1jz swap on 2002 5 lug taco any advice or comments?
Discussion in 'Street Trucks' started by tacowhore, Aug 5, 2012.
  1. Aug 9, 2012 at 8:58 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    These guys both have very valid points. swapping in the 2 is probably going to end up being way too much work. You will probably be just as happy and save yourself weeks of work if you upgrade all of the internals and throw on a turbo with a lot of boost. Turbosvare fun as hell and the 2rz handles boost well. I really think that would be your best bet.
  2. Aug 10, 2012 at 2:18 PM
    tacowhore
    tacowhore [OP] Active Member
    ricky
    hamilton On.
    02 tacoma feeler
    lowering kit K&N cold air intake
    Well I'm gonna do my research, regardless I need another daily beater before I do any major mods.
  3. Aug 10, 2012 at 5:06 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    The supercharger kits are out there. Mjbtaco had one at one point. There were trd and lce kits made.
  4. Aug 11, 2012 at 7:17 AM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    Do you think they are really worth it compared to a turbo in respect to power gains?
  5. Aug 21, 2012 at 3:09 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I had a stock internal 2RZ running 18psi for almost 2 years with no problems with a GT3076R Ball bearing turbo, probably making a little over 300hp to the wheels, however I was using a standalone for engine management.
    Built a full turbo motor and was shooting for 30+psi, the WG failed causing a boost spike (over 40 psi) and th short of it is I parted the motor and accessories out.
    Bought an LS1 with a T56 trans and fabbed it in, now i am starting at 300horse and going up from there, going turbo soon. (Dyont even try to do it unless you have large pockets)
    Your better off boosting the stock motor if you dont have much experience, however you had better know what your doing or find a friend who knows whats up to help you out.
  6. Aug 21, 2012 at 5:00 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    I wish there was a definitive guide to a 2rz turbo install. List of parts, prices, etc
  7. Aug 21, 2012 at 5:22 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    i personally prefer a 1j over the 2j. I did a 1j swap in my 7m and love that motor. Makes more then enough power, its lighter, it revs higher, its cheaper to build and maintain, parts are just as common as a 2j, and imo theres nothing that compares to the sound of a 1j with an open down pipe. Both motors are beasts, i just went with the 1j for those reasons. I also didnt do an engine sway between different vehicles either so my costs were a fraction of what u might spend! I hope u go for it though! Id love to do a 1j or 2j swap in my 2nd gen
  8. Aug 21, 2012 at 7:36 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    I was talking about a 2rz (the 2.4 that's already in my truck)
  9. Aug 21, 2012 at 7:41 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    They do. Most guys claim they can do just as good for less money with different parts
  10. Aug 21, 2012 at 7:48 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Damn it, I was beat to the punch.
  11. Aug 21, 2012 at 9:17 PM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    There's no definitive guide because every single part is debatable lol You can do better than LCE for less money though ;p
  12. Aug 22, 2012 at 5:36 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
