103k miles... time for a Tune-Up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Axian, Jul 12, 2017.
  1. Jul 12, 2017 at 5:24 PM
    Axian
    Axian [OP] Well-Known Member
    Eric
    Colchester, Vermont
    09 Silver 4x4
    I am nearly at the 103,000 mile mark, and I was wondering just how beneficial a Tune-Up would be?
    Any info would be appreciated. I bought it 2nd hand with ~80K miles on it... not really sure what was done as far as maintenance is concerned, but the truck runs great. Just wondering if I would see any sort of positive outcome from getting a tune-up.
    Thanks!
    Ax
  2. Jul 12, 2017 at 6:10 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    older trucks i.e. first gens plugs typically should be done at 50k miles. The second gens had longer life plugs that are supposed to 100k max. But keep in mind that a plug that is at 80k miles is four fifths worn. I would not do that. The plugs are much more efficient when the gap is in spec. Not all worn down with a much bigger gap. I swap mine at 50k regardless of any other reason than milage. All the parts on my truck are new and so are all the fluids. My truck burns zero oil and leaks nothing! I only use castrol edge extended performance 15,000 mile oil. The truck runs amazing go toyota
  3. Jul 12, 2017 at 6:32 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Those plugs don't get any easier to get out with age, for that reason alone I would change them. I changed mine at 90,000 miles ( bought it with 88,000 miles.) The gaps were between .052 and.063 instead of .041-043 . You will know if the plugs have been changed, the factory puts densos on one side and NGKs on the other.
    TRDSport10 likes this.
  4. Jul 12, 2017 at 6:38 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The 4.0 has 30,000 mile plugs, but they do last longer. I wouldn't go more than 50k, but that's just me. I just changed mine at 29k.
    tcjacado likes this.
  5. Jul 12, 2017 at 6:42 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I waited until 50,000 miles to change plugs this last time instead of my usual 30,000... the plugs looked fine when I pulled them out.
    NAAC3TACO likes this.
  6. Jul 12, 2017 at 6:45 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Not sure if you are trying to be funny but that's kind of a dick response if this guy is looking for serious advice
    OP, get the plugs changed at least. Should be done every 30ishK miles., I'd check air filter, oil/oil filter etc as well
  7. Jul 12, 2017 at 6:45 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I'd do the plugs and fluids (oil, diffs and transfer case at least) just for piece of mind since you don't know the maintenance history. It's not very hard and there is a good how-to on TW somewhere if you need help.
    Edit:
    here it is
    https://www.tacomaworld.com/threads/front-diff-and-transfer-case-oil-change-howto.147631/
    Shwaa likes this.
  8. Jul 12, 2017 at 6:48 PM
    crdnlplt
    crdnlplt Well-Known Member
    SE PA
    17 dcsb trd or
    Definitely change the plugs as mentioned above, mainly so they don't seize up in there. Also, clean the pcv valve. Not many people do this but it makes a surprisingly good difference when done.
    danbow and NAAC3TACO like this.
  9. Jul 12, 2017 at 6:54 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
  10. Jul 12, 2017 at 7:29 PM
    Tacosail
    Jerry
    '13 white ACLB
    While you have it torn apart this far, might as well clean the mas air flow sensor and the throttle body. Might be a few ponies hiding there.
    danbow likes this.
  11. Jul 12, 2017 at 7:42 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would also replace the air in the tires with nitrogen. It will help your mpg.
    Jimmyh likes this.
  12. Jul 12, 2017 at 7:50 PM
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    I changed my plugs at 60k, I'm now at 108k and not changing until I notice starting or gas mileage issues. I would flush my tranny oil and change serpentine belt.
  13. Jul 12, 2017 at 9:53 PM
    SunSetPrez
    SunSetPrez Well-Known Member
    Orange County
    My 2014 is at 86K miles and on the original plugs. Every time I change the oil I keep telling myself I'm going to change the plugs too. Then I get lazy and don't. Oddly enough I have been getting much better fuel mileage in the last 10K than it ever did so who knows if my lazy ass is going to change them.
    dtopgun515 likes this.
  14. Jul 12, 2017 at 10:03 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I has been my understanding that the 30k interval for the 4.0 was for mpg #s, though I'm not sure how that would apply after the truck leaves the lot. So not sure. Pretty confident my 07, (same engine as my '15), owners manual didn't call for so frequent a spark plug swap. I plan to go to 50-60k at least. Once again not certain of any of this.
  15. Jul 12, 2017 at 10:15 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I just changed my plugs at 30k. Immediately noticed a difference in how the motor runs and sounds at low RPM.
  16. Jul 12, 2017 at 11:22 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Air is already 78% nitrogen. Even if you did air up your tires with 100% nitrogen, you would only gain 0.000001 better MPG. It's really just snake oil so you pay to fill up your tires. It's especially a waste when you off-road and need to air down.
    ausfahrt likes this.
  17. Jul 12, 2017 at 11:50 PM
    Axian
    Eric
    Colchester, Vermont
    09 Silver 4x4
    OK... I got quite a list going now. This should be fun!
    danbow likes this.
  18. Jul 13, 2017 at 5:46 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I only gap my plugs, still going on orig plugs at 172k
  19. Jul 13, 2017 at 8:39 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    Beat me to it...
  20. Jul 13, 2017 at 9:16 AM
    knottyrope
    Knotty
    Bahstun
    fill tires with helium to it will be lighter
    JK
    Axian[OP], danbow and mrlee like this.
