1st Gen 3.4 Vacuum Hose Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jnorris, Mar 19, 2019.
  1. Feb 24, 2020 at 9:30 AM
    #161
    GQ7227
    GQ7227 mw survivor
    J A Y
    i guess NY does not have a 'color code'?
    ... think i read previously somewhere that CA is forced to use all black for smog inspections :notsure:
  2. Feb 24, 2020 at 9:32 AM
    #162
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    Never heard of color code in NY or any other state :D
  3. Feb 24, 2020 at 11:51 AM
    #163
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    Color doesn't matter in CA smog, but all the EVAP bits and bobs need to be there.
  4. Feb 24, 2020 at 11:52 AM
    #164
    hunt_taco70
    hunt_taco70 Member
    Trent
    2001 Tacoma double cab 4x4
    Toytech
    Been waiting forever for the black ones to be in stock. Thinking about just ordering blue.
  5. Mar 4, 2020 at 7:29 PM
    #165
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    The Silicone intakes dress up kit will cover all the vacuum lines correct? I just ordered it
  6. Mar 5, 2020 at 4:17 AM
    #166
    vettehigh
    Jon
    Upstate, NY
    Did for me with plenty left
  7. Mar 5, 2020 at 4:18 AM
    #167
    TacomaEli
    Eli
    Roanoke, Virginia
    Ok cool
  8. Mar 8, 2020 at 5:45 PM
    #168
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    Just used this kit and got a few extra ft of 8mm. And had a decent amount left over and everything fit great, hoses felt nice, and seemed to be good quality. Definitely recommend.
  9. Mar 15, 2020 at 5:19 PM
    #169
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    Pulled the trigger on my kit today. Here's hoping that it makes it before Christmas.. :rolleyes:
    I need to adapt an older style intake hose to my truck as well, since I really don't feel like spending an extra $100 just for a barely different hose. Hopefully that and the vacuum lines will address a pending P0442 code I keep having to reset with my ultra gauge.
  10. Mar 15, 2020 at 6:21 PM
    #170
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    https://parts.olathetoyota.com/p0442-code-toyota
    Frog4aday likes this.
  11. Apr 14, 2020 at 5:52 PM
    #171
    MedicMutt
    Josh
    Baton Rouge, LA
    It seems that my air intake hose is of a different design from most other 3.4 liter Tacomas. That lead to some headaches during my vacuum hose refit, but thankfully some hardware store plumbing parts appear to have corrected my problem.
    Old
    I'm guessing this stupid thing was strictly for noise abatement.
    New setup
    Hooray cheap plastic fittings!
  12. Apr 28, 2020 at 1:33 PM
    #172
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I did this job over this past weekend. I used about 9ft of 8mm hose and 2ft of 6mm hose from siliconeintakes.com. I also ordered some red 10mm hose for the brake booster line, but decided against installing it. The OEM hose (44773-04020) is 50% thicker and wasn't in that bad of shape, and I didn't want to downgrade with the thinner silicone hose.
    I replaced the clamps on all the hoses and put in a new PCV valve, grommet and ventilation cap. The old clamps were rusty and ugly and I wanted to retain the OEM look as much as possible.
    The old PCV valve seemed to function just fine although the old grommet was a PITA to remove. The heat had hardened the rubber into something that more resembled plastic.
    Here's the overview of all of the hoses I replaced. It's possible I mislabeled one or more of the evap components, still learning my way around the evap system. Appreciate any feedback. This is for a 2004 3.4L Taco, the older ones seem to have different evap setups.
    6mm
    - Intake Resonator Hose, 9" long, no clamps
    - Radiator Overflow Tank Hose, 8" long, 2 clamps
    8mm Hoses
    - Airbox to Vent Valve, 43" long, 2 clamps
    - Purge Valve to Throttle Body, 22.5" long, 2 clamps
    - Purge Valve to Surge Tank, 1.5" long, 2 clamps
    - Surge Tank to Service Port, 2" long, 2 clamps
    - Service Port to Fuel Tank(??), 5.75" long, 2 clamps
    - Vent Valve to Fuel Tank, 9" long
    - PCV to Throttle Body, 8" long, no clamps (DON'T USE silicone for this one!)
    - Radiator Overflow Tank Drain Pipe, 9" long, no clamps
    Clamps
    - 10 x 8mm hose clamps (96132-51300)
    - 2 x radiator hose clamps (90069-19014)
    - 2 x brake booster hose (96133-41500)
    [EDIT] After having these installed for several months, I've noticed oil seeping through the PCV to throttle body hose. I don't think silicone is suitable for this hose, and I've replaced it with 1/4" ID fuel line. You should be able to buy fuel line by the foot from most auto parts stores.
  13. Apr 28, 2020 at 4:00 PM
    #173
    Bend_corners
    Bend_corners Well-Known Member
    Jim
    USA
    1995.5 5vzfe medium quartz Xtracab
    Super clean man good work.
    Black97v6MT and CrustyTaco like this.
  14. Aug 25, 2020 at 9:13 AM
    #174
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    Did anyone do any of the lines under the truck going to the canister?
  15. Aug 25, 2020 at 10:09 AM
    #175
    CrustyTaco
    Todd
    Louisville, KY
    Not yet, but I just ordered a set of gaskets for the gas tank, and will be pulling my bed to replace here in the next month or two. I am chasing a P0456 (small evap leak) code, and I suspect that I have a bad sending unit gasket. While I have the bed off I intend to change all of the vacuum hoses for the canister. I will update this post with the details once I get them replaced.
    Black97v6MT likes this.
  16. Aug 25, 2020 at 10:57 AM
    #176
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I forgot I had ordered a kit from these guys for my bronco which I no longer have, but the kit is still in a box somewhere. I’ll have to dig it out and see if I’ll be lucky enough to have the correct lengths in the correct diameters. Nice documentation @CrustyTaco !
    CrustyTaco likes this.
  17. Aug 25, 2020 at 12:16 PM
    #177
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Just ordered this same kit.
    I ordered the red, not because I want to be fancy, but because the black was back ordered, and I didn't feel like waiting. So, fancy red it is...
    Price was also still the same (shipped) as it was in the OP: $49.43
  18. Aug 25, 2020 at 12:30 PM
    #178
    Al786
    Al786 New Member
    Al
    2002 Toyota tundra SR5
    Can I ask what size tubing and attachment you used? I seem to have the same air intake as you. And the OEM part for the vacuum hose is a preformed and has two different size outlets.
  19. Aug 25, 2020 at 1:14 PM
    #179
    tacotime1
    tacotime1 Well-Known Member
    I just did the one from the air box to the pressure valve and it resolved my small vacuum leak detected. I had it wrapped in electrical tape for years but I guess it finally got too worn.
  20. Aug 26, 2020 at 9:52 AM
    #180
    MedicMutt
    Josh
    Baton Rouge, LA
    I think the hose is the 10mm from the silicone intakes.com kit. The plastic part is a hose barb from a local hardware store. I can't remember the exact diameter, but I believe it's NPT to a standard hose barb.
