15inch rims? On 2003 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Freddy435, Aug 5, 2015.
  1. Aug 5, 2015 at 7:55 AM
    Freddy435
    Freddy435 [OP] New Member
    Freddy
    2003 tacoma
    2.5 inch leveling kit light bar
    Hey guys so i was hearing A lot of controversy about 15 inch rims fitting on2003 tacomas because of somthing with the brakes im not sure if this is true. the wheels im looking at to trade Re in the link btw let me know if u guys think these will fit fine. http://capecod.craigslist.org/pts/5130994438.html
    Btw they r tundra rims and i was gunna put wheel spacers too
  2. Aug 5, 2015 at 8:25 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yes, the brake calipers are big and need a lot of room so if you go to 15" rims they will nearly touch or might not even let the rim go one depending on which rims you get.
    it never hurts to try but to fit 15" rims I think you need the 5 lug calipers and spindles which wont work on prerunner or 4wd
  3. Aug 5, 2015 at 8:44 AM
    Freddy435
    Freddy
    2003 tacoma
    Thanks it helps alot
  4. Aug 5, 2015 at 4:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I did not like the star pattern of the later first gen Tacomas. I took the 16" stock wheels off my 2003 Double Cab and swapped them for earlier 15" Tacoma wheels I found for cheap on craigslist. They cleared fine, and then I was able to run lighter floatation 31x10.5" tires.
    I ran these, from a 2000 Tacoma.
  5. Aug 5, 2015 at 4:49 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    the first 2 sets of 15 inch wheels i tried did not fit, the 3rd did!! it depends on the wheel like said above.
    Im all for trying to fit 15s....
  6. Aug 5, 2015 at 4:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  7. Aug 5, 2015 at 5:24 PM
    keakar
    karl
    louisiana
    so which wheels fit? what year and what did they come off of?
    inquiring minds want to know because lots of others would like to use 15's
    I know I would have done it if I knew what to use before I bought new tires all around
  8. Aug 5, 2015 at 5:28 PM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Those are Tacoma wheels. I don't think any Tundras came with 15's. Those look exactly like the 15 inch wheels that came on my 2003. They will fit fine.
  9. Aug 5, 2015 at 5:38 PM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    they were american racing ATX chamber wheels, teflon coated. they no longer make the ones i have....
    Running Board Man likes this.
  10. Aug 5, 2015 at 5:40 PM
    keakar
    karl
    louisiana
    oh, I thought you found an oem set that fit, oh well, like you said, keep trying until you find something that fits
  11. Jan 15, 2018 at 2:50 PM
    jahsonferg
    jahsonferg Member
    new hampsha
    96 3.4 one ton almost
    I kno that 96 through 99 at least came stock with 31 10.5 15s. But my 01 has 16.s stock gonna try 15s tonight got some new 235 75 15s winters with studs with a 200$ parts truck 96. Someone put a new frame under from a 04 but motor was seized from (sitting) under valve covers it got pretty hot!!!!
  12. Jan 15, 2018 at 3:42 PM
    mccartyls
    mccartyls New Member
    Shawn
    1999 Toyota Tacoma SR5 extended cab
    I think I foumd the answer above, but just to make sure. I have a 1999 Tacoma but it has 14s on it. I am having issues finding 14 rims that I like and some of the 15s I can get a decent price on at tirerack. So 15s came stock? Leery of buying online and not being sure they will fit.
    Thanks for the suggestions!
  13. Jan 15, 2018 at 3:49 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW!
    Does your truck have 5 lugs or 6?
    They will require different wheels, I don’t think 14s fit on the 6 lug trucks.
    jahsonferg and mccartyls[QUOTED] like this.
  14. Jan 15, 2018 at 5:09 PM
    mccartyls
    Shawn
    Yes, 5 lug. Hoping I replied right...eeek! :)
  15. Jan 15, 2018 at 5:15 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    15's were on my 2000 stock.
  16. Jan 15, 2018 at 5:38 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    These 15 x 7 Enkei wheels fit my 2004 DCSB 4wd. I was running 31x10.50x15 mud terrain tires. Fit with no problem. I had them previously on my 1992 xcab.
  17. Aug 20, 2019 at 1:39 PM
    chickenboy1347
    chickenboy1347 Active Member
    Nathan
    2002 Tacoma PreRunner
    I recently put a set of the stock 15x7s on my 2002, no fitment issues. Not to mention tires are significantly cheaper too.
  18. Aug 20, 2019 at 3:00 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    They were a special package available only in Southeast and Gulf Coast dealerships in the early/mid 90’s.
  19. Aug 21, 2019 at 8:11 AM
    paetersen
    paetersen Well-Known Member
    These rims. Stock on 95.5-99ish tacomas and 4 runners, used on 4 runners maybe up to 03? Anyway, stock toyota rim, fits 1st gen taco, and many people are running them, including me. Should be fairly easy to hunt down a set for about 50 bucks a rim. Try car-part.com to search junkyards in your area.
    BestGen and Hamer95USA like this.
  20. Aug 22, 2019 at 2:34 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I used to run the original steel OEM wheels that my truck came with until about almost 3 years ago. I bought a set of used OEM 6 spoke aluminum alloy wheels with mold growing on it off of Craig's List, took it to West Coast Wheel Repair in Fremont, CA to have it cleaned/polished/powder coated in black. I'm happy with the way it rides and looks on my truck. That being said, I bought a set of used 16" OEM 6 spoke aluminum alloy wheels that came off of a late '90s 4Runner SUV that will be getting installed sometime in the future due to my need for having a LOAD E tires that will handle heavier weight capacity.
    BestGen likes this.
