16x8 or 17x8 wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rideawalrus, Oct 29, 2018.
  1. Oct 29, 2018 at 1:43 PM
    rideawalrus
    rideawalrus [OP] Well-Known Member
    Four Corners area
    '16 TRD OR 4x4 Prem Tech/JBL Blazing Blue, King coils/shocks, deaver leafs
    King coils/shocks, deaver leafs Pelfrey skid soft topper Nalgene holder
    I finally found and decided on a new set of wheels I like, now the question is stick with 16 inch or go to 17. Ill be running 33 inch KO2s, at 59 or 58 pounds each, with the 24 pound wheel. I do a good amount off offroading, but not as much rock crawling. I usually drop the pressure on my current e rated ko2 to around 22 pounds for it.
    Any advice in wheel size in this situation? Gas mileage differences between the two? Other input?
  2. Oct 29, 2018 at 5:23 PM
    RustyTacos
    RustyTacos Well-Known Member
    CJ
    kentucky
    17 MGM TRD Sport 4x4 MT
    More sidewall is better for offroad right? I would probly base my decision more on tire prices for each size wheel, that may be pretty close tho.
  3. Oct 29, 2018 at 5:25 PM
    rideawalrus
    Four Corners area
    Yes more sidewall is nice if you want to run really low, but I'm thinking with that much sidewall on either size as long as I'm not wanting to go into the lower teens with pressure there wouldn't be much difference? Cost is 200 vs 220
  4. Oct 29, 2018 at 5:28 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Agreed...I'd go 16"
  5. Oct 29, 2018 at 5:31 PM
    RustyTacos
    CJ
    kentucky
    If its only a few pounds difference between the sets i dont think there will be much of a difference in mpg, decision might just come down to which you think looks better i think 16s look alittle small for 3rd gens but thats up to you.
    Mtn_man_mike likes this.
  6. Oct 29, 2018 at 5:52 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I personally like more sidewall, makes the tire look chunkier and meaner
  7. Oct 29, 2018 at 6:00 PM
    RetiredSCPO
    RetiredSCPO Well-Known Member
    Will
    Seven Cities
    2017 Tacom TRD Off Road Double Cab-Silver
    Stock
    Opinions are like......
    Here is what I know coming from the Jeep TJ Rubicon world....there are far more tire size choices with a 17 " wheel than 16's. As far as air pressure I routinely aired down to 10-12 psi rock-crawling and never lost a bead, not that it won't happen, it will eventually. 22 PSI? all day long....
  8. Oct 29, 2018 at 6:01 PM
    IowaQuicksand
    IowaQuicksand Well-Known Member
    Iowa
    18 Quicksand DCSB OR 6MT
    I personally am a 16 fan. You don't see them much anymore and I think they just look meaner
  9. Oct 29, 2018 at 6:42 PM
    Sharpish
    Brian
    He's right about more tire size options with 17".
    275/70-17
    255/75-17
    34x10.5x17
    And especially when you go really big like 35/37 options are very limited with 16".
  10. Oct 29, 2018 at 6:54 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    I went with 16s, but wanted to stay with p or c tires. Just 265 75 16 which are available with p rating. If you jump to 285 and don’t want lt tires, go with the 17s. No 285 75 16 available that aren’t lt. Quite a few p or c rated 285 70 17. Also be careful with balancing weights. Front stick on weights got knocked off by the calipers so they had to use hammer in weights on the inside of the wheels.
  11. Oct 29, 2018 at 7:01 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    16’s are better. Mine look nice and big. 16x8 -25 on 285/75/16.
    My wheels weigh 19lbs
    My tires weigh 59lbs. Can’t beat this combo. And I air down to about 13psi when I crawl/offroad.
  12. Oct 29, 2018 at 7:04 PM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
  13. Oct 29, 2018 at 7:04 PM
    jerryb1984
    Jerry
    285 70 17 bfg in c are 50 pounds. Not listed on their website, but are for sale on eBay and can find the weights online.
    Could also find some rubicon takeoffs for cheap.
  14. Oct 29, 2018 at 7:29 PM
    BetaTaco
    BetaTaco Built like a steakhouse, handles like a Bistro.
    Northern Virginia
    2016 SR5 V6 4X4 DCSB
    same shit as everyone else
    I would just keep in mind that your wheels and tires are a part of your suspension. 16" wheels may be bouncier than 17" wheels with 33" tires. That is a lot of rubber on the sidewall either way though. Not a great scientific tire for tire comparison but my ride firmed up quite a bit on stock suspension when I went from 16" SR5 alloys with 245/75/16 Firestone LE2 to 17" 4Runner alloys with 265/70/17 standard load Falken AT3W. The new tire is way beefier and has a higher load index so that obviously contributed to a firmer ride as well.
  15. Oct 29, 2018 at 8:14 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Not bouncy at all.
  16. Oct 29, 2018 at 8:15 PM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    If that were true then everybody with tires larger than a 33 would have a bouncy ride and that’s just not the case,
  17. Oct 29, 2018 at 8:19 PM
    rideawalrus
    Four Corners area
    I think I want to stick with E rated tires for off road durability, I have put a lot of rocks into the sidewall and there are a a lot of sharp rock areas here. I won't ever be going bigger than 33s, 285/75 r16 or 285/70 r17s. That does suck weight wise, but it's better than getting flats. I run King suspension with helps a lot with roughness, but a 16 would have that little extra absorption. It'd be nice if there was a lighter tire that has the strength, traction, and road driveability of the KO2, but I havnt really found one that has it all yet
    Thanks for the insights and constructive thread guys, keep it going if you have other thoughts.
    Pics of those two sizes could be nice to compare too if you've got them.
  18. Oct 30, 2018 at 12:11 AM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    I went with 17's. Better tire selection and I plan on doing big brakes later down the road.
  19. Oct 30, 2018 at 12:59 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    When you do off road, how much must, vs sand, vs rocks? Worth considering.
    17" pick up dings because of the lower sidewall ratio. This matters if they are powder coated vs painted and thus harder to hide scratches.
    Hard to say you will regret one vs the other.
  20. Oct 30, 2018 at 2:03 AM
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    285/75/16 STT Pros DOMINATE off road and for me they have been comfortable, well mannered, daily driven road tires too. And they only weigh 59 lbs in that size. Impressive.
    Ctupton likes this.
