10k miles bulging battery acid leaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ericjmyerssr, Nov 17, 2016.
  1. Nov 18, 2016 at 6:48 PM
    #41
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Huh..??
  2. Nov 18, 2016 at 6:51 PM
    #42
    Markcal
    Markcal Well-Known Member
    Would you recommend a battery tender? I have a Harbor freight "float" charger and seemed to work, but still leery that it keeps the charge, without overcharging it. Maybe I feel this way because HF sells cheap tools, so maybe this "floater" isn't on par with others.
  3. Nov 18, 2016 at 6:53 PM
    #43
    Markcal
    Huh..??
    I thought that was your posting...opps. :oops:
  4. Nov 18, 2016 at 7:03 PM
    #44
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    Sulphacation is hardly an issue anymore. Ever since early 'Diehard' days, a bit of Epsom salt - Magnesium sulfate - has been added to prevent it. Almost every battery manufacturer has their own special mixture for it. You quite correct on using a tender on one, I built a $40 solar tender for the batteries in my tear drop.
  5. Nov 18, 2016 at 7:08 PM
    #45
    over60
    Muskoka, Ontario
    I checked out HF "float" chargers.... Looks like this one would be the one that I would get.... Mine are made other manufacturers, but basically same as this one...
    I'd buy this one...
  6. Nov 18, 2016 at 7:09 PM
    #46
    over60
    Muskoka, Ontario
    Solar tender would work good in the right circumstances..:thumbsup::thumbsup:
  7. Nov 18, 2016 at 7:10 PM
    #47
    Markcal
    OK :thumbsup:
  8. Nov 18, 2016 at 7:31 PM
    #48
    anonemoose
    Bill
    Big Pine, Calif
    As long as it is a three stage tender you are ok. A good read about batteries by the folks that made the converter/charger for my teardrop: http://www.progressivedyn.com/battery_basics.html explains the levels for charging and the 'why' without needing an engineering degree.
  9. Nov 18, 2016 at 8:09 PM
    #49
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I would replace it with a Interstate battery.
    mikmabz likes this.
  10. Nov 19, 2016 at 6:46 AM
    #50
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    My FJs also went through 5 sub zero winters and extreme summer Temps with no issues. Great battery.
    shakerhood likes this.
  11. Nov 19, 2016 at 12:50 PM
    #51
    desertdogtrainer
    desertdogtrainer Member
    This is correct. Mileage got me.
  12. Nov 20, 2016 at 6:25 AM
    #52
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    Had the same issue with my Battery. I had to pull it out and neutralize all of the acid. Then wash everything down. I checked the battery cells and they were full. I guess they were over filled from the factory.
  13. Nov 20, 2016 at 9:50 AM
    #53
    JGreer3
    JGreer3 Well-Known Member
    I used to develop and test batteries in the motorcycle industry. Although not super common this is a known reason why batteries fail. It could have been from the heat or a bad plate in the batter itself, but there wasn't anything you, the truck, or Toyota could have done.
  14. Nov 20, 2016 at 10:04 AM
    #54
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    This thread is still going? :notsure:
  15. Nov 20, 2016 at 10:11 AM
    #55
    Markcal
    :rofl:
  16. Nov 20, 2016 at 1:11 PM
    #56
    over60
    Muskoka, Ontario
    What..? If you pulled out the acid, (ie: emptied the battery).. how can it be full when you check it..? :eek::confused::confused::confused:
  17. Nov 24, 2016 at 7:50 AM
    #57
    kngharley
    Corona, Ca
    No I had to pull the battery out of the truck and neutralize the acid that spilled all over the place. They must have overfilled it from the manufacturer. Batteries are to only be filled to the to of the plates inside the battery Not to the top of the filling holes.
  18. Nov 24, 2016 at 7:53 AM
    #58
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Wife's Rav4 battery lasted 10 yrs. No complaints.
  19. Nov 24, 2016 at 12:04 PM
    #59
    over60
    Muskoka, Ontario
    Holy shit man... it was filled right up to the top...? Of course it would spew acid all over... hope you got it all in time and it didn't wreck anything..!! Did you talk to the dealer about it..?
  20. Nov 25, 2016 at 5:55 AM
    #60
    kngharley
    Corona, Ca
    No... You know dealers. Somehow, some way, they will say it was my fault. It's not even worth the trip in.
