1st Gen. 3.4 V6 Transmission drain n fill fluid capacity
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roadeater, Dec 5, 2015.
  1. Dec 5, 2015 at 11:25 AM
    Roadeater
    Roadeater [OP] Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    3.4 V6 pre-runner sr5 automatic transmission.
    I read many treads about how much fluid should go when draining and filling without dropping the pan and changing filter.
    I did mine 2 times using T-IV from toyota . No dropping pan. When I refilled it always took around 4.5 qts of fluid to get to th HOT mark on th dipstick with engine running.
    I went to toyota dealership, they said it only takes 2.7 qt.
    Is the manual wrong?
    Is the dealer only putting 2.7 when the correct should be more then 4?
    Lukass and opteron like this.
  2. Dec 5, 2015 at 12:01 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    According to the FSM, its 1.7qt drain and fill, 7.6qt dry fill (if you removed the tranny out from car and tipped it on end).
  3. Dec 5, 2015 at 12:47 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    It is approximately 4 quarts for a drain and fill. I did mine just a few months ago (2003 3.4L). I poured all the drained transmission fluid into a 1 gallon milk jug and the carton was just short of full. I put four quarts of the Toyota T-IV back in and she is golden. I had seen the drain and fill listed as about two quarts, but everyone that had actually done it said 4 quarts. I filled the milk carton to double check.
  4. Dec 5, 2015 at 7:16 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    4+ quarts here.
    2001 4x4 auto 3.4.
    nearly 5 quarts all told but i squirted some through just to flush the bottom better.
    Roadeater[OP] likes this.
  5. Dec 6, 2015 at 7:42 PM
    hondamxracer
    hondamxracer Well-Known Member
    4.25 and 4.5 on the last two drain and fills on my truck at the hot mark.
    Both times I added 4 quarts then drove a bit to warm up the trans. Then added .25-.5 to reach the full side of hot range.
  6. Jan 19, 2018 at 11:32 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    How do we re fill the transmission fluid ?? Through the dip stick?
  7. Jan 19, 2018 at 11:42 AM
    fenmik
    fenmik Well-Known Member
    Nova Scotia, Canada
    2019 Double Cab TRD Sport.
    Yes just refill through the dipstick. A funnel makes this much easier.
    Lukass likes this.
  8. Jan 19, 2018 at 11:45 AM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    What about changing the filter? I have the 95 4x4 V6 Auto and it calls for filter 35330-22010
  9. Jan 19, 2018 at 12:06 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    have to take the pan off the bottom. you'll need an additional 3 quarts (won't need all 3 but extra just in case) if you do a pan drop and filter change.
  10. Jan 19, 2018 at 1:15 PM
    vettehigh
    Jon
    Upstate, NY
    So I will need 5 total quarts or just 3 of Toyota T-IV to do complete pan drop and filter?
    Also, do I need Toyota Fluid 00295-00103 Formed-in-Place Oil Pan Gasket for the pan? Thanks for all your help
  11. Jan 19, 2018 at 1:22 PM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2013 acces cab TRD offroad M/T 4wd
    Best method every time I replaced it in my Tacoma, was use an empty gallon water jug. Put one quart marks on the side of the jug. Drain it into the jug with a funnel or drain it in a pan and pour it in the empty jug so you will know how much you drained out of your tranny. This will give you an estimate of how much oil to replace.
  12. Jan 19, 2018 at 1:37 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    When I did my drain and fill it took almost 4/1/2 to get it back to where it needed to be. Auto 3.4/4wd
  13. Jan 19, 2018 at 2:24 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    It's not that hard to do a flush. Disconnect "Out Line" at the radiator. Replace with a longer one to empty into a bucket.
    Start engine run briefly. Shut off. Add transmission fluid to trans dipstick. Start motor briefly, shut off.
    Repeat till you have clean fluid coming out.
    Rocket86 likes this.
  14. Jan 19, 2018 at 2:26 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    pan drain is exactly 4 quarts T-IV and a new drainplug gasket.
  15. Jan 19, 2018 at 6:20 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I had a little over 6.5 quarts with drain and taking the Pan off. I also used a new filter as my fluid was dark and it was worth the $30 to get a new one.
    this is what I used:
    https://www.amazon.com/gp/product/B000C8R9RM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B00BLKXW9O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I have a little over 5 quarts left
    NikkoCharger likes this.
  16. Jan 23, 2018 at 11:44 AM
    vettehigh
    Jon
    Upstate, NY
    Just called my dealer for fun and they told me that to drop the pan (95 V6), clean screen, and refill (up to 5 quarts) will cost a grand total of $313 tax included :eek:
  17. Jan 23, 2018 at 11:52 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    rdiddy_25 and vettehigh like this.
  18. Jan 23, 2018 at 12:01 PM
    01GreenTacoma
    Ouch! I did mine at home for 45$.....
  19. Feb 3, 2018 at 10:32 AM
    vettehigh
    Jon
    Upstate, NY
    1995 4x4 Auto V6
    I just picked up 6 quarts of Castrol Transmax Import Multi Vehicle ATF fluid today. Is Castrol good enough? I have a new OEM filter/OEM drain plug/OEM drain plug gasket. Will change this week
  20. Feb 3, 2018 at 12:38 PM
    gearcruncher
    Canadain bumper technician
