110v power outlet/ Inverter install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jmota25, Jan 3, 2024.
  1. Jan 3, 2024 at 11:45 AM
    Jmota25
    Jmota25 [OP] New Member
    I am installing a OEM power outlet and inverter that I pulled from a 2009, on my 2006 Tacoma. Unfortunately, the wire from the inverter was cut as it enters the engine bay. From what I can tell it enters from the passenger side runs with the wire harness up to the driver side. I don't know if it connects directly to the battery with an inline fuse, or if it goes to a relay in the box. Can anyone help me figure out where this wire goes? I will try to post pictures as soon as I can. Any pictures from someone's stock system would be greatly appreciated.
    I have installed the outlet in the bed, run the harness to the cab and inverter under the center console, continued the harness to the engine bay, and installed the power button on the right of the steering wheel. Just don't know what happens in the engine bay itself.
  2. Jan 3, 2024 at 2:21 PM
    caribe makaira
    Caribbean, Puerto Rico
    cable to relay, relay to fuse, fuse to buss bar (battery), relay controlled via switch in cab via IGN fuse.
    ricphoto and Dm93 like this.
  3. Jan 3, 2024 at 6:46 PM
    Jmota25
    Okay, thanks! That will help a lot. I still would like to see an actual representation of how it all comes together. At this point I am gonna have to do some splicing but nothing too serious.
  4. Jan 3, 2024 at 7:29 PM
    caribe makaira
  5. Jan 3, 2024 at 7:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It goes in a relay box
    Jmota25[OP] and Dm93 like this.
