1st gen axle nut size?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Inverno4, Jul 17, 2013.
  1. Jul 17, 2013 at 3:50 AM
    Inverno4
    Inverno4 [OP] Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    Anyone know if its 35 or 36mm for an '04 4WD 3.4L? There are conflicting reports on various sites that it could be both. The FSM doesn't seem to show it (or I couldn't find it in there).
  2. Jul 17, 2013 at 4:15 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2013 acces cab TRD offroad M/T 4wd
    I have an 03 4x4 double cab and the nut on mine was 35mm.
  3. Jul 17, 2013 at 6:28 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    All the OEM CV nuts I have seen, dozens and dozens, were 35mm. I have seen some "rebuilt" shafts come with new nuts that were 36mm.
  4. Jul 17, 2013 at 7:19 AM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    Good to know. The shaft is a reman one from Autozone, so possibly its the 36mm.
  5. Jul 17, 2013 at 7:21 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
  6. Jul 17, 2013 at 7:53 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Ditto here, back when time began all I had was a 36mm and it worked just fine, frankly on that big of a nut it did not seem that loose at all.
