1jz swap on 2002 5 lug taco any advice or comments?
Discussion in 'Street Trucks' started by tacowhore, Aug 5, 2012.
  1. Aug 5, 2012 at 10:15 PM
    tacowhore
    tacowhore [OP] Active Member
    ricky
    hamilton On.
    02 tacoma feeler
    lowering kit K&N cold air intake
    i have the itch to beef up my taco. wondering what everyone thinks about a 1jz swap?
  2. Aug 6, 2012 at 2:35 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That would be bad ass. Check out supra trucks for their 2jz swap SR.
  3. Aug 6, 2012 at 7:41 AM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    is there much difference between the 2jz and the 1jz?
  4. Aug 6, 2012 at 3:53 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yes
  5. Aug 6, 2012 at 3:55 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Why not just weld an inline twin onto the front of your current motor? Helluva lot easier
  6. Aug 6, 2012 at 3:59 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    I've always been interested in dropping an inline N/A 6 cylinder into my taco....
  7. Aug 6, 2012 at 10:11 PM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    im a noob, inline twin?
  8. Aug 7, 2012 at 12:11 PM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    I haven't looked into the 2jz mainly because I was concerned about the price!
  9. Aug 7, 2012 at 2:24 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    LOL if you don't have deep wallet don't attempt engine swap and leave your truck alone.
  10. Aug 7, 2012 at 3:37 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    All those motors are more than enough. My friend pulled his 7mgte and put in a 1jz, his supra was quick. I'd get the 1jz over a 2jzge with a turbo kit slapped on it. If its feasible for you, get the 2jzgte, most parts will be easier to find in the states as opposed to sourcing out parts overseas for the 1jz. Install a good headgasket and studs before dropping it in so you won't have to do it later. Just make sure it has enough fuel and you shoudl be fine. Gonna be more power thatn you can put down anyway, sounds like fun!
  11. Aug 7, 2012 at 10:48 PM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    nvm aha ive done my research, still not a seasoned vet tho
  12. Aug 7, 2012 at 10:51 PM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    i cant get a rebuilt 2jzgte with tranny harness and ecu for 2600
    that do you guys think of that?
  13. Aug 7, 2012 at 10:57 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    ^^ Seems like a decent price. By decent I mean average. You also have to remember when you're adding more power, especially to these little 5 lugs you're putting stress on everything else. A stock tranny and clutch would take a shit at some point. And that wimpy 7.5" rearend just isn't enough.
    I know a lot of turbo guys run a mustang/explorer/ranger diff in their trucks. (same bolt pattern for the wheels)
  14. Aug 8, 2012 at 1:01 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    you're not really thinking the swap through. its going to be a ton of work to just get the motor in. its not just a bolt in and go type swap. you need to cut up some stuff, beef up your diff, change your drive shaft, get custom mounts made. most likely run a stand alone ecu.
    you're gonna be into it close to 10k because you cant just swap in the motor and be done with it, you need to upgrade your brakes or your truck will never stop, need to beef up your suspension. it's a ton of work. but like i said before, if you have the means to make it happen then go for it. i would LOVE to swap in a 2jz into my truck some day. and like everyone else says, 2jz or nothin.
  15. Aug 8, 2012 at 1:07 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    If you can't handle a mostly bolt in turbo setup, you're doomed on an engine swap.
  16. Aug 8, 2012 at 6:42 AM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    Well we shall see. I'm still weighing my options. To me tho the swap
    Is preferred for sure. Thanks for all
    Your advice guys
  17. Aug 8, 2012 at 7:09 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
    You're probably better off going the turbo or supercharger route. That's what I'm hoping to do eventually.
  18. Aug 8, 2012 at 7:40 AM
    05RedTaco
    Tony
    Scottsdale
  19. Aug 9, 2012 at 8:38 AM
    tacowhore
    ricky
    hamilton On.
    02 tacoma feeler
    I haven't found a super charger for my model but I did find a turbo kit on lcengineering. Same price as the engine tranny harness and ecu!
  20. Aug 9, 2012 at 8:46 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It is about time! I was waiting for someone to post that picture.
    Well done.
