1 piece driveshaft pros cons
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dYL0n, Jan 31, 2014.
  1. Jan 31, 2014 at 10:26 AM
    dYL0n
    dYL0n [OP] أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Local drive line shop quoted me $320 on a new driveshaft. I'm having terrible vibes on my tacoma. I figured I'd go with a 1 piece rather than change my carrier bearing (which is going to crap) and u joints than need to be replaced.
    Anyways, what are your thoughts on a 1 piece shaft for 2wd? I measured mine and it's ~71" and he's adding 1" because the lift is causing it to stick out the tranny a bit.
  2. Jan 31, 2014 at 10:30 AM
    Large
    Large Red
    A 1 piece got rid of 95% of my vibes but not the wrap on take off. Best of both worlds would be the 1-piece & a trac bar
  3. Jan 31, 2014 at 10:55 AM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Two piece with a double cardan and slip joint is the way to go...but it'll be a bit more $$$. On my phone so I'm having trouble copying the picture, but it's in my gallery if you'd like to see what I'm taking about.
  4. Jan 31, 2014 at 11:01 AM
    dYL0n
    Dyl0n
    New Orleans, LA
    I've heard the same, but that's not a huge issue. The carrier drop I have didn't change my clearance too much
  5. Jan 31, 2014 at 12:06 PM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    Did you have a local shop fabricate your 1-piece or order from someone like Tom Woods?
  6. Jan 31, 2014 at 12:13 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Nortwest Drivelines built it. PM me for more info.
    OP, the reason I bring up this style driveshaft over a one peice is because of a possible "con" of one peice units. There has been some question if the added weight on the output shaft seal causes/or increases the failure rate of the seal (which already has a tendency to leak).
  7. Jan 31, 2014 at 12:14 PM
    Large
    Large Red
    Local member bought a 1 piece that didn't fit his truck, I bought it off him.
  8. Jan 31, 2014 at 12:51 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    That's what my concern was. I figured it'd put more stress on it. I asked him about an aluminum one to help with the weight, that'd be $600. Not even sure what I want to do!
  9. Jan 31, 2014 at 1:35 PM
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Has worked very well for me.:cool:
  10. Jan 31, 2014 at 1:38 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I've had my tom woods 1-piece for 4 years now and I love it
  11. Jan 31, 2014 at 1:49 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    2wd?
  12. Jan 31, 2014 at 2:11 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    4x4
  13. Jan 31, 2014 at 2:25 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    Damn
    I really wish there was someone on here with a 2wd 1 piece shaft.
  14. Jan 31, 2014 at 2:33 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    So here's what I'm thinking now. Get them to keep my front shaft, add a double cardan joint to the rear shaft and make the entire shaft an inch longer than what I have now due to the 4" lift.
  15. Jan 31, 2014 at 2:34 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    If you go with a one-piece, make sure you pick a shop that can spin it to 3500 rpm. Some shops only balance them at 2300 rpm, and that won't cut it. The prior owner of my truck put the one piece on. When I bought it, it still had vibes at 75 to 80mph. I took the shaft in to a good shop here, and they basically ended up re-building it. Now it's smooth. Because the shaft is so long, it has to be larger in diameter. I think mine is 4" in diameter. That's a safety concern, so make sure the shop knows what its doing. FYI, to rebuild my single piece shaft cost about $180 (two new u joints, rebalance, re-weld endcap, repaint) and only took 24 hours. (I was shocked at how cheap that was, but that shop was good. Probably had 10 people working there doing nothing but driveshafts.)
    But I wish I had the double cardan setup. It's "more" stock, so it hurts resale value less. Overall it's probably lighter, and gives a little better ground clearance. If you go double cardan, you should get spring shims and tilt the diff up, so the shaft to diff angle is only about 1 degree. The older forerunners and maybe tacoma's used a double cardan shaft. Some people have found those and rebuilt them to save some money. But the shop could also convert your existing shaft.
  16. Jan 31, 2014 at 6:36 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you do this, make sure to read up on proper pinion angle when using a double cardian.
    You have to make the angle of the back U joint (opposite of the double cardian) almost flat 0* for the harmonics to be right.
  17. Jan 31, 2014 at 6:54 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I'm not positive, but I would bet the vibrations from a two piece would cause a seal failure more often than the extra weight from the one-piece. I am buying a one piece here in a few months. Semi-local(Reno) very reputable driveline shop quoted me $445 w/ tax. They build so many they keep them one stock.
  18. Jan 31, 2014 at 7:14 PM
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    I am curious to see what people are doing to help with low speed drive shutter at take off. I have it and is annoying. If a two piece aftermarket driveshaft cures it that will be my route. The drive line issues suck on our trucks. Mine started after my lift. Tryed carrier bearing drop and axle shims with no luck.
  19. Jan 31, 2014 at 7:55 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    I ended up installing the driveshaft spacer I posted on here for sale. Driveline vibes are gone. Just need to replace the bad u joint I have.
  20. Feb 1, 2014 at 4:54 AM
    simpson1550
    simpson1550 Member
    Indian Head, MD
    2012 Tacoma TRD/OR
    I completely agree, the shop that did mine a few weeks ago said they balanced it at 2500 rpm's. It's great, but vibes from 60-65 mph. I'm gonna take it out soon and have it redone at 3500. Hope that helps.
