12Volt.Solutions Remote Start and Smart Start
Discussion in 'Product Reviews' started by Jmk0601, Nov 26, 2017.
  1. Nov 26, 2017 at 4:54 PM
    Jmk0601
    Jmk0601 [OP] Member
    Jin
    2017 White Tacoma TRD Pro
    Stock for now
    I was googling around for remote start and came across 12Volt.Solutions. They offered fully plug and play remote start for 2016+ Tacomas in addition to keeping the OEM FOB. I didn't want to carry another fob around with me for remote start. Install was a breeze. Took about 20-30 min at most to complete the install. During the first time of the install, I broke off one of the pins because I wasn't careful enough. I didn't know this until auto headlights weren't working. When I hit up 12Volt.Solutions, I was told it was probably broken pin on the 30 pin connector. Lord behold, one of the pin was bent in the 30 pin connector, and it was the auto headlight connection. This was my fault, and I made that mistake because I wasn't careful enough. 12Volt.Solutions didn't argue with me or make me pay for a new harness or the shipping. They sent me a new one in 2-3 days. What a world-class customer service. I just installed the new harness and GPS smart start module today, and they all work flawlessly.
    https://youtu.be/j2m9EpbXDl8
  2. Dec 16, 2017 at 5:10 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    This does not use the OBD2 port correct?
  3. Dec 16, 2017 at 7:53 AM
    Jmk0601
    Jmk0601 [OP] Member
    Jin
    Stock for now
    It kind of sort of does? The t harness will connect to our OBD2 port but there is another open OBD2 port to put in place if you need to use it to read codes and whatnot.
    MCDavis[QUOTED] likes this.
  4. Dec 16, 2017 at 11:19 AM
    MCDavis
    RIC, VA
    Thanks. I have the ShiftSense Pro and obviously want to keep that and still use the remote start.
  5. Dec 16, 2017 at 12:34 PM
    Jmk0601
    Jmk0601 [OP] Member
    Jin
    Stock for now
    You'll still be able to use it!
  6. Dec 28, 2017 at 8:49 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    I also purchased and installed this plug and play solution. Like OP, I broke a pin in my harness and I gotta say, the customer service is superb! They attempted to trouble shoot and once they determined a new harness was needed, they immediately shipped a new one out. Works as described and I’m grateful for this amazing service.
  7. Jan 15, 2018 at 2:22 PM
    YorktownPatriot
    YorktownPatriot Member
    2016 TRD Sport 4X4
    Retrax PRO MX bed cover OEM bed mat Tuffy Security lock box 12Volt Solutions remote start Weather Tech mats & bug deflector Runnin4Tacos TRD PRO grille Runnin4Tacos amber grille light kit Raptor Series 3” nerf bars black
    My kit is on its way from Tulsa...will put it in next weekend. Thanks for the video and the comment about installation time and 12volt customer service. Cheers...
    remgu2000 likes this.
  8. Jan 29, 2018 at 2:38 PM
    Quicksander17
    Quicksander17 Well-Known Member
    Austin
    2017 Tacoma TRD Off-Road 4x4 Quicksand
    METAL: RRW Rock Sliders - https://www.relationsracewheels.com/collections/rock-sliders Body Armor Low Profile Steel Winch Bumper Body Armor Rear Steel Bumper DiamondBack Heavy Duty Aluminum Tonneau Ridge Runner Bed Rack System DV8 Low Profile Aluminum Roof Rack TRD Aluminum Skid Plate CBI Gas Tank Skid Plate PERFORMANCE: K&N Cold Air Intake K&N Throttle Controller Front Camera Emblem Mount and Backup Cam Controller LED Headlight Bulbs Pop n Lock Power Tailgate Lock Rear LED Tailgate Strip Reverse Backup LED Bulbs Sport Wing Door Ding Guards https://www.sportwing.com/FE-TACDC-Toyota-Tacoma-Double-Cab-Painted-Body-Side-Molding
    Anyone find a harness / remote start kit that doesn't shut off the engine when you open the door?
    I guess it might be a way to prevent someone from driving off without their key fob but it seems like this feature/problem could be eliminated if the doors would stay locked upon remote stop and only allow the doors to be unlocked with the key fob unlock button or hand on the driver's door sensor with fob in pocket..
    I'm sure everyone knows it's not good for the engine to shut down then to be started up again that quickly. It also wastes gas.
  9. Feb 4, 2018 at 3:05 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Hey guys, I installed this last week, works great. Only question is about the battery warning that comes with the kit, it says that when you disconnect the battery, and then re-connect it can try to start the car, and to ask the owner (me) how to disable it....
    So, if I want to disconnect my battery in the future I need to pull apart the steering trim again and unplug it? Anyone know more about this
  10. Feb 12, 2018 at 8:26 PM
    ORtrailtaco
    ORtrailtaco Well-Known Member
    17 TRD Sport
    Suspension & 285's
    I have this in my Tacoma and love it. I think they are referring to the toggle switch that comes with the kit.
    The toggle switch disables the module/system and returns the truck to factory basically.
    Bridge4 likes this.
  11. Feb 13, 2018 at 2:26 AM
    Bridge4
    MA
    Thanks, that makes sense and is easier than disconnecting everything.
    ORtrailtaco[QUOTED] likes this.
  12. Mar 17, 2018 at 9:11 AM
    dan_SD
    dan_SD Well-Known Member
    Daniel
    18' Cavalry Blue TRD PRO
    Sorry for bringing back and old thread and possibly a dumb question. So lets say you "remote start" your truck in the morning. Once you unlock and open your door the engine cuts off? You would then start the truck again upon getting in?
  13. Mar 17, 2018 at 9:12 AM
    Bridge4
    MA
    yeah exactly this. Is it a little annoying yea, but it saves your car from being stolen if you live in the city or are in a sketchy area, so I'd say the pro outweighs the con.
    dan_SD[QUOTED] likes this.
  14. Apr 12, 2019 at 8:13 AM
    Taco_N00b
    Taco_N00b Member
    2018 DCSB
    Only if you want to drive it.
