128k Miles and losing its mind
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sheppington, Jan 25, 2020.
  1. Jan 25, 2020 at 11:52 AM
    Sheppington
    Sheppington [OP] Active Member
    2016 Inferno Tacoma TRD OR 6spd Manual DCSB
    Greetings all, was coming home today when my truck decided to have an anxiety attack.
    Still in the process of using the search bar to figure out what may be wrong, until then enjoy the fireworks on the gauge cluster!
    A little background: 2016 DCSB OR 128k Miles, only mods to the truck are an aftermarket Android head unit with a CAN bus connection (more on CAN) and LED dome lights.
    Sensing electrical/sensor issues for obvious reasons, will do further research. Way past warranty, was considering upgrading before this happened...not so sure after reading some posts.
    Some codes pulled off of bluetooth OBD reader on mobile app are attached.
    Link to vid: http://youtu.be/ihdubMcTbaQ
    Very sorry for poor filming, what we're seeing here is a cycle of the screens:
    Check Brake System
    Crawl Not Available Check System Operation Condition (6spd w/o crawl mode)
    Check Vehicle Stability Control
    There was a flash of Brake Override Malfunction - Contact Dealer at first but couldn't get it on video.
    Turned the truck off and it went away, found error codes below, this was at about 30mph, brakes and acceleration worked fine, seemed to not be in limp mode (b/c of manual tranny?) like some others trucks.
    Believe some codes have to do with the CAN bus and being the radio is plugged inline to it I venture it could be part of the issue, brakes also could use a tuneup. Not condemning anything just thought it'd be helpful for those who are under 100k.
    Warranty out, dealer provides me with sympathy chuckles when I visit!
  2. Jan 25, 2020 at 12:12 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    So you're saying it stopped after you cycled the ignition?
    Warranty or not, trouble codes like that would have me running to the dealer to at least figure out what it could be.
    FredRed315 and Modesto Tacoma like this.
  3. Jan 25, 2020 at 12:23 PM
    Sheppington
    Yeah after I cycled the ignition in the driveway it started up and ran fine with no lights or errors. I agree with you, trying to get it in for a service asap. ABS light has come on in the past but went away and never seen anything this frantic in a vehicle before, it was cycling screens faster before filming.
  4. Jan 25, 2020 at 12:24 PM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    Did u try disconnecting then reconnecting the battery ?
  5. Jan 25, 2020 at 12:26 PM
    Sheppington
    Will do so next chance, raining something awful here so I'll try to avoid adding water to the equation for now!
    Fearthisbeard[QUOTED] likes this.
  6. Jan 25, 2020 at 12:53 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'd would FOR SURE pull the head unit. Especially if it's a cheaper unit. Canbus is wicked complex and removing the HU goes a long way towards finding out the culprit.
  7. Jan 25, 2020 at 2:15 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    U0100 is monitored when the ignition is on, battery voltage is at a certain level and other key modules are configured correctly.
    U0073 can pop up intermittently, or it can result from a dead battery.
    Check your charging system, battery voltage running and off. Check all the grounds. There may be in excess of 12-14 on the truck, I don't know how many but check them all. Grounds are attached, many years ago, over paint, and now years later probably worse. Grounds are responsible for many sensor faults. You have to have absolute connectivity and continuity to chase a code. Snowflake washers are your friend. We installed hundreds at Kia to solve electrical issues. This is free maintenance basically.
    Zim
    Samuel and Bastek like this.
  8. Jan 25, 2020 at 2:26 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Did you recently install your head unit (or anything else)?
    Have you had your crankshaft position sensor replaced?
  9. Jan 25, 2020 at 2:27 PM
    ajmogen
    Aaron
    Wisconsin
    Are you on your original battery?
    auskip07 likes this.
  10. Jan 25, 2020 at 2:35 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    :facepalm:
    SandyTaco4x4 likes this.
  11. Jan 25, 2020 at 2:38 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Damn, true!
  12. Jan 25, 2020 at 2:40 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    yep i would bet the battery is on its way out.
    ajmogen[QUOTED] likes this.
  13. Jan 25, 2020 at 2:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Another vote for battery... or some aftermarket wiring issue.
    shakerhood likes this.
  14. Jan 25, 2020 at 5:22 PM
    Sheppington
    Appreciate you all getting back to me! Big +1 on the grounds because my factory radio shit the bed 5k past warranty (beyond infuriated) and I had a suspicion it was a bad ground or the fact that the air vents are right next to the unit with little to no cooling inside to prevent damage. Will dust off the ol' Fluke soon.
    I've had the aftermarket radio in for about 15k with little to no issues, all properly soldered harness connections so no hand splicing done by myself, although capable. As I said I had a feeling the Canbus decoder may have interfered as it was more or less rigged up when it came to the software (using a different models settings etc.) to get it to work. Nothing else installed recently, to my knowledge no CPS replacement however with the accidents I can't be sure right now. Same story with the battery 99% sure it's original though, will be the next thing replaced most likely.
    Sincerely appreciate the genuine replies... Unlike TW I've met aggravating resistance from others on many a forum. Was hoping my high mileage and immense frustration would act as a pioneer of issues and help others in the future.
    No Clazzios here btw haha, if that were true about the zipper I think I'd kick myself in the ass figuring that one out!
  15. Jan 25, 2020 at 5:24 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Your canbus communication system is going crazy.
    Have you plugged anything into the OBDII/CAN jack ?
    Just read you installed head unit. Disconnect the canbus jack.
    You are getting an E on the temp cluster display. That tells me canbus pblm.
    Skydvrr and Sheppington[OP] like this.
  16. Jan 25, 2020 at 5:26 PM
    Sheppington
    Definitely getting warmer, planning to yank that decoder out tomorrow. I have not plugged anything in other than an ELM327 Bluetooth reader for the phone app Carista. I don't leave it in either only to scan codes. Interesting the temp gauge is what led you to that thought, sounds like proper insight to me!
  17. Jan 25, 2020 at 5:30 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Mine did that when the battery died at 30k.
    Sheppington[OP] likes this.
  18. Jan 25, 2020 at 5:32 PM
    2016Tacoman
    J
    I know on aftermarket Pioneer heads there is a setting in the radio that can affect other canbus interfaces. I had that issue with a scangauge on a truck and the people at scangauge new it was the radio setting interfering with their unit. Been so long now I don't remember the specifics of what page the setting was on in the radio.
    Pioneer head ?
  19. Jan 25, 2020 at 5:38 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Agreed, check CPS
  20. Jan 25, 2020 at 5:39 PM
    Sheppington
    Possibly an override function of some sort... Might have seen similar. Not Pioneer but a China-made Android unit that I spent a long time researching, the branding escapes me but it was the well-supported hidden gem of the bunch at the time. I knew there would be quirks but never like this. Could be a few issues (Batt., Radio, CPS) doing the tango.
