10in kicker bass station connection
Discussion in 'Audio & Video' started by Gatorking89, Jul 22, 2020.
  1. Jul 22, 2020 at 7:20 PM
    Gatorking89
    Gatorking89 [OP] Bandit
    Blairsville Ga
    2019 white tacoma 4d 4x4
    Leveling lift, rc upper control arms, Oldman emu add a leaf, rc 9500lbs winch, diff. drop kit, carrier bearing drop, 2in wheel spacers, 2 5000lb rear airbags for towing, early stile dodge flip tow mirrors, pedal commander, custom built front and back bumpers
    I'm trying to find the best way to install my system without changing my factory sound system
  2. Jul 23, 2020 at 3:23 PM
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    Im confused on so many levels o_O... you want to install without installing?
  3. Jul 23, 2020 at 6:40 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    He wants to install it without replacing the headunit is what I am getting out of what he said.
    So, you will want to make a harness that gets signal from the front speakers to send to the subwoofer. It can either be a line converter, or if the sub accepts speaker inputs, you can just run speaker wires from the front speakers (tap into the speaker harness near the door plugs) to the sub.
  4. Jul 23, 2020 at 6:47 PM
    TacoWdrd
    Shane
    Ohio
    2019 MGM TRD OR
    Ah.... now I’m tracking.
