1 inch lift options
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoKrush, May 7, 2020.
  1. May 7, 2020 at 12:59 PM
    TacoKrush
    TacoKrush [OP] Active Member
    Denver, CO
    Hey guys I’m currently running a 2017 SR5 DCSB on stock suspension. What equipment (preferably budget friendly) would you guys recommend if I wanted a 1 inch lift in the front while keeping a neutral to slightly positive rake? Would bilstein 5100s be my best bet?
    71tattooguy likes this.
  2. May 7, 2020 at 1:15 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    5100’s will be great. You won’t have much rake. Stock these truckS are 1.5” to 1”5/8 stock rake.
    Junkhead likes this.
  3. May 7, 2020 at 1:21 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    I have a .75” spacer that will net you 1.5” of lift im selling for $45 shipped. Comes with longer top hat bolts too.
  4. May 7, 2020 at 1:24 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Pass on the spacers. Go 5100’s all around won’t disappoint for a good set up. Budget friendly as well. Also Eibach great kit. Mild off-roading and camping etc. will be great. Lots of members running these set ups.
  5. May 7, 2020 at 1:26 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    6112 if you want a better ride than the 5100
    maxtherat and 71tattooguy like this.
  6. May 7, 2020 at 3:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Have you considered installing larger tires, e.g. 255/85R16? Those will raise the whole truck 1".
    Skydvrr likes this.
  7. May 7, 2020 at 3:44 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    While these are a great tire size for getting more ground clearance overall, the OP seems to want to only lift the front to look more level as a looks thing.
  8. May 7, 2020 at 9:02 PM
    TacoKrush
    Denver, CO
    Ended up going with the 5100s all around thanks for everyone's input.
  9. May 8, 2020 at 7:14 AM
    TacoKrush
    Denver, CO
    One more thing... if I wanted to go with the 1.1 inch setting in the front and keep a slight positive rake, would an AAL be my only option? Seems like that would add 1.5 inches in the rear which would make the rake more positive than it already is stock. Trying to stay away from blocks.
  10. May 8, 2020 at 7:28 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i know you dont want blocks- but toytec makes a 1/2” “shim” basically a half inch block that gets thru bolted to your leaf pack. that would get the rear up alittle and have none of the ill effects of bigger blocks. it’s an option.
    you could do the same thing with an old set of overloads (not the ones you have but and additional set)- just cut them down with a chop saw. that would be a free option.
    maxtherat likes this.
  11. May 8, 2020 at 7:33 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Cheapest option is a spacer up front. More expensive option is new struts/springs such as Bilstein 5100's or coilovers such as Eibach's etc. Also factor in the cost of an alignment etc. I would do it right. Buy once, cry once!
  12. May 8, 2020 at 7:37 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Factory rake on these trucks is like 1.5” - 1.5/8”. Lift front and back equal you will be close to factory rake.
  13. May 8, 2020 at 9:05 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    If you want to use an AAL and don't haul heavy weight you can take the Over Load Leaf out of the pack when you put the AAL in.
  14. May 8, 2020 at 9:12 AM
    TacoKrush
    Denver, CO
    Could you link me to the shim? Can’t seem to find it. Will it have any detrimental effect on my drivetrain while off-roading like I’ve read about?
    problem is if I raise the front 1.1” and add a leaf (+1.5”) it will increase the rake by ~0.4” on top of the 1.5” stock rake theoretically.
    71tattooguy[QUOTED] likes this.
  15. May 8, 2020 at 9:14 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    On my DCLB I went 1.5” front 1.5” aal I have close to factory rake
    OvrlndBigAl likes this.
  16. May 8, 2020 at 9:43 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Mind posting a few different angles of your truck when you get a chance? I’m looking to just bump my truck 1-1.5 inches and go 265/75-16 for my next set of tires.
    I can’t figure out how I want to approach a small lift. My truck almost sits level completely stock but with my Snugtop that has the reinforced sportsman package. Not sure how much it weighs but I’m guessing 200 pounds. Even though I fill up my truck with camping stuff, kid stuff and a huge dog I never really “haul” or tow with it. I’m thinking an AAL might be nice for a little additional capacity if I’m lugging around my rooftop tent and the dual sport on my hitch carrier.
  17. May 8, 2020 at 10:11 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    You could also do Icon progre
    no problem. I will. Also you could also do a icon progressive aal. I went with aal with my long bed. Works fine for me. Not a stiff ride at all. I’ll post pics soon for you.
  18. May 8, 2020 at 10:16 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
  19. May 8, 2020 at 10:17 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
  20. May 8, 2020 at 10:18 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
