1" shackle plus 1" block
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdproven, May 17, 2019.
  1. May 17, 2019 at 8:04 PM
    trdproven
    trdproven [OP] Well-Known Member
    Is this a good idea to lift with a 1" shackle plus 1" block? Dont want to use any leafs as I dont want it stiff. Or is a 2" shackle by itself better? All toytec products.
    Thanks in advance I couldn't find anything about this combo by searching.
  2. May 17, 2019 at 8:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why not new leafs?
    Unless you've got a really low mileage, garage kept specimen, I'm sure your current leaf springs are flat and stiff enough as it is.
    New leafs will give you the height you're looking for.
    Shocks provide the damping you seem to want by your "don't want it stiff" comment; could turn that into a joke but rather not :anonymous:
    otis24 and trdproven[QUOTED][OP] like this.
  3. May 17, 2019 at 9:09 PM
    trdproven
    Stock leafs only have a few thousand miles on it since I warrantied it. I dont tow or load. Not a sag question more of a lift question. Hope that it clarifies the question more.
  4. May 18, 2019 at 5:04 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Stay away from blocks. Shackles or leafs.
    Good luck.
    Brice and trdproven[OP] like this.
  5. May 18, 2019 at 5:14 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    1 inch blocks on the rear are fine. You can research an “add a leaf” (AAL).
    trdproven[OP] likes this.
  6. May 18, 2019 at 5:31 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    You would be fine with this setup. Ignore the naysayers.
    Brice likes this.
  7. May 18, 2019 at 5:31 AM
    trdproven
    I do understand the pros and cons of each. Just wondering since many say 1" blocks are fine but what if you add a 1" shackle lift to it to make it 2".
    Also I do prefer shackles since it maintains the ride quality but the only issue with it I noticed is it tends to expose itself more in our models. Showing below the bed pretty obviously.
  8. May 18, 2019 at 5:32 AM
    trdproven
    Which part the combo or just the 1" block?
  9. May 18, 2019 at 5:35 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    The combo. The only issue you may run into is the passenger leaf springs may rub your tailpipe if its in the stock location. And the shackle doesnt really hang down too far. This was mine when I ran a lift shackle. 0330180931-1.jpg
    You can see it some, but its not that bad imo.
    buckmaster243 likes this.
  10. May 18, 2019 at 5:37 AM
    trdproven
    I actually have the toytec 1" shackle on right now. Looks a bit like yours. Is yours 1"? I'm guessing it would show more using the 1.5-2" setting like another members own I saw here. I'd probably run the emu drop bracket to fix the exhaust part.
  11. May 18, 2019 at 5:39 AM
    trdproven
    Here's mine with 1" toytec shackle in rear
    stealthmode likes this.
  12. May 18, 2019 at 5:42 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    That was the maxtrac adjustable shackle. I had it set for 1.5", although it really only gave .75" at best. Imo, they arent the best way to get lift as they put more stress on the springs and has a higher chance for axle wrap. I swapped it for a 2" add a leaf, which you should really consider. The ride is not stiff like everyone claims it is. Its firm, but by no means harsh.
  13. May 18, 2019 at 5:45 AM
    trdproven
    I was thinking aal if there's a 1" and keep my 1" shackle to make it 2. Wheelers say it should be ok 2 or under. They say the pinion angle issue is more of a 2nd gen up issue as our driveline measurements or geometry is better or something.
  14. May 18, 2019 at 5:48 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I had some nasty vibes after installing my 2" spring. 3 degree shims took care of it. Im actually gonna swap my 2" spring with a wheelers 1.5" sometime in the next few days to get my truck to sit more level. As im im only at 1 & 5/8" of lift up front, so I have some rake.
  15. May 18, 2019 at 5:53 AM
    trdproven
    Which is the best ride 1.5 aal?
    I'm wondering is there certain lift scenarios that cause the vibes. Like too much front or rear rake or height or parts used. Wondering if there is a formula that causes it. I see some high lifts where I am for 1st gen. Noone ever seems to talk about vibes here. Almost 80% of the trucks or SUVs are lifted here. It's a popular thing to lift everything that can be lifted.
  16. May 18, 2019 at 5:59 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Ill let you know monday how the new spring rides
    trdproven[QUOTED][OP] likes this.
  17. May 18, 2019 at 9:11 AM
    Ritchie
    TRD,
    I have 5” of lift in the rear, zero vibes, zero lift blocks and zero shims.
    I do have Deaver leafs and a pair of AllPro shackles.
    The leafs are soft so I added a BudBuilt track bar. Zero axle wrap now.
    Good luck.
  18. May 18, 2019 at 1:34 PM
    trdproven
    How did you get 5" of lift? What's your exact setup?
    Wish there is a sure shot way of lifting, no stiffness, and no cons.
  19. May 18, 2019 at 1:52 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Adding a shim to any amount of lift is never a bad idea. Just keep it at or below 3 degree and it wont do anything bad. And really, shimming should be done with any amount of lift, as the pinion angle is being changed. Some get vibes, some dont. Best way to prevent any vibes and have peace of mind is just to install shims at the same time you install your lift.
  20. May 18, 2019 at 2:03 PM
    trdproven
    I assume to some extent the shims also add lift?
