1GR-FE F/I Mods and Dyno's
Discussion in 'Performance and Tuning' started by Torspd, Dec 15, 2016.
  1. Jun 12, 2017 at 4:54 PM
    #61
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Forgot to mention that the dyno was done at 4th gear, I'd assume i have a slight amount more than 300 hp when in 5th gear....correct?
  2. Jun 12, 2017 at 4:57 PM
    #62
    Camby
    Brian
    Denver
    Shortly after installing the tune, I kept running into posts complaining the AFRs were dangerous on this website. So I rushed to get it dyno'd to check and make sure I wasnt potentially going to blow up my engine.
    Torspd[QUOTED][OP] likes this.
  3. Jun 12, 2017 at 5:06 PM
    #63
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Being 1:1 in 5th, yes. However, using fourth prevents you from hitting the speed governor on the dyno. Plus, fourth is close enough to 5th.
  4. Jun 12, 2017 at 5:07 PM
    #64
    Torspd
    Tor
    The Great America!
    Magnuson's tune is independant of Bully Dog's. Just uses their device to load the firmware.
  5. Jun 12, 2017 at 5:08 PM
    #65
    Camby
    Brian
    Denver
    Im just grasping at straws to justify I have more HP than whats shown :p
  6. Jun 12, 2017 at 5:09 PM
    #66
    Camby
    Brian
    Denver
    correct, so whenever points the blame at BD for their SC tune not going the way they want, it's really Magnuson's tune
  7. Jun 12, 2017 at 5:10 PM
    #67
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    Idk, are you sure? I've gotten indications pointing both ways. BD is supposedly revising a tune for me, not Magnuson.
  8. Jun 12, 2017 at 5:11 PM
    #68
    gersus
    Missouri
    14 Tacoma DCOR
    Using the 3" pulley seems ok. Using smaller pulley brings the issue.
  9. Jun 12, 2017 at 5:22 PM
    #69
    Torspd
    Tor
    The Great America!
    Bully Dog and Magnuson have their own independant tunes.
  10. Jun 12, 2017 at 5:36 PM
    #70
    Camby
    Brian
    Denver
    They do? For superchargers?
  11. Jun 12, 2017 at 5:38 PM
    #71
    Torspd
    Tor
    The Great America!
    Quoted it earlier, from Gadget at URD. Don't remember which thread I posted it in.
  12. Jun 12, 2017 at 5:45 PM
    #72
    Torspd
    Tor
    The Great America!
    From Gadget on XRU. Quote,"
    [Gadget, post: 988181, member: 15"]URD stocks the Magnuson supercharger kits.
    The 4.0L system is sold two ways:
    1. One with tuning. This one is CARB approved and comes with full warranty.
    2. Without/Tuning. This one is not CARB approved. Does not come with a warranty.
    The CARB approved tuning version uses Magnuson's own proprietary calibration file and uses the included BullyDog device to flash your stock ECU.
    URD has done some testing and the Magnuson calibration file is different from the Toyota/TRD dealer reflash. It is mostly in the VVTi system and it does not make as much power.
    URD does have a calibration file for our UCON-EMS that will cover either the Toyota/TRD reflash, or the Magnuson Reflash, or even NO REFLASH at all. The UCON can run that Supercharger better than either reflash.
    OK, options. If you live in California you should purchase the version with tuning so you can get the CARB sticker. If you do not get the version with tuning you cannot get the CARB sticker. Toyota is not supposed to flash your ECU is you do not have a TRD version. Yes, some people with contacts are getting their's reflashed at the dealer. Just remember you cannot unflash it and go back to stock.
    You can get the Magnuson and the UCON and that makes a great combo.
    Of course the URD Supercharger system is still the best......
    If anyone has any questions, let me know."
  13. Jun 14, 2017 at 10:17 PM
    #73
    Guns 'n Tacos
    Guns 'n Tacos Well-Known Member
    Georgia
    Does anyone have a video of the exhaust cam gear installation with the new UCON?
  14. Jul 5, 2017 at 10:34 AM
    #74
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    No, but you can look at the apr one on youtube
    Guns 'n Tacos[QUOTED] likes this.
  15. Jul 24, 2017 at 5:38 PM
    #75
    FroadinTaco
    FroadinTaco Member
    JJ
    2014 Tacoma - Black
    BFG AT Method Wheels Flowmaster Exhaust
    At the end of the day though, can this cause issues with my warranty at the dealer? Since neither are a TRD product, could I ever run into issues?
  16. Jul 24, 2017 at 6:26 PM
    #76
    gersus
    Missouri
    14 Tacoma DCOR
    Yep, I would say so.
  17. Jul 24, 2017 at 7:27 PM
    #77
    Torspd
    Tor
    The Great America!
    Unplug it.
  18. Sep 29, 2017 at 10:26 AM
    #78
    Torspd
    Tor
    The Great America!
    @Billy182 his TRD s/d 1GR X-Runner.
    Quote, "My dyno sheet, overall a little disappointing, it looks like the belt was slipping at around 3800 rpm. Ambient temps were 85 degrees
    ," End quote.
    Biscuits likes this.
  19. Oct 24, 2017 at 10:46 AM
    #79
    BATMANs
    BATMANs Member
    Tacoma X-Runner (coming soon)
    Apologies for bringing up an old post.
    If I am reading this right - the aforementioned power to the wheels is made with the Roots style blower?
    I thought they had a limit of right around 300rwhp and for more power the URD Rotrex was the only blower solution for more power.
    Sorry if this has been covered before and I missed this.
  20. Oct 24, 2017 at 1:55 PM
    #80
    Camby
    Brian
    Denver
    At stock yes, around 300 hp, but if you replace the pulley with a smaller one (rotors spin faster => more boost => more power)
