10 or 6 ply TIRES!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNROBERTS, Nov 25, 2009.
  1. Nov 25, 2009 at 10:22 AM
    USNROBERTS
    USNROBERTS [OP] Well-Known Member
    Jacksonville, FL
    06 PRERUNNER SR5 TRD SPORT
    I was going to grab some Bfg A/T tires today (265/70/17) but found out there are 2 different thicknesses. Should i go 10 ply or stay with 6? I tow a boat but regular tires do that job fine. Anyone have experience with either or can recommend one or the other? Other tires not an option btw. Thanks for any help in advance!
  2. Nov 25, 2009 at 10:23 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Go 6 ply, its all you need with the taco and you'll have better mpg as a result of the lighter tire.
    ORtoCOTaco likes this.
  3. Nov 25, 2009 at 10:26 AM
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    I had the 10 Ply on my FJ Cruiser and they had really weird road manners. The truck REALLY wanted to go straight. When turning the wheel it really wanted to go back to center.
  4. Nov 25, 2009 at 10:26 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    yup. i believe thats right. i have to get ten ply for my new tires and the gas mileage is going to suck. 6 ply for sure
  5. Nov 25, 2009 at 10:28 AM
    USNROBERTS
    Jacksonville, FL
    Awesome thanks for the Help!
  6. Nov 25, 2009 at 10:30 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    So thats why my I get bad MPG and my tires way a ton. My dune grapplers are 10 ply
  7. Nov 25, 2009 at 10:38 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Go for 6ply whenever you can. 10ply are for fullsize work trucks. 3/4-1ton. Way too stiff of sidewalls. You will get a much better ride and perfomance from a 6ply.
  8. Nov 25, 2009 at 10:50 AM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    good to know next time i get new tires.
  9. Nov 25, 2009 at 10:58 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    wish i would have known that before hand... owell:rolleyes:
    I guess next time ill know
  10. Nov 25, 2009 at 11:14 AM
    dylandercole
    Dylan
    a lot of 285s dont come in the 6 ply. Most of the tires im looking at are only in "E" rating which is the 10 ply.
  11. Nov 25, 2009 at 11:20 AM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    I am going back to 6 ply on my next set. I lost 1-1.5 mpg but they are pretty tough. I have not had a puncture in my 10 plys. I noticed on the spec sheets that 10 ply can weigh 5-10 pound more on each tire and that in unsprung weight.
  12. Nov 25, 2009 at 1:06 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Why not get 8 ply tires? Balance both worlds...
  13. Nov 25, 2009 at 1:42 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    For our trucks, wouldn't the only advantage of 10-ply be for some serious wheeling (aka rocks)? I may be wrong but it seems like they might have better resistance to tearing... Otherwise as for load limit the 6-ply should be more than adequate, as everyone else has said :D
  14. Sep 24, 2016 at 9:13 PM
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I have the Wrangler Duratrac tire 265/70/17 in a 6 ply and taken them off roading in some rough terrain and have no problems.
  15. Sep 24, 2016 at 9:17 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    The 2 ply sidewall makes allot of happiness!
  16. Sep 24, 2016 at 9:20 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    7 year old thread revival, reported
    RattleTractor and DustStorm4x4 like this.
  17. Sep 24, 2016 at 9:26 PM
    Skyway
    Ande'
    St.Pete
    Yep! I skrewed up replying to this.....
  18. Sep 24, 2016 at 9:27 PM
    IronPeak
    AuggieX
    Back to Back
    All in good fun ;)
    Skyway[QUOTED] likes this.
  19. Sep 25, 2016 at 9:24 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I like the 10 ply... been running them on Toyota trucks for the past 26 years and have never had a flat or sidewall damage. The gas mileage takes a hit (always go up in size also) but it's a truck... didn't buy it to save money. I my experience the e rated track and handle corners better. The ride might be rougher but a lot of that can be adjusted with psi.
  20. Sep 25, 2016 at 9:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I always wonder how one finds these old ass threads and replies without realizing it.
