11.5 inch tires... will they fit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Newbie123, Jun 18, 2012.
  1. Jun 18, 2012 at 8:08 PM
    Newbie123
    Newbie123 [OP] Active Member
    2017 4x4 Off Raod DCLB Super white
    Let me first say i tried doing a search and didn't see anything that came up. I'm sure you guys get the tire fit questions a million times a day, so i apologize in advance.
    I have a 03 prerunner ext cab that i would like to fit one or two in wider tires under with only using different wheels and spacers. I like the goodyear wranger duratrac tires. These are the tire sizes i'm considering 32x11.5x15 or 16. Some of the sizes those tires aren't available in but none the less i'm wondering what kind of spacing will be needed to run without rubbing... Thanks
  2. Jun 18, 2012 at 8:13 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Not sure if your running a lift or not but im running 3" spacer lift and i fit 31x11.5x15 without any rubbing at all. 32s should be fine i would think but ill let someone else chime in :anonymous:
  3. Jun 18, 2012 at 8:16 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    at least 2" lift with about 4.5" backspaced wheels
  4. Jun 19, 2012 at 4:22 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I am running 32x11.5x15 with a 2.5" lift and black rock alloys with 4" backspacing. No rubbing.
  5. Jun 19, 2012 at 7:22 AM
    Pol500
    Pol500 Well-Known Member
    Duluth, MN
    03 TRD DC 4x4
    Deck plate, grey-wire, blue plug, alarm mod, clear corners, moved/painted badges, color matched grill, topper, 5100s, wheelers 5 leaf + 1.5 aal , OME coils, All-Pro rear bumper, Methods w/ 32's, converted HID Hellas, supercharger
    I had 32x11.5x15 with an 1.25" lift on stock aluminum 15s with no rubbing.
  6. Jun 19, 2012 at 7:26 AM
    Newbie123
    The stock tires are 31.7 inches i believe, so why would i need to lift the truck to go wider? :confused:
  7. Jun 19, 2012 at 7:28 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    My tires are close to that wide...I forget the backspacing on my wheels but they rub at full lock on the frame
  8. Jun 19, 2012 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Stock is 265/70 16 which is only 30.6" roughly. Wider tire creates a larger turning area which will put the tire into the fender/frame.
  9. Jun 19, 2012 at 8:38 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    I have a 2.5" lift with 32x11.5x15 and 3.75" backspacing. No rub
  10. Jun 19, 2012 at 3:50 PM
    Newbie123
    Gotcha, so the truck needs to be higher to rise above the centerline of the tire. I copy. Well, If I must lift then I want to go with the shortest lift possible. Ive done some reading and if you're doing just a 1-2 inch lift, blocks seem to be ok. I would much rather go with AAL but havent seen a set up that offers that short of a lift.
  11. Jun 20, 2012 at 5:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check out . They sell a 1.5" leaf pack and a 1.5" AAL. It goes in between the overload and the other leafs. And being a first gen, you can always just stick a longer shackle in there to get the 1-2" of lift also.
  12. Jun 20, 2012 at 7:48 AM
    Newbie123
  13. Jun 20, 2012 at 7:17 PM
    Dek Ngo
    Dek Ngo Well-Known Member
    D
    Austin, TX
    '96 4x4
    Be sure to post pics after you get them installed. I've been thinking about going with the same wheels and would like to see them installed.
