10k mile service
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BSFord, May 10, 2019.
  1. May 10, 2019 at 12:25 PM
    BSFord
    BSFord [OP] Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Hi all,
    So i have an appt tomorrow at my dealer for the 10k service. Not sure if I should go or not and need your help to convince me. I skipped the 5k as since it was basically just a tire rotation and to let air under the hood. Since then I've changed my own oil at 5k and have done nothing else. As of today I'm at 9,6xx miles.
    Is it worth bringing it in? I ask because I would be getting a free oil change and tire rotation, among the other "inspection" items... but I hesitate because I fear the dealer will F something up like I've read about several times on here from other members. Should I take advantage of this "free" service or skip it and do my own maintenance? Am I just being paranoid? what did you do with your ToyotaCare appointments?
    Thanks!
  2. May 10, 2019 at 12:37 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    The service isn’t free...it’s factored into the cost of the truck. The odds the dealer will damage your vehicle and not make it right is greater than you hitting the Powerball jackpot on Saturday.
  3. May 10, 2019 at 12:37 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Frankly, the questions you're asking could have been mostly solved by going in for the 5k? I did an oil change at 5k, but let the shop have at it for all the scheduled services so far. I was able to get comfortable with them at the 5k. I pulled the wheels when messing with stuff and found the lug nuts to not be over-torqued and they felt to be evenly torqued also. About the only thing that I find odd is that they always mess with the seat adjustments. No big deal there, just weird.
    Since, I have found the oil filled perfectly to the top notch. And found similar lug nut torquing when swapping the wheels across to finish up the cross rotation since I didn't feel like asking them to do it.
    I can't resist free service work and will even go back to do the last needless 25k service. From then on, it will be all me. I am curious about the oil filter canister come the 30k service. I have no worries about it being nylon, but will it come off nicely? It sure did at 5k.
    BSFord[QUOTED][OP] likes this.
  4. May 10, 2019 at 12:42 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    There are thousands of 5K/10K checks done everyday... not many, if any, articulate the successful service center experiences versus almost all that have had a bad one do. You did pay for the ToyotaCare (nothing is free)... go and get the service done, and follow up with your own Quality Control check if still concerned.
    Flash1034, tonered and BSFord[OP] like this.
  5. May 10, 2019 at 1:17 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Yes 'Free" over tightening of your oil filter housing and lug nuts. Free grease spot on your seat and an extra free scratch on the door. I avoid that place like the plague.
  6. May 10, 2019 at 2:42 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Just had my 10k done last weekend. No issues and they also did the recall fix of the wave sensor.
    BSFord[OP], CusterFan and tonered like this.
  7. May 10, 2019 at 2:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Haha! With the torque printed right on it, there really isn't much other that hoping the shop trains and supervises well enough.
    Vbpiper likes this.
  8. May 10, 2019 at 3:56 PM
    Xena1
    Ron
    Yes, do your own oil changes and/or buy a Baxter Performance spin on filter adapter like I did.
    Vbpiper likes this.
  9. May 10, 2019 at 3:58 PM
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    Do your own service, you will be happy you did. I do not bring any of my vehicles in to a dealer unless I have to..........................
    BSFord[OP] likes this.
  10. May 10, 2019 at 4:13 PM
    Xena1
    Ron
    The goons in the service dept don't pay a lot of attention to torque specs I can assure you that.
    BSFord[OP] and tonered[QUOTED] like this.
  11. May 10, 2019 at 4:30 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Just curious as I haven't taken a look into it, what's involved in changing the filter in the canister?
    Sounds like a big mess, like the old pre-spin on Ford and Chevy canister filters.
    Vbpiper and tonered like this.
  12. May 10, 2019 at 5:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I know where you are coming from.
    I can tell you, though, that my lug nuts from my dealer are golden. I honestly have no complaints, and I am not a comfortable with shops touching my stuff. Like I said, the final verdict will come in 9k when I swap the filter.
    Taco16LB and BSFord[OP] like this.
  13. May 10, 2019 at 5:06 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It's a piece of cake. Just download the Service Manual that is posted around here somewhere. The OE filters come with a drain valve that makes it mess-free.
    Vbpiper likes this.
  14. May 10, 2019 at 5:46 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I've been bringing it in to the dealer because I'm paranoid about them trying to void the warranty in case I ever need it (knock on wood) and figured it only helps the resell value if you have all maintenance records
    BSFord[OP] and kahanabob like this.
  15. May 10, 2019 at 7:11 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    like IEsurfer said..take it in!
    BSFord[OP] and IEsurfer like this.
  16. May 10, 2019 at 7:16 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I take mine in, if they overtighten, guess who gets to deal with and fix it? The dealer. I’ve got a pretty good service department that has serviced my Toyota vehicles for over 10 years. They also know me, and if I catch something not right, they’ve always fixed it, and at times went above and beyond. Other than some past instances that required higher intervention, no complaints usually.
    Sdswingr, BSFord[OP] and IEsurfer like this.
  17. May 10, 2019 at 7:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Stats:
    Toyota sells 250K Tacomas a year.
    Less than 3% of vehicle owners now change their own oil.
    There are not many people who post on Tacomaworld compared to total owners.
    Most people only post when there is a problem.
    If dealers screwed up as often as people say, there would be hundreds of thousands of posts about dealers. There's not. There's not even hundreds of those posts here.
    My dealer has been taking care of my Toyotas for 15 years. They have screwed up exactly once. Cut O ring on filter. Got home and oil leaked out on my driveway. I called them, told them my problem. Within 30 minutes there was a roll back picking up my 4Runner and putting oil dry on my driveway. Within two hours there was a cleaning company that came out, scrubbed my driveway and removed all trace of oil. The following week their sales manager called and they gave me a Toyota Platinum warranty because I had inquired about possible damage to the engine from lower oil level. The light never came on tho. I drove the 4Runner 100K and traded it in on another one.
    Does this sound like a bad dealer experience?
    Make your own choices instead of strangers on a nameless, faceless internet.
  18. May 10, 2019 at 8:18 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Its just oil change and tire rotation and maybe air filters, the dealer is giving me a free engine air filter for filling out a survey.
  19. May 11, 2019 at 6:20 AM
    Kevin Jones
    Kevin
    Va
    My '18 TRD Sport is nearing 9000 miles and even though I nearly changed oil at 5000 miles I decided to follow Toyota's 10,000 mile recommendation as I've followed their recommendations on my '96 4x4 the entire 23 years I've owned it and and have experienced 412,000 trouble-free miles.
    I believe I will change oil myself as even though I've never heard any negatives regarding Toyota performed oil changes I own a C7 Grandsport Corvette and there's horror story after horror story regarding Chevy dealers changing oil in their 10-quart 'dry-sump' systems. Everything from under-filling, over-filling, lose oil filters, double-gasketing oil filters, not draining both drain plugs, filling oil in coolant reservoir as opposed to oil reservoir.
    It's really a sad state when one has to worry about having such a simple routine task performed at new car dealerships.
  20. May 11, 2019 at 6:34 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    The level of paranoia over dealer service is ridiculous. You’d think trucks across the brand spectrum were blowing up daily.
    Go get your service. You paid for it. If you don’t want them to rotate your tires, tell them not to do it. If they over tighten your oil filter, well, just turn your wrench a little harder to get it off when you do your own services.
    Sdswingr, JCT86, CusterFan and 2 others like this.
