner before you start.
  4. May 13, 2011 at 5:53 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    This looks like a good video.
    http://www.youtube.com/watch?v=M7gEOMny5Dw
    I haven't done them on my truck yet, but did my wife's Ford Escape not too long ago. I just took my time, used lots of brake cleaner, and made sure not to stress the brake lines.
    I don't remember how much the front pads were, but even buying the mid-high pads at Kragen was pretty cheap. Since you do one side at a time, you always have an example to look at. I used the special brake pad lube although the pads I bought specifically said not to put the lub on the back of them so I lubed posts where things move.
  5. May 14, 2011 at 10:37 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    This is what I used as pointers. Last brake job I did was on my old K5 Blazer and it was years ago and this video helped remind me what I was doing.
    Installed Brembo blanks and Hawk LTS pads a while back on my truck and was done with both sides in an hour. Huge improvement over OEM brakes too.
  6. May 14, 2011 at 10:57 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    it takes me about 10 minutes per side including taking off tire ( pads only) but i dont have a yota front end. its relatively simple and once you do one side the other is a cake walk. btw buy a haynes manual, it will be your best friend. also i believe there is a write up about it on here somewhere
  7. May 14, 2011 at 3:13 PM
    bhh2000
    Ben
    Santa Rosa
    2016 DCLB TRD 4X4
    Thanks the the advise! I watched the video and it looks easy!
    Now any input on pad and rotor brands or materials?
  8. May 14, 2011 at 4:53 PM
    gobias
    02 Dbl TRD
    Brembo blanks and Hawk LTS pads. Be sure to get some anti-squeal compound for the backs of the pads too.
  9. May 14, 2011 at 8:58 PM
    ngrysen713
    ngrysen713 Member
    Nic
    Hudsonville, MI
  10. May 14, 2011 at 9:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    We've always had luck with cheap duralast pads from vatozone. Also take the rotor into your local NAPA store (or any machine shop really) and see if they can be turned.
  11. May 14, 2011 at 9:03 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    remove caliper bolts and slide out caliper, pop old pads out and use a C clamp to press in the caliper plunger til it's flush with the caliper. pop new pads in, use the grease on the backs of all the moving parts but not the material side of the pad or rotor. clean off the rotor if you touched it. slide caliper back on and re tighten bolts, profit.
  12. May 14, 2011 at 9:05 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Just be happy it doesn't need rear brakes:D
  13. May 14, 2011 at 9:21 PM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    This is what I do, C clamp ftw! Except, I leave the old 'plunger' side pad in while I'm using the clamp, this way the cylinder isn't damaged in the process. The old pad get's all the force and scaring. I realized this worked better for me after I chipped a ceramic plunger.
    Also pop the break fluid reservoir cap before using the C clamp, this let's the fluid easily flow back up to the reservoir.
  14. May 14, 2011 at 9:27 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    That is a good idea, i'll do that next time (the old pad on the plunger part) I accidentally left out the take the cap off the res part.
  15. May 14, 2011 at 9:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I pop the cap of the fluid reservoir and use a huge set of channel locks to compress the plunger, mostly because all of our c clamps are 12".
  16. May 16, 2011 at 1:17 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just a word of warning, that video makes things look a hell of a lot easier than they can be. Hopefully being in North Ca. your pins won't be too rusted, but over here in new england mine were so badly rusted in that I had to use a dremel to cut them out and then use a drill to drill out one piece of the pin. It took me most of an entire day to get them out. I put anti sieze on them before putting the new pins back in, so hopefully next time it won't be too bad. Compared with my wifes Honda the Toyota's are a PITA.
  17. May 16, 2011 at 4:41 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Always use 3m copper caliper lube. Regular antiseize will gum up rapidly and cause the pads to stick. Antiseize is for bolts.
  18. May 17, 2011 at 8:11 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    what's the torque for the caliper bolts?
  19. May 17, 2011 at 8:39 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I trust you and not disagreeing, but I used standard spark-plug anti-seize and haven't had a problem, that was 2 years ago.
  20. May 17, 2011 at 9:12 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The dielectric grease for the boot, or anti seize for the threads?
