17x8 or 17x7 TRD Pro Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by justintackitt, Jan 17, 2019.
  1. Jan 17, 2019 at 7:42 PM
    justintackitt
    justintackitt [OP] Well-Known Member
    2016 Tacoma DCTRD4X4
    Will be swapping out my original OR wheel with a TRD pro wheel. Will be going either 275/70/17 or 285/70/17. I’m thinking I would like the 8” wide version over the 7” wide. Both show 5mm offset. Is it safe to say the 7” would be less prone to any rubbing? I Was going to try the 275 on stock suspension no lift and if it rubbed then do an OME 2” lift. Or the other option was the 285 with the OME lift.
  2. Jan 17, 2019 at 7:45 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    The extra inch does push the tire out 1" so it is closer to the outside of wheelwell. Many people run the 8" including my wifes rig. It clears fine but.my wheels do have a -10mm offset to bring it back in a bit.
  3. Jan 17, 2019 at 8:00 PM
    rasber3140
    rasber3140 Well-Known Member
    2021 TRDOR Barcelona Red
    Where are you seeing 8 inch TRD Pro wheels at?
  4. Jan 17, 2019 at 8:04 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    The Pro wheels only come in 17x7 dont get screwed over
  5. Jan 17, 2019 at 8:11 PM
    justintackitt
    Thank you for the info!
    The 8” version is on eBay and are knock offs. Seems to have sold quite a few with positive feedback.
  6. Jan 17, 2019 at 8:22 PM
    SpeySquatch
    2016 TRD OR DCSB
    To agree and add to El Duderino,
    the 17” 4Runner PRO wheels (which are 7” wide) a 255/75/17 tire aligns perfectly within 1/8” to the edge of the fender, so any increase in tire width will just increase that much out of the fender.
    Example, if I go from my 255/75/17 to a 265/70/17 the tire will stick out 1/4” even though it’s 1/2” wider tire. The tire sticks out 1/4” on both the inside (towards differential) and outside (away from truck)
    From the back
    From the top
    From the side
    El Duderino[QUOTED] likes this.
  7. Jan 17, 2019 at 8:24 PM
    JayRolla
    Colorado Springs
    waterlogged77 likes this.
  8. Jan 17, 2019 at 8:31 PM
    El Duderino
    Jeremy
    HI->PNW
  9. Jan 17, 2019 at 8:32 PM
    El Duderino
    Jeremy
    HI->PNW
    Same set up
    SpeySquatch[QUOTED] likes this.
