1 TPMS needs replacement, best options?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cropduster78, Feb 9, 2022.
  1. Feb 9, 2022 at 12:32 PM
    cropduster78
    cropduster78 [OP] Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    Anyone have ideas on the cheapest/best way to replace one
    TPMS sensor?
    I was quoted $300.- by my local dealer to do it.
    Normally I wouldn't be so cheap about it but $300 for one sensor and mount and balance
    and a quick reprogram just doesn't seem right.
    Any ideas how to get it done correctly without such a piping?
    Thanks...
    GrizzledBastard and MNMLST like this.
  2. Feb 9, 2022 at 12:38 PM
    avn
    avn Well-Known Member
    A
    CA
    2022 TRD OR
    I think if you go to to an aftermarket place like America’s tire/discount tire (same shop different name for different states) they can do it for way cheaper, tire dismount is $7 tire remount is $22 and I think a new sensor is $60. Prices subject to vary area by area
  3. Feb 9, 2022 at 12:40 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    That’s way too much for one. I got all four done for $350 at my local tire shop.
    cropduster78[OP] and jackn7 like this.
  4. Feb 9, 2022 at 12:53 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    tpms is designed to suck money from your wallet again and again over the life of the truck... it's the gift that keeps on giving. Just buy a $10 pressure gauge and be done with it. Free yourself from the insanity!
  5. Feb 9, 2022 at 12:55 PM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    You can buy an aftermarket kit on Amazon. The tire valve caps measure the pressure. Something like this...
    Easesuper Solar Tire Pressure Monitoring System,7 Alarm Modes & Real-time Monitoring,Automatic Brightness LCD Display,4 External Waterproof Sensors for Car (0-99psi/0-6.8bar) https://www.amazon.com/dp/B09374H9VG?_encoding=UTF8
  6. Feb 9, 2022 at 1:02 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I agree but it varies greatly by which America’s Tire store you go to, or maybe who you talk to there. I’m having a similar issue with a Corolla I’m fixing up for my GF’s son. I knew I had a bad TPMS sensor and went to ATC to see what it would cost to replace and program one sensor.
    They quoted me $400 which included one new sensor with no guarantee that they would be able to program it. I thanked the man for his time (and for confirming which tire had the bad sensor in it) and went home.
    I ordered a new Bosch sensor on Amazon for $30, bought a programmer for $150 then paid a local, no name tire shop $30 to replace the sensor.
    Beware though that if one sensor has gone bad, others may not be far behind; I replaced the bad sensor on the Corolla I’m working on then six weeks later another stopped working. I’m giving some thought to just replacing the original three just to save having to deal with this every couple of months.
  7. Feb 9, 2022 at 1:05 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    That's fuckin' ridiculous. Dealer pricks is what they are. I have an obvious sensor failure that was not caused by anything other then it's own death. Maybe battery, maybe circuitry, but no damage whatsoever and I couldn't get 2 dealers to warranty the POS. Just give me a sensor and clone it and done.
    I just went and bought a complete TPMS kit. The Autel TS508 so I can do my own shit, now. If you want a new, 7000 mile old Toyota OEM sensor, I'll sell you one. I removed 3 functional units and won't reuse them. Any shop can put it in, they don't have to break down your tire, just the bead at the air valve, seal it up with air and program it to your ECU. The programming takes a minute. $40 shipped USPS Priority. I can send you a video proving it works by reading it on my scanner.
    Lots of shops use the Autel brand because they are dual frequency, 315mHz & 433mHz. That way, they only have to stock 1 rubber stem model and 1 metal stem model. The system can read and work with most all OEM systems, it just can't program an OEM sensor. Autel sensor work beautifully with the Toyota ECU.
    I literally just programmed one minutes ago to put in my spare with a new matching TRD Pro wheel. The shop did want $55 a sensor and I think it was $360 to do all 4 so I said screw it and bought the entire system. Autel sensors are only $31
    Kev250R likes this.
  8. Feb 9, 2022 at 1:07 PM
    Squatting Pigeon
    Squatting Pigeon Remember, bird watching goes both ways. Moderator
    North Texas
    TRD OR 4R | GR Corolla
    lossgenius and cropduster78[OP] like this.
  9. Feb 9, 2022 at 1:11 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I run these on my trailer. Great for what they are, but their refresh rate is abysmal compared to stock.
    For the truck I'd let discount tire handle it.
    cropduster78[OP] likes this.
  10. Feb 9, 2022 at 1:37 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    That's pretty much the answer right there. As confusing as it seems when asking questions and getting nebulous answers from dealers and even tire shops, the whole thing is quite simple once you put in a little effort to understand it. This is a money maker for dealers for doing the absolute most minute amount of work. Toyota's sensor prices are hideous. They're made by Pacific and really do nothing more than any other sensor yet I saw them sold for upwards of $80/ea! As I mentioned above, even my Big Brand wanted $55/ea and I had already started investigating sensors and scanners. I've got to be buddy-buddy with the manager there and I asked him what kind of sensors they recommended and sold, he said Autel. Ironically, I already had the Autel system in my Amazon Cart! After our conversation, I sat down while waiting for them to test my bad sensor and I hit the "BUY" button. It was literally in my hands the next day! LOL! 2 days later, I was back with 4 new wheels and 4 new sensors, already programmed (cloned) and it only cost me $109 to break down, mount, and road force balance the new wheels on my near new tires.
    @cropduster78 Serious, if you're interested in an OEM sensor, hit me up. How old are your good sensors? If you're near 5 years, they're croaking. I've got 3 good ones if that helps in anyway, otherwise, check with a local shop and find out if they use Autel sensors because you can buy them on Amazon and hand them to them to program.
  11. Feb 9, 2022 at 3:16 PM
    dalemats
    dalemats Well-Known Member
    dale
    2017 Tacoma Limited 2WD
    2017 MGM Limited 2WD DCSB, bed mat, wheel, spare & tailgate locks, Gen 2 running boards, tri-fold cover, ShiftSense Pro v2, LED interior lights, Bracketeer fire extinguisher bracket, Pop & Lock power tailgate lock,
    You might check Costco or Sam’s Club in your area.
  12. Feb 9, 2022 at 3:26 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Town Fair did mine a couple years ago for about $50.00 each.
  13. Feb 9, 2022 at 3:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    I bought new tires at Costco for a 14 RAV, and decided to do premptive on 8 yo TPMS and had them put in 4 new units.
    Dill is the brand.
    But truthfully any good tire repair or retail shop should be able to fix you up for $75 or so.
    I'd not be inclined to revisit your dealer for ANY service work outside of warranty or recall.
  14. Feb 9, 2022 at 3:44 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    Costco told me $55 for sensors which seemed in line with most reasonable shops. I didn't go as far as asking whether that was including the install since I was just curious with the sensors themselves.
  15. Feb 9, 2022 at 7:13 PM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    Got a replacement sensor at NAPA for $45.
  16. Feb 9, 2022 at 7:28 PM
    Mr. Twisty
    Mr. Twisty Well-Known Member
    Denver, Colorado
    2016 TRD-Offroad Double Cab/1997 V6 Reg Cab
    Did like @GrizzledBastard did, bought the Autel brand scanner/programmer with new stems from TPMS.com. Used a farm jack to get the tire far enough from the rim near the stem to get my fat hand in there to do the swap & air back up. Figured these things are going to be on every new car I own or family/friends have for the rest of my life so why not just get the tool to do them myself.
    GrizzledBastard likes this.
  17. Feb 9, 2022 at 8:31 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    Great idea on the bead break! Damn, I had a Harbor Freight tire changer set up bolted to the concrete for a few years to change my own and friend's motorcycle tires. It had a bead breaker that would have been perfect for the job. I started running some of the heavier, high mileage Bridgestone and Michelin Sport/Tour tires that were even tough for modern hydraulic changer machines. I tore the bolts out of the ground trying to mount one! I gave it away after that! :rolleyes:
  18. Feb 9, 2022 at 8:48 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just did my 2012.
    (4) denso sensors from Amazon (~$35 each)
    (1) bead breaker from harbor freight (~$50 each) - did first with a bottle jack, after it worked I bought bead breaker.
    (1) copy of techstream and dongle
    Balance seems plenty good, i only broke bead on one side so the tires stayed aligned to the wheel and balance weights.
    NOTE, I only recommend doing this yourself with steel wheels, unless you are OK with scratching aluminum wheels.
  19. Feb 9, 2022 at 8:57 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    In my ignorance on TPMS, after the insane quotes and even the $360 from the tire shop, I tried reasoning out the expense and thought "Well, they got break down the tire then mount and balance, so...I get some of the cost...." Then I watched them pull and check my bad OEM sensor that they had been implicated in damaging by the Stealership when I tried to warranty. They just busted the one bead and that's it! I felt pretty stupid that I didn't think out of the box on that one. Then I got pissed again because there's nothing to it! Who would figure so much emotion over a tire sensor?! :rofl:
    BigWhiteTRD[QUOTED] likes this.
  20. Feb 9, 2022 at 9:05 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    if you work on your truck a lot, get a bi-directional OBD2 scan tool that can reprogram TPMS
    you can then just buy your own TPMS sensor and pair it yourself as many times as you want, especially if you also swap winter tires
